Vu+ Solo 4K Reinicio al cambiar el audio en reproducción multimedia
Eurolo199
15 May 2015
14
Versión de OpenSpa:
7.2.006
Al reproducir una pelicula en 4K y cambiarle el idioma, se reinicia el deco. Sucede en kodi, en el menu de peliculas, en el mediacenter, etc. Con cualquier reproductor. Pulso amarillo, selecciono una pista de audio DTS o AC3 audio y se reinicia
Características especiales:
Ninguna, es una instalacion limpia
Se adjunta Crash-log: Si/ No
SI
09:55:33.5584 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 190 1
09:55:33.5606 { } Screens/InfoBarGenerics.py:200 actionA KEY: 400 0 KEY_YELLOW YELLOW
09:55:33.8841 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 190 1
09:55:33.8857 { } Screens/InfoBarGenerics.py:200 actionA KEY: 400 1 KEY_YELLOW YELLOW
09:55:33.8860 { } Components/ActionMap.py:46 action [ActionMap] InfobarAudioSelectionActions yellow_key
09:55:33.8897 { } skin.py:1479 readSkin [SKIN] processing screen AudioSelection:
09:55:33.9049 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element key_right in <class 'Screens.AudioSelection.AudioSelection'>
09:55:33.9052 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element key_left in <class 'Screens.AudioSelection.AudioSelection'>
09:55:33.9097 [ E ] gdi/accel.cpp:357 accelAlloc [gAccel] accel alloc failed
09:55:33.9097 [ E ] gdi/gpixmap.cpp:146 gSurface [gSurface] ERROR: accelAlloc failed
09:55:33.9205 { } skin.py:1479 readSkin [SKIN] processing screen SimpleSummary:
09:55:33.9305 { } Screens/Screen.py:151 show [SCREENNAME] ['AudioSelection_summary', 'SimpleSummary']
09:55:33.9323 { } Screens/Screen.py:151 show [SCREENNAME] AudioSelection
09:55:35.6213 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
09:55:35.6248 { } Screens/InfoBarGenerics.py:200 actionA KEY: 108 0 KEY_DOWN DOWN
09:55:35.6254 { } Components/ActionMap.py:46 action [ActionMap] DirectionActions down
09:55:35.9440 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
09:55:35.9458 { } Screens/InfoBarGenerics.py:200 actionA KEY: 108 1 KEY_DOWN DOWN
09:55:36.2670 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
09:55:36.2688 { } Screens/InfoBarGenerics.py:200 actionA KEY: 352 0 KEY_OK OK
09:55:36.2691 { } Components/ActionMap.py:46 action [ActionMap] OkCancelActions ok
09:55:36.2695 [ ] service/servicemp3.cpp:1990 selectTrack [eServiceMP3 selectTrack 1
0:01:08.426171887 2258 0x158b030 ERROR libav :0:: restart header sync incorrect (got 0x1e8c)
0:01:08.426423798 2258 0x158b030 ERROR libav :0:: too many audio samples in frame
0:01:08.426597267 2258 0x158b030 ERROR libav :0:: too many audio samples in frame
0:01:08.426739751 2258 0x158b030 ERROR libav :0:: restart header sync incorrect (got 0x13d4)
0:01:08.426860172 2258 0x158b030 ERROR libav :0:: too many audio samples in frame
0:01:08.427059998 2258 0x158b030 ERROR libav :0:: Invalid blocksize.
09:55:36.4736 [ ] service/servicemp3.cpp:2020 selectAudioStream [eServiceMP3] switched to audio stream 1
09:55:36.4976 [ ] bsod.cpp:328 print_backtrace Backtrace:
09:55:36.4979 [ ] bsod.cpp:336 print_backtrace /usr/bin/enigma2(_Z17handleFatalSignaliP9siginfo_tPv) [0x82E08]
09:55:36.5006 [ ] bsod.cpp:336 print_backtrace /lib/libc.so.6(__default_rt_sa_restorer) [0xB6191E60]
09:55:36.5007 [ ] bsod.cpp:348 handleFatalSignal -------FATAL SIGNAL
09:55:36.5103 [ ] bsod.cpp:328 print_backtrace Backtrace:
09:55:36.5106 [ ] bsod.cpp:336 print_backtrace /usr/bin/enigma2(_Z17handleFatalSignaliP9siginfo_tPv) [0x82E08]
09:55:36.5107 [ ] bsod.cpp:336 print_backtrace /lib/libc.so.6(__default_rt_sa_restorer) [0xB6191E60]
09:55:36.5107 [ ] bsod.cpp:348 handleFatalSignal -------FATAL SIGNAL
Si no me equivoco es por culpa de algún archivo de subtítulos acabado en .srt, si puedes poner aqui el resultado con el media info del archivo se vería perfectamente.
Eurolo199
15 May 2015
14
Hola, Si tiene subtitulos incrustados, aqui pongo la captura del media info
¿que puedo hacer para ver estos archivos con el deco?
Incrustados no lo creo, pero lo que falla son los PGS, creo recordar y no lo que te puse antes, si lo recompilas y quitas esos textos te ira bien.
Eurolo199
15 May 2015
14
OK, lo probare, aunque recompilar cada archivo lleva mas de dos horas. Pero bueno, que le vamos a hacer
Hombre depende de tu pc pero con el mkvtoolnix-gui.exe, puedes tardar como 30 min máximo, por que solo as de quitar lo del subtitulo y si quieres los audios que no utilices.
Eurolo199
15 May 2015
14
Despues de quitar los subtitulos sigo igual, misma situacion y mismo crashlog,
4.394
@Eurolo199 haz un par de pruebas haber si funciona sin cambiar el MKV aunque si quitas los PGS mucho mejor porque dan muchos problemas y no estan soportados en Enigma2.
Primero vete a Plugins-Descargar plugins-systemplugins y instalas serviceapp. Tras reiniciar te vas a Menu-Configuracion del receptor-Uso e interface-ServiceApp, en ese menu veras la primera opcion "Enigma2 playback system" que estara como "Original" pues cambiala a "serviceapp" te aparecera una segunda opcion "Player" esta la cambias a "exteplayer3" el resto lo dejas como esta por defecto y das a boton verde para guardar y salir, sales del todo de los menus y reinicias el receptor, luego pruebas a reproducir la peli como siempre.
Si no funciona instalate el EMC de Plugins-Descargar plugins-extensions-enhancedmoviecenter, tras instalarlo y reiniciar intenta reproducir la peli con este reproductor en lugar de con el MediaCenter.
Quedaria una tercera opcion pero empezaremos por esto, ya contaras.
jositoesp
29 Dic 2017
14
hola compañeros tengo el mismo problema, 1º no se reproducian las películas en 4k, lo conseguí anulando la opción de imagen automática en hd, pero se reproducen en inglés y al cambiar el idioma se sale de la película, voy a probar lo que comenta el compañero a ver si hay suerte.
tengo un octagon sf4008 4k
un saludo
