Nuevo proyecto que reemplaza DogSettings: Editor settings plus
abdelsat
OpenSpa VIP
21 Ene 2008
2.783
361
Gracias.....
Enviado desde mi SM-G900F mediante Tapatalk
vmax
RMCF 1902
26 Dic 2012
2.957
2.355
en el Oeste
Vers. 0.1.0.8
In this version
- Enigma2: transponder frequency correction without channels
- Enigma2: Correction system-standard management
- Import channels from the internet added error checking.
- Enigma2: corrected in userbouquet files, numbering bouquet and added new esp suffix for files
- Enigma 2: correct command to restart the decoder.
- Correction Spanish translation (thanks to abdelsat forum: OpenSpa)
- Fix minor.
http://www.esettingsplus.altervista.org/index-EN.html
Reactions: rusoalicia y txemax
vmax
RMCF 1902
26 Dic 2012
2.957
2.355
en el Oeste
eSettings+ Vers. 1.0.0.0
In this version
- Layout change
- Added tool to telnet
- Added tool signal analysis
- Added videoplayer
- Added channel reference in tooltip general channels list
- Added channel reference in tooltip favorite channels list
- Fixed creating new TP for DDT for satellite management
- Enigma2: Fixed MODD management (only numeric) for satellite management
- Spark2: Fixed max number of TV channels max 15000
- Spark2: Conversion SPARK-> Generic added TID and NID for transponder
- Rounding frequency
- Spark2: Added markers favorite
- Added field Decoding the Channel List
- Modified export bouquet (added decoding channel)
- Modified import bouquet (added decoding channel - Not compatible with earlier)
- Modified export channels (decoding added)
- Others minor Fix
1.767
Hola, acabo de ponerlo en mi pc pero no veo el idiona español hay que meter algun archivo para que este programa tenga idioma español.
Edito: solucionado renombre el archivo a español y no lo guarde. luego lo e puesto en espanol como venia le di a guardar y ya lo tengo.
vmax
RMCF 1902
26 Dic 2012
2.957
2.355
en el Oeste
eSettings+_1.1.0.11
Enigma2 - Neutrino HD - Spark - A3 Spark2 - ALi3612
eSettings+ is a Satellite editor multiplatforms program for Windows.
The features are:
Loading settings from file & decoder
Save to file & decoder
Creating operational profiles
Complete management of channels and favorites lists
Complete management of satellites
Enigma2 conversion settings - Neutrino - Spark - Spark2 - Ali3612 and vv.vv.
Complete management settings for system Spark / Spark2 SAT + DTT
Importing favorite channels lists
Import Export favorite lists - Export channel list in CSV format
Import channel list from KingOfSat
Import channel list from SatChart
IPTV channels manager (enigma2 and Neutrino HD systems)
Import IPTV channels list m3u format
Signal Analyzer Audio/video
Login TELNET session
FTP Client
Player TV/IPTV Channels with current channel EPG (for enigma2 system)
eSettings+_1.1.0.11
