- 19 Mar 2007
- 11.803
- 596
Bueno vamos a insertar nuevas cosas, ahora los plugins pueden ser actualizados de forma automatica desde el receptor como la bajada de semillas para los canales, tambien se añaden nuevas opciones y correciones.
Todo esto es lo que tenemos ya en los Plugins:
Lo nuevo
Lo que ya teniamos
Servicio de descarga automatica en la siguiente IP: http://host1foot.no-ip.info:8080
PASS PARA SOVOK TV
Lo nuevo
1,add crossepg plugin support
2,add sovoktv plugin support
3,fix a bug on Mcas : One tricolor card can't work by mcas
Lo que ya teniamos
------------------------------plugin note 2012.07.12----------------------------------------------------------------
1,update spcs from 2.5.63 version to 2.5.78 version
2,Oscam4spark_tools,new navigation OSD for oscam
3,update mcas to 1.0.10 version.
4,Add plugin_avatar_iptvactive.s for webtv update new list from webtv server .
------------------------------plugin note 2012.04.28----------------------------------------------------------------
update spcs from 2.5.59 version to 2.5.63 version
-------------------------------plugin note 2012.03.09-----------------------------------------------------------------
1,add SparkRcuSrv:a ANDROID RCU plugin, control SPARK stb from ANDROID devices
How to use the ANDROID RCU plugin
1),Press OK button to run "SparkRcuSrv" in the menu/plugin.
2),install "SparkRcu.apk" in android device(smart phone, tablet, etc.)
3),run "SparkRcu" on your android device; switch to config menu, set IP of your spark receiver and save; don't change the Port(default as 8080);
4),make sure the connection between spark receiver and android device is established correctly; then you can control spark receiver via your android device.
2,change the content format for webtv.xml.(add a field : iconsrc_b="")
-------------------------------plugin note 2012.01.10-----------------------------------------------------------------
1,add webtv folder
2,update mcas
3,update spcs
-------------------------------plugin note 2011-11-25--------------------------------------------------------------------------
1,add default biss key
2,make a new Plugin_update2remote: a tool used to add support all existing spark RCU on E2
How to use the Plugin_update2remote to upgrade 'e2remote' on spark system.
1,decompress 'e2remote' folder,and copy the folder to your usb
2,Press OK key to open Plugin_update2remote in the menu/plugin.
3,Press red button enter into Plugin_update2remote menu
4,Select the 'e2remote' folder on the'update path' option,then press red key to start upgrade.
---------------------------------plugin note 2011-10-20-----------------------------------------------------------------
1. under /var/bin: update mcas , camconfig, e2upgrade, oscam, spcs, proton
2. under /var/keys: update keydata.bin keydata.def
---------------------------------plugin note 2011-06-14-----------------------------------------------------------------
1. renew mcas, improve key editor.
2. add plugin_camconfig.s and plugin_e2upgrade.s
---------------------------------plugin note 2011-04-21-----------------------------------------------------------------
update spcs
1. update to spcs2.5.40 (can only run with encrypt.ko)
update mcas:
1. update latest mcas lib
2. add twin protocol support
notice!!
1. make sure conax is disable in system/basic setting/conditional access/conax
2. now only support camd.socket mode and linux dvb api V3, so make sure set mgcamd to box type 6.
3. now can only descramble one channel in mgcamd, which means you can NOT record one channel and watch the other channel.
4. now can support multi-channel in oscamd and mcas, which means you can record one and watch the other one.
5. make sure don't open two client at the same time. for example, don't start mgcamd and oscamd at the sametime.
6. mcas and sharing client can be excueted at the same time.
7. add spcs for middle east
plugin installation
1)usb installation:
1.copy plugin folder to the root directory of first partition of usb stick (like c:/plugin/var).
2.connect usb stick to stb. stb shall prompt a message to user to upgrade plugin.
2)ftp installation:
1.ftp to stb and copy plugin folder to /root.
2.better wait for sometime (10-20 seconds) because stb may need to flush cache data to nand flash.
How to Get free days subscription from NassCam server:
* lunch NassCam menu
* select Download settings and press ok
* wait download success
* goto activation code menu
* select free and press ok
* wait welcome message
PASS PARA SOVOK TV
- login: 1111, pass: 1111
- login: 2222, pass: 2222
- login: 3333, pass: 3333
