Azbox Premium plus No me funciona el Oscam en mi Azbox
llamptv1
11 Ago 2022
8
oscam.conf
[global]
disablelog                    = 0
loghistorylines               = 256
serverip                      =
logfile                       = /var/log/oscam.log
initial_debuglevel            = 0
sysloghost                    =
syslogport                    = 514
logduplicatelines             = 0
pidfile                       =
disableuserfile               = 1
disablemail                   = 1
usrfileflag                   = 0
clienttimeout                 = 15000
fallbacktimeout               = 3000
fallbacktimeout_percaid       =
clientmaxidle                 = 120
bindwait                      = 120
netprio                       = 0
sleep                         = 0
unlockparental                = 0
nice                          = -1
maxlogsize                    = 10
waitforcards                  = 1
waitforcards_extra_delay      = 500
preferlocalcards              = 1
readerrestartseconds          = 0
dropdups                      = 1
reload_useraccounts           = 0
reload_readers                = 0
reload_provid                 = 0
reload_services_ids           = 0
reload_tier_ids               = 0
reload_fakecws                = 0
reload_ac_stat                = 0
reload_log                    = 0
block_same_ip                 = 0
block_same_name               = 1
usrfile                       =
mailfile                      =
cwlogdir                      =
emmlogdir                     = /var/log/
lb_mode                       = 0
lb_save                       = 1000
lb_nbest_readers              = 2
lb_nfb_readers                = 1
lb_min_ecmcount               = 5
lb_max_ecmcount               = 500
lb_reopen_seconds             = 30
lb_reopen_invalid             = 0
lb_force_reopen_always        = 1
lb_retrylimit                 = 0
lb_stat_cleanup               = 336
lb_max_readers                = 0
lb_auto_betatunnel            = 1
lb_auto_betatunnel_mode       = 1
lb_auto_betatunnel_prefer_beta= 50
lb_savepath                   =
lb_retrylimits                =
lb_nbest_percaid              =
lb_noproviderforcaid          =
lb_auto_timeout               = 0
lb_auto_timeout_p             = 30
lb_auto_timeout_t             = 300
double_check_caid             =
ecmfmt                        = c&p/i/s/l:h
resolvegethostbyname          = 0
failbantime                   = 0
failbancount                  = 0
suppresscmd08                 = 0
getblockemmauprovid           = 0
double_check                  = 0
[dvbapi]
enabled                       = 1
au                            = 1
pmt_mode                      = 1
request_mode                  = 0
listen_port                   = 0
delayer                       = 0
ecminfo_type                  = 0
user                          = user1
read_sdt                      = 2
write_sdt_prov                = 1
oscam.server: #aqui si hay mas readers pues todos los pones igual salvo los datos xxxxx
[reader]
label                         = chica_guapa
description                   =
enable                        = 1
protocol                      = cccam
device                        = xxxxxxxx,xxxxxx
user                          = xxxx
password                      = xxxx
inactivitytimeout             = 30
reconnecttimeout              = 30
reconnectdelay                = 60000
cccversion                    = 2.1.4
cccmaxhops                    = 3
cccmindown                    = 0
cccwantemu                    = 0
ccckeepalive                  = 1
cccreshare                    = -1
group                         = 1
oscam.user
[account]
user                          = user1
pwd                           = password1
group                         = 1
tanto el oscam.user como el oscam.conf que te pongo no le tienes que modificar nada.
Funciona a la prefación en cualquiera box E2
