Azbox Premium plus No funciona el multiboot
1.762
Mira estoy loco acabo de darle a control + v y ahora la paguina del foro casi no puedo verla con lo cual no se que me comentais.
papaluna
Vip openspa
12 Oct 2007
725
47
Esto es lo que me sale a mí
Disk /dev/hda: 3811 cylinders, 16 heads, 63 sectors/track
Units = cylinders of 516096 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/hda1 0+ 717 718- 361871+ 83 Linux
/dev/hda2 718 726 9 4536 83 Linux
/dev/hda3 727 844 118 59472 82 Linux swap / Solaris
/dev/hda4 845 3810 2966 1494864 5 Extended
/dev/hda5 845+ 3810 2966- 1494863+ 83 Linux
Disk /dev/mtdblock0: 1 cylinders, 255 heads, 63 sectors/track
Disk /dev/mtdblock1: 0 cylinders, 255 heads, 63 sectors/track
Disk /dev/mtdblock2: 0 cylinders, 255 heads, 63 sectors/track
Disk /dev/mtdblock3: 0 cylinders, 255 heads, 63 sectors/track
Disk /dev/mtdblock4: 0 cylinders, 255 heads, 63 sectors/track
Disk /dev/mtdblock5: 0 cylinders, 255 heads, 63 sectors/track
Disk /dev/sda: 1020 cylinders, 248 heads, 62 sectors/track
Units = cylinders of 208896 bytes, blocks of 1024 bytes, counting from 0
/dev/sda1 0+ 38450- 38451- 7843839+ b W95 FAT32
/dev/sda2 0 - 0 0 0 Empty
/dev/sda3 0 - 0 0 0 Empty
/dev/sda4 0 - 0 0 0 Empty
    1,7 MB · Visitas: 7
1.762
me podeis indicar como colocar otra vez la pantalla del foro en condiciones a que tecla tengo que llegar.
1.762
Disk /dev/hda: 15851 cylinders, 16 heads, 63 sectors/track
/dev/hda1 0+ 371 372- 187487+ 83 Linux
/dev/hda2 372 380 9 4536 83 Linux
/dev/hda3 381 498 118 59472 82 Linux swap / Solaris
/dev/hda4 499 15850 15352 7737408 5 Extended
/dev/hda5 499+ 15850 15352- 7737407+ 83 Linux
Disk /dev/hdb: 121601 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
/dev/hdb1 0+ 121600 121601- 976760032 83 Linux
/dev/hdb2 0 - 0 0 0 Empty
/dev/hdb3 0 - 0 0 0 Empty
/dev/hdb4 0 - 0 0 0 Empty
Disk /dev/sda: 1017 cylinders, 124 heads, 62 sectors/track
Units = cylinders of 3936256 bytes, blocks of 1024 bytes, counting from 0
/dev/sda1 0+ 1016 1017- 3909347+ 83 Linux
Disk /dev/sdb: 1010 cylinders, 63 heads, 62 sectors/track
/dev/sdb1 0+ 245- 246- 1973476+ c W95 FAT32 (LBA)
/dev/sdb2 0 - 0 0 0 Empty
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
1.762
Sigo biendo la configuracion del foro muy pequeño, creo que se a mandado la carpeta de los datos.
1.762
Supongo que usas Dcc, asi que selecciona con el raton la zona que quieres copiar, a continuacion tienes arriba a la izquierda tres iconos, el de la izquierda de dos hojitas de papel es para copiar, despues en el foro con Control V lo pegas.
Sabes como solucionar el problema de que se a quedado la pantalla del foro cuatro dedos mas pequeña a la derecha y a la izquierda con tocar la teclas ctrl + v en el foro.
26 Ago 2009
8.533
2.650
Si usas firefox haz ctrl + 0 y se te restaura el tamaño.
7.252
1.394
Vale, y el comando mount que os devuelve?
1.762
Por cierto para que me de el archivo que tengo que escribir en telnet mount>/var/volatile/tmps/sfdisk.txt es que pongo eso y me dice algo de directorio como que no esta o algo parecido.
1.762
creo que esto esta en el archivo que estaba antes el otro.
7.252
1.394
????? Estas mandado de nuevo lo del sfdisk y ademas, esta repetido tropecientas veces.
1.762
si no es eso no sale nada, pues en la pantalla de telnet al poner el comando que me as puesto no me laia nada.
7.252
1.394
En la pantalla no te tiene que salir nada. Eso te crea el archivo /tmp/mount.txt. Me tienes que poner lo que te sale en ese archivo.
1.762
rootfs on / type rootfs (rw)
/dev/hda1 on / type ext3 (rw,relatime,errors=continue,barrier=1,data=ordered)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /media type tmpfs (rw,relatime,size=64k)
/dev/hdb1 on /media/hdd type ext2 (rw,relatime,errors=continue)
/dev/sda1 on /media/usb1 type ext3 (rw,relatime,errors=continue,user_xattr,barrier=1,data=ordered)
/dev/sdb1 on /media/usb type vfat (rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620)
tmpfs on /var/volatile type tmpfs (rw,relatime)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
/dev/hda5 on /media/spzExtended type ext3 (rw,relatime,errors=continue,barrier=1,data=ordered)
/dev/hda5 on /usr type ext3 (rw,relatime,errors=continue,barrier=1,data=ordered)
djmount on /media/upnp type fuse.djmount (ro,nosuid,nodev,relatime,user_id=0,group_id=0)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=\192.168.D.)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=\192.168\D.)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=\192.168.1D.)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=\192.168D.)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=\192.\D.)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=\\D.)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=\D.)
///D. directas on /media/net/Ddirectas type cifs (rw,mand,noatime,sec=ntlm,unc=D.)
1.762
no se por que me copia tantas veces, por favor si hay datos que no tiene que estar borrarlos todos yo e quitados algunos.
7.252
1.394
Vale, lo veo bien por ahora. Puedes mirar si en la carpeta /media/spzExtended tienes las carpetas usr/bin?
Tambien comprueba que solo tengas las carpetas MutlBootUpload y MultiBootI en el pen que has puesto para ello y si estan en mas sitios borralas.
