- 21 Ene 2011
- 277
- 17
PROBADO Y FUNCIONANDO ES EL 26 CON MEJORAS
LO TENGO PUESTO AHORA MISMO
Los q tengais el 1.3.26 solo actualizar en main code o los q tengais boot 1.1.5
LINK DE DESCARGA
http://foro.goldenmedia.es/redirect...load.com/index.php?action=download&pid=332721
AHORA PONGO TO LO Q TIENE
- Update USB **** (Mcaskey.bin):Configuracion CA en key edit salen dos botones load backup key
Menu -> cards and modules -> SD card -> edit **** -> Red - carga del usb las ****, GREEN - Salva las **** en Usb
- Enter BISS ****:
i -> i -> Red -> RED
- Menu subtitles:
YELLOW -> YELLOW
- Changed the media library menu key (the folder)
There is now access all files on disk without the need to enter the tuner menu.
- Icon image magnification (key 0) shifted to one side
- Access to safe disposal of devices connected via USB:
Menu -> USB -> You can safely remove the device
camd Key uploaded the latest patch (to make the changes you might need to download software
(optional software without a list of channels) via USB twice - the first time a software update to
version 1.3.1929 and the second time updates camd Patch Key.
-BulsatCom ok only by last camd version new key 04 fix 39.0*E
-RAI next key 0C fix (11766V & 10992V 27500 3/4) @ 13.0E*
-Telespazio Hungary Ex Mediatech next key 0C 4.0*W
-ORF/Austrian TV 19.2*E
-CCWs NDTV 24x7 (10921 H 22000 5/6) 28.5*E
-CCWs WDS TV (11278 V 2893 3/4) 10*E/9*E
-Eri Tv 2 (Earth) BISS (12609V S/R 2590 FEC 3/4) 30.5*E 2nd change
-TV Globo key 01 fix (11585/VER/27500) @ 13.0°E
-Kabel Deutschland Key 00 fix (OK) 23.5E*
-BISS **** controll all & insert all new ok
Image Server:
- configure a network connection according to the data access to the Internet (Menu-> Ethernet-> network settings)
- Menu-> Ethernet-> conf network client, press the white key (Activate the server)
- choose from the list of active servers, Avatar, OK confirm
- The window with the keyboard enter the code 9939, OK confirm
- if the connection is correct, you will receive an expiration date of allowances (1 month)
- watch;-)
traduccion de nuestro querido google
- Actualización de las llaves USB (Mcaskey.bin):
Menú -> tarjetas y módulos -> Tarjeta SD -> teclas de edición -> Red - Carga, VERDE - Guardar
- Introduzca las ****** BISS:
- subtítulos del menú:
AMARILLO - AMARILLO>
- Se ha modificado la biblioteca de medios tecla de menú (la carpeta)
Ahora hay acceso a todos los archivos en el disco sin necesidad de entrar en el menú del sintonizador.
- Icono de ampliación de la imagen (tecla 0) pasó a un lado
- Acceso a la eliminación segura de los dispositivos conectados a través de USB:
Menú -> USB -> Usted puede quitar con seguridad el dispositivo
camd clave subido el último parche (para hacer los cambios que usted puede ser que necesite descargar el software
(software opcional sin una lista de canales) a través de USB dos veces - la primera vez que una actualización de software para
la versión 1.3.1929 y el segundo tiempo camd actualizaciones de parches Key.
-Bulsatcom bien sólo última versión de la UEM nueva clave de fijar 39,0 * 04 E
-RAI junto 0C fijar clave (11766V y 10992V 27500 3 / 4) * @ 13.0E
Telespazio Ex-Hungría Mediatech siguiente clave 0C 4.0 * W
TV -ORF/Austrian 19,2 * E
-CCWs NDTV 24x7 (10.921 H 22000 5 / 6) 28.5 * E
-CCWs WDS TV (11278 V 2893 3 / 4) E * 10 / 9 * E
Eri-TV 2 (Tierra) BISS (12609V S / R 2590 FEC 3 / 4) 30.5 E * 2 º cambio
Globo de televisión de clave 01 fix (11585/VER/27500) @ 13.0 ° E
Kabel Deutschland-clave 00 fix (OK) 23.5E *
Llaves BISS controlar todos y se puede insertar todos los nuevos
Imagen del servidor:
- configurar una conexión de red de acuerdo a los datos de acceso a Internet (Menú-> Ajustes de red> Ethernet)
- Cliente de Menú-> conf Ethernet-> red, pulse la tecla blanca (Activar el servidor)
- elegir de la lista de servidores activos, el Avatar, OK confirmar
- La ventana con el teclado introducir el código de 9939, OK confirmar
- si la conexión es correcta, usted recibirá una fecha de caducidad de derechos de emisión (1 mes)
- ver;-)
LINK DE DESCARGA
- Enter BISS ****:
- Menu subtitles:
YELLOW -> YELLOW
Image Server:
- watch;-)
- ver;-)
