- 11 May 2011
- 30
- 2
Quiero aprovechar que este aparato no consume tanto como un pc encendido.
Ademas me gustaria saber si puede conectarse a una vpn
#!/bin/sh
# code by ngc1927
export PATH="$PATH:/root/plugin/transmission/bin/"
export LD_LIBRARY_PATH="/root/plugin/transmission/lib:$LD_LIBRARY_PATH"
export CLUTCH_HOME="/root/plugin/transmission/share/transmission/web/"
CONF="/root/plugin/transmission/conf/"
DOWNLOAD_DIR="/storage/c/Downloads/"
USER="tuusuario"
PASSWORD="tuclave"
CONF_ALLOW_IP=""
case $1 in
start)
/root/plugin/transmission/transmission-daemon -g $CONF -u $USER -v $PASSWORD -w $DOWNLOAD_DIR -a $CONF_ALLOW_IP
sleep 2
echo " "
echo "Transmission Started"
echo "Open your browser at"
echo "http://IP_DECODER:9091"
echo " "
echo "Enjoy "
echo " "
stop)
if [ -n "`pidof transmission-daemon`" ] ; then
echo "stopping transmission-daemon"
killall transmission-daemon
fi
restart)
$0 stop
sleep 5
$0 start
echo " "
echo "Options: $0 {start|restart|stop}"
echo " "
esac
exit 0
#!/bin/sh
# mod by lucifer para gm990
Errore() {
echo "Error 1"
exit 0
export PATH="$PATH:/storage/c/transmission/bin/"
export LD_LIBRARY_PATH="/storage/c/transmission/lib:$LD_LIBRARY_PATH"
export CLUTCH_HOME="/storage/c/transmission/share/transmission/web/"
CONF="/storage/c/transmission/conf"
DOWNLOAD_DIR="/storage/c/transmission/download"
USER="root"
PASSWORD="root"
CONF_ALLOW_IP="+192.168.1.0/255"
case $1 in
start)
transmission-daemon -g $CONF -w $DOWNLOAD_DIR || Errore
#transmission-daemon -g $CONF -u $USER -v $PASSWORD -w $DOWNLOAD_DIR -a $CONF_ALLOW_IP || Errore
sleep 2
echo " "
echo "Transmission arrancado"
echo "Abrir en tu explorador"
echo "http://IPDETUDECO:9091"
echo " "
echo "BIEN HECHO "
echo " "
stop)
echo "Parado transmission-daemon"
kill -9 `pidof transmission-daemon`
fi
restart)
$0 stop
sleep 5
$0 start
echo " "
echo " "
esac
exit 0
