- 21 Oct 2018
- 342
- 43
Tengo imagen 8.0.001 y no me deja actualizar online, pantalla azul.
openSPA Enigma2 crash log
crashdate=sรกb sep 10 13:50:09 2022
compiledate=May 27 2022
skin=BlackSPA/skin.xml
sourcedate=2022-05-21
branch=8.0
rev=9bb7a1e
component=Enigma2
stbmodel=duo2
stbmodel=dm8000
kernelcmdline=libata.force=1:1.5Gbps bmem=192M@64M bmem=384M@512M memc1=788M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
nimsockets=NIM Socket 0:
imageversion=box_type=vuduo2
imageissue=Welcome to openSPA for %h
[eDVBFrontend] Slow ioctl 'FE_READ_STATUS', potential driver issue, 585ms
[eDVBPESReader] Created. Opening demux
[ePyObject] (PyObject_CallObject(<bound method FanControl2.query of <class 'Plugins.Extensions.FanControl2.plugin.FanControl2'>>,()) failed)
dmesg
<6>[DFP]: registered dbox fp
<6>[DFP]: Scart 9597 is found 0
<6>
<6>[SC]: registered sci0
<6>[SC]: registered sci1
<4>system_time_set wakeup mode get
<4>system_time_set wakeup mode get 0xc1
<4>FP Update Driver Loaded
<4>VFDController Update Driver Loaded
<4>BKNI_P_GetTrackAllocEntry_resize: resizing from 8704->14080
<4>BKNI_Malloc(linuxkernel) top users:
<4> blocks, bytes, filename:line
<4> 1627, 359636, BSEAV/lib/utils/balloc.c:31
<4> 1024, 176128, portinginterface/hsm/src/common/bhsm.c:500
<4>[VID]: VIDEO_SET_STREAMTYPE 0
<4>[VID]: VIDEO_SELECT_SOURCE 1 0
<4>[VID]: VIDEO_PLAY 1 2 0
<4>[VID]: VIDEO_CONTINUE 1 1
<4>[VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[VID]: VIDEO_STOP 0 1
<4>[VID]: VIDEO_SELECT_SOURCE 0 0
<6>NET: Registered protocol family 10
<7>__clk_enable: network [1]
<7>bcm7425_pm_network_enable 00
<7>__clk_enable: enet [1]
<7>bcm40nm_pm_genet_enable 00
<6>IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
<6>bcmgenet bcmgenet.0 eth0: link up, 100 Mbps, full duplex
<6>IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
<3>UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
<3>[DFP]: unknown cmd 0x540d
<4>[AUD]: AUDIO_SET_MUTE 0
<4>[AUD]: AUDIO_SET_MIXER -843424264
<4>[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
<4>[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[AUD]: AUDIO_SET_MIXER : amixl 32, amixr 32
<4>[AUD]: AUDIO_SET_MIXER : next left volume -2355, right volume -2355
<7>__clk_disable: enet [0]
<7>bcm40nm_pm_genet_disable 00
<7>__clk_disable: network [0]
<7>bcm7425_pm_network_disable 00
<5>EXT4-fs (sda1): error count: 1
<5>EXT4-fs (sda1): initial error at 1649330256: __ext4_get_inode_loc:3908: inode 171078: block 70057988
<5>EXT4-fs (sda1): last error at 1649330256: __ext4_get_inode_loc:3908: inode 171078: block 70057988
<4>FE tune
<4>[AUD]: AUDIO_SELECT_SOURCE 0
<4>[AUD]: AUDIO_SET_BYPASS_MODE 1
<4>[AUD]: downmix 0 state : 0
<4>[AUD]: AUDIO_PAUSE 1
<4>[AUD]: AUDIO_PLAY 1 decoder start : 0
<4>[VID]: VIDEO_GET_SIZE src w: 1280 h:720 display w:1280 h:720
<4>[VID]: VIDEO_GET_SIZE aspect: 1 3
<4>[VID]: VIDEO_SET_STREAMTYPE 1
<4>[VID]: VIDEO_FREEZE 2141412960 0
<4>[VID]: VIDEO_PLAY 2141412960 5 2
<4>[VID]: VIDEO_SLOWMOTION 0 1
<4>[VID]: VIDEO_FAST_FORWARD 0 1
<4>[VID]: VIDEO_CONTINUE 0 1
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcf570d80
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CHANNEL_SELECT 0
<4>[VID]: VIDEO_STOP 1 1
<4>[AUD]: AUDIO_STOP 8089152
<4>[AUD]: AUDIO_CONTINUE 8089152 0 aph=0x0
<4>[AUD]: AUDIO_CONTINUE aph=0 0 0
<4>[AUD]: AUDIO_SET_MIXER -844808712
<4>FE tune
<4>[VID]: VIDEO_FREEZE 2146890024 0
<4>[VID]: VIDEO_PLAY 2146890024 5 2
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcd9aad00
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_STOP 17555936
<4>[AUD]: AUDIO_CONTINUE 17555936 0 aph=0x0
<4>FE tune
<4>[VID]: VIDEO_FREEZE 2139654968 0
<4>[VID]: VIDEO_PLAY 2139654968 5 2
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcef76a80
<4>[AUD]: Mute : 0
<4>!!!pes_cb idx<0
<4>!!!pes_cb idx<0
<4>[AUD]: AUDIO_STOP 17022240
<4>[AUD]: AUDIO_CONTINUE 17022240 0 aph=0x0
<4>[AUD]: AUDIO_SET_MIXER -820396552
<4>FE tune
<4>[VID]: VIDEO_FREEZE 2139476408 0
<4>[VID]: VIDEO_PLAY 2139476408 5 2
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcf041e00
<4>[AUD]: Mute : 0
<4>!!!pes_cb idx<0
<4>!!!pes_cb idx<0
<4>[AUD]: AUDIO_STOP 18049776
<4>[AUD]: AUDIO_CONTINUE 18049776 0 aph=0x0
<4>FE tune
<4>[VID]: VIDEO_FREEZE 2145198504 0
<4>[VID]: VIDEO_PLAY 2145198504 5 2
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcdab1200
<4>[AUD]: Mute : 0
<4>!!!pes_cb idx<0
<6>usb 3-1: USB disconnect, device number 2
<4>------------[ cut here ]------------
<4>WARNING: CPU: 0 PID: 2314 at /mnt/storage/jenkinsWS/OpenSpa/testspa8.0/builds/openspa/vuduo2/tmp/work-shared/vuduo2/kernel-source/fs/sysfs/group.c:212 sysfs_remove_group+0x168/0x1dc()
<4>sysfs group 807fde54 not found for kobject 'target3:0:0'
<4>Modules linked in: ipv6 brcmfb(O) dvb_bcm7424(PO) dvb_base(PO) bcm_event(PO) procmk(O) rt5370sta(O) rt2800usb rt2800lib rt2x00usb rt2x00lib mac80211 enigma(O) xfs libcrc32c
<4>CPU: 0 PID: 2314 Comm: umount Tainted: P O 3.13.5 #1
<4>Stack : 00000006 00000000 00000000 00000000 00000000 00000000 8087668a 0000003e
<4> 80870000 00000000 807e4040 00010000 8073f4ec ce433d10 807e6627 80873818
<4> 807e4040 00010000 cf485c00 cf825be4 00000001 8068c2b0 807f0000 8002b53c
<4> 10008703 00000000 80743d08 cf45fc24 cf45fc24 8073f4ec 00000000 00000000
<4> 00000000 00000000 00000000 00000000 00000000 00000000 00000000 cf45fba0
<4> ...
<4>Call Trace:
<4>[<8000bce0>] show_stack+0x20/0x70
<4>[<80690400>] dump_stack+0xc0/0xf0
<4>[<8068b808>] warn_slowpath_common+0x84/0xb0
<4>[<8002b6dc>] warn_slowpath_fmt+0x30/0x3c
<4>[<8015d818>] sysfs_remove_group+0x168/0x1dc
<4>[<803ad5dc>] device_del+0x44/0x21c
<4>[<803d816c>] scsi_target_reap_usercontext+0x28/0x3c
<4>[<80045fc0>] execute_in_process_context+0x2c/0x74
<4>[<803db530>] scsi_device_dev_release_usercontext+0x108/0x16c
<4>[<803ac9c8>] device_release+0x38/0xb4
<4>[<8034ddc4>] kobject_put+0x154/0x194
<4>[<803e0dd8>] sd_release+0x80/0xe0
<4>[<801280d8>] __blkdev_put+0x1d8/0x244
<4>[<800e86ac>] deactivate_locked_super+0x5c/0xc4
<4>[<8010a830>] mntput_no_expire+0x200/0x2f4
<4>[<8010bf1c>] SyS_umount+0xa4/0x4f0
<4>[<80010714>] handle_sys+0x134/0x158
<4>
<4>---[ end trace 9f6020ae6d535abd ]---
branch=8.0
rev=9bb7a1e
component=Enigma2
stbmodel=duo2
stbmodel=dm8000
dmesg
<6>
<4>FE tune
<4>[AUD]: Mute : 0
<4>FE tune
<4>[AUD]: Mute : 0
<4>FE tune
<4>[AUD]: Mute : 0
<4>!!!pes_cb idx<0
<4>!!!pes_cb idx<0
<4>FE tune
<4>[AUD]: Mute : 0
<4>!!!pes_cb idx<0
<4>!!!pes_cb idx<0
<4>FE tune
<4>[AUD]: Mute : 0
<4>!!!pes_cb idx<0
<4> ...
<4>Call Trace:
<4>
