Problema Oscam
Raul93_
3 Ene 2019
164
18
No sé que hacer ya. Llevaba una semana sin cortes y otra vez de nuevo empieza a cortarse. Tengo un Vu+ zero 4k con Oscam_modern r11464. Me sale log de este tipo cuando se corta y no tiene ningún sentido porque los ecm no pasan de 300ms:
Por favor ayudadme, ya no sé que hacer.
Esta es mi configuración:
Oscam.server
[reader]
label = ***
protocol = cccam
device = ***,***
user = ***
password = ***
inactivitytimeout = 30
group = 1
emmcache = 1,1,2
cccversion = 2.1.3
cccmaxhops = 3
ccckeepalive = 1
cccreshare = 3
[reader]
label = ***
protocol = cccam
device = ***,***
user = ***
password = ***
group = 1
emmcache = 1,1,2
cccversion = 2.1.3
cccmaxhops = 3
ccckeepalive = 1
cccreshare = 3
[reader]
label = ***
protocol = cccam
device = ***,***
user = ***
password = ***
group = 1
emmcache = 1,1,2
cccversion = 2.1.3
cccmaxhops = 3
ccckeepalive = 1
cccreshare = 3
[reader]
label = emulator
protocol = camd
device = /usr/keys/SoftCam.Key
group = 1
fallback = 1
Oscam.conf
[global]
logfile = stdout
lb_save = 100
[dvbapi]
enabled = 1
au = 1
user = dvbapi
[webif]
httpport = 8080
httpuser = ***
httppwd = ***
httppollrefresh = 10
httpallowed = 127.0.0.1,192.168.100.1-192.168.100.255
Oscam.user
[account]
user = dvbapi
group = 1
Raul93_
3 Ene 2019
164
18
He leido un poco y... Puede ser que en el archivo oscam.server tenga que poner "ccckeepalive=1"? Según PARECE si esa opción está activa, cada cierto tiempo mandaría un ecm al servidor que no se esté usando para que siga activo y no se desconecte. Probaré a ver que tal
Reactions: 1 person
Raul93_
3 Ene 2019
164
18
Oscam.server
[reader]
label = ***
protocol = cccam
device = ***,***
user = ***
password = ***
group = 1
emmcache = 1,1,2
cccversion = 2.1.3
cccmaxhops = 3
ccckeepalive = 1
cccreshare = 3
[reader]
label = ***
protocol = cccam
device = ***,***
user = ***
password = ***
group = 1
emmcache = 1,1,2
cccversion = 2.1.3
cccmaxhops = 3
ccckeepalive = 1
cccreshare = 3
[reader]
label = ***
protocol = cccam
device = ***,***
user = ***
password = ***
group = 1
emmcache = 1,1,2
cccversion = 2.1.3
cccmaxhops = 3
ccckeepalive = 1
cccreshare = 3
[reader]
label = emulator
protocol = camd
group = 1
fallback = 1
Oscam.conf
[global]
logfile = stdout
lb_save = 100
[dvbapi]
enabled = 1
au = 1
user = dvbapi
[webif]
httpport = 8080
httpuser = ***
httppwd = ***
Oscam.user
[account]
user = dvbapi
group = 1
mikitor
30 Jul 2018
223
54
Y con cccam no te va bien?
Tengo un uno 4k con cccam 2.3.2 y de lujo sin cortes
No puede ser tu red? Pregunto
Raul93_
3 Ene 2019
164
18
@mikitor También se me corta pero tengo entendido que con cccam si tienes más de una linea (como es mi caso) no suele ir tan bien como con oscam y con los ecm altos tiene problemas. Lo raro es que llevaba una semana (con Oscam) sin ningún corte y de un dia para otro...pam! Antes por lo menos sabía que se cortaban porque tenía un ecm muy alto y era problema de la linea, se solucionó y empezó a ir de maravilla... Pero ahora...
Raul93_
3 Ene 2019
164
18
El enésimo reinicio que hago y nada más empezar... Las 3 lineas con NOK's a la vez... Esto es cada vez que hay un corte. Como pueden fallar las 3 a la vez? No entiendo nada. Y encima no puedo comprobar si es problema del internet porque mi deco sólo se puede conectar por cable y no puedo probarlo con el 4G...FABULOSO!!
994
tienes que adaptar ese [global] de oscam.conf lo tienes escueto...si guardas configuración por web oscam te deberia registrar todos los valores en tu archivo oscam.conf que tienes del resto de parámetros por defecto y a partir de ahi, adapta los valores a lo que mejor te funcione, tienes me da varios servidores es importanrte adaptar el global a tu forma y config para tu servidor completo.
994
aparte tienes errores demuxer, estos muchas veces estan relacionado con el binario en si, osea, lo más rapido para comprobar que esos errores no sigan es cambiar el binario a otra versión OSCam y si esto no soluciona pues intentar atajar errores de configuración.
Raul93_
3 Ene 2019
164
18
@fogo Y como puede ser que con esa configuración haya estado una semana sin ningún corte?
instinto
7 Feb 2018
69
68
Escribete una oscam.dvbapi para poner la prio
P: 1810
P: 0100
994
OSCam es muy compleja dado la cantidad de parámetros que tiene, aparte cada servidor es una historia distinta, a esto sumale que algo ajeno a ti, si no a otro servidor puede implicar tu estabilidad.....muy bueno también lo que te indica @instinto prioriza la plataforma a ver si estabiliza ese demuxer.
Raul93_
3 Ene 2019
164
18
Acabo de empezar de nuevo y he puesto sólo un servidor. Mirad lo que me aparece en "Users".
instinto
7 Feb 2018
69
68
Lo mejor es enchufar el Receptor por Cable al Router y no usar Wifi o D-LAN. Lo tienes por Cable?
