Buenas... mismo resultado. Os copio el dmesg. Es instalación limpia, sin copia de seguridad. He puesto la instalación automática en off, le he dado a instalar, y reiniciado cuando me ha pedido. Como estaba en amarillo, le he dado a cargar, y reiniciado gui. Como seguía en amarillo, he apagado deco y vuelto a encender, y sigue amarillo.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.14.28 (
[email protected]) (gcc version 13.2.0 (GCC) ) #1 SMP Fri Feb 24 05:23:03 UTC 2017
[ 0.000000] CPU: ARMv7 Processor [420f00f3] revision 3 (ARMv7), cr=30c7387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: BCM97252SSAT_V00
[ 0.000000] moving dtb from 0x0000000007628000 to 0x0000000000943430
[ 0.000000] cma: Reserved 504 MiB at 0x0000000010000000
[ 0.000000] cma: Reserved 260 MiB at 0x000000002f800000
[ 0.000000] cma: Reserved 1020 MiB at 0x0000000080000000
[ 0.000000] cma: Reserved 16 MiB at 0x000000000f000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 524288
[ 0.000000] free_area_init_node: node 0, pgdat c0903e40, node_mem_map cd7f2000
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] HighMem zone: 5632 pages used for memmap
[ 0.000000] HighMem zone: 458752 pages, LIFO batch:31
[ 0.000000] MCP: Enabling write pairing
[ 0.000000] PERCPU: Embedded 8 pages/cpu @cd7c0000 s9536 r8192 d15040 u32768
[ 0.000000] pcpu-alloc: s9536 r8192 d15040 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523776
[ 0.000000] Kernel command line: root=/dev/mmcblk0p4 rootwait rw rootwait=data=journal debug,nolock coherent_pool=2M brcm_cma=504M@0x10000000 brcm_cma=260M@0x2f800000 br
cm_cma=1020M@0x80000000 hwtypenum=264
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 219400K/2097152K available (6648K kernel code, 348K rwdata, 1984K rodata, 265K init, 200K bss, 34552K reserved, 1843200K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0876524 (8634 kB)
[ 0.000000] .init : 0xc0877000 - 0xc08b9540 ( 266 kB)
[ 0.000000] .data : 0xc08ba000 - 0xc0911300 ( 349 kB)
[ 0.000000] .bss : 0xc0911308 - 0xc0943430 ( 201 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc403000, parent irq: 93)
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc3e1000, parent irq: 64)
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc410640, parent irq: 95)
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc4d1200, parent irq: 58)
[ 0.000000] Architected cp15 timer(s) running at 27.00MHz (virt).
[ 0.000004] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 2545165795328ns
[ 0.000008] Switching to timer-based delay loop
[ 0.000199] Console: colour dummy device 80x30
[ 0.000217] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
[ 0.000225] pid_max: default: 32768 minimum: 301
[ 0.000311] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000316] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.005953] CPU: Testing write buffer coherency: ok
[ 0.006156] CPU0: update cpu_power 1024
[ 0.006163] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.006322] Setting up static identity map for 0x65a848 - 0x65a8a0
[ 0.008470] CPU1: Booted secondary processor
[ 0.008490] CPU1: update cpu_power 1024
[ 0.008493] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008555] Brought up 2 CPUs
[ 0.008565] SMP: Total of 2 processors activated.
[ 0.008569] CPU: All CPU(s) started in SVC mode.
[ 0.008899] devtmpfs: initialized
[ 0.012063] VFP support v0.3: implementor 42 architecture 4 part 00 variant 0 rev 0
[ 0.039256] regulator-dummy: no parameters
[ 0.039473] NET: Registered protocol family 16
[ 0.040679] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[ 0.041413] cpuidle: using governor ladder
[ 0.041419] cpuidle: using governor menu
[ 0.043773] irq: no irq domain found for /rdb/interrupt-controller@f040a700 !
[ 0.043908] irq: no irq domain found for /rdb/interrupt-controller@f0417380 !
[ 0.047085] irq: no irq domain found for /rdb/interrupt-controller@f03e1a00 !
[ 0.047319] syscon f0404000.syscon: regmap [mem 0xf0404000-0xf0404523] registered
[ 0.047456] syscon f0404100.syscon: regmap [mem 0xf0404100-0xf040415b] registered
[ 0.047608] syscon f040415c.syscon: regmap [mem 0xf040415c-0xf040419b] registered
[ 0.047747] syscon f0410700.syscon: regmap [mem 0xf0410700-0xf041070b] registered
[ 0.047872] syscon f041070c.syscon: regmap [mem 0xf041070c-0xf0410713] registered
[ 0.047991] syscon f1101004.syscon: regmap [mem 0xf1101004-0xf1101403] registered
[ 0.048110] syscon f1181004.syscon: regmap [mem 0xf1181004-0xf1181403] registered
[ 0.048246] syscon f0404080.syscon: regmap [mem 0xf0404080-0xf0404083] registered
[ 0.048380] syscon f04040a4.syscon: regmap [mem 0xf04040a4-0xf04040a7] registered
[ 0.048495] syscon f03e0154.syscon: regmap [mem 0xf03e0154-0xf03e0157] registered
[ 0.048611] syscon f03e0354.syscon: regmap [mem 0xf03e0354-0xf03e0357] registered
[ 0.048734] syscon f03e0400.syscon: regmap [mem 0xf03e0400-0xf03e0403] registered
[ 0.049263] irq: no irq domain found for /rdb/interrupt-controller@f0417380 !
[ 0.049735] syscon f03e2400.syscon: regmap [mem 0xf03e2400-0xf03e27ff] registered
[ 0.049886] syscon f0452000.syscon: regmap [mem 0xf0452000-0xf04520ff] registered
[ 0.050440] No ATAGs?
[ 0.050456] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.050461] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.050626] Broadcom Brahma-B15 readahead cache at: 0xfc3e2478
[ 0.064412] bio: create slab <bio-0> at 0
[ 0.065343] SCSI subsystem initialized
[ 0.065530] libata version 3.00 loaded.
[ 0.065873] usbcore: registered new interface driver usbfs
[ 0.065941] usbcore: registered new interface driver hub
[ 0.066025] usbcore: registered new device driver usb
[ 0.066138] Linux video capture interface: v2.00
[ 0.066336] pps_core: LinuxPPS API ver. 1 registered
[ 0.066340] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <
[email protected]>
[ 0.066385] PTP clock support registered
[ 0.066943] Advanced Linux Sound Architecture Driver Initialized.
[ 0.067635] cfg80211: Calling CRDA to update world regulatory domain
[ 0.068078] brcm-pci f0460000.pcie: adjusting to legacy (broken) pcie DT
[ 0.068280] brcm-pci f0490000.pcie: adjusting to legacy (broken) pcie DT
[ 0.168654] brcm-pci f0460000.pcie: link down
[ 0.268880] brcm-pci f0490000.pcie: link down
[ 0.268921] Switched to clocksource arch_sys_counter
[ 0.269068] FS-Cache: Loaded
[ 0.276785] NET: Registered protocol family 2
[ 0.277121] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.277137] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.277158] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.277206] TCP: reno registered
[ 0.277213] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.277224] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.277325] NET: Registered protocol family 1
[ 0.277482] RPC: Registered named UNIX socket transport module.
[ 0.277488] RPC: Registered udp transport module.
[ 0.277491] RPC: Registered tcp transport module.
[ 0.277494] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.277500] PCI: CLS 0 bytes, default 64
[ 0.277694] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.278712] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.284668] bounce pool size: 64 pages
[ 0.290646] FS-Cache: Netfs 'nfs' registered for caching
[ 0.290953] NFS: Registering the id_resolver key type
[ 0.290975] Key type id_resolver registered
[ 0.290979] Key type id_legacy registered
[ 0.290988] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.290993] Installing knfsd (copyright (C) 1996
[email protected]).
[ 0.291226] FS-Cache: Netfs 'cifs' registered for caching
[ 0.291443] Key type cifs.spnego registered
[ 0.291595] fuse init (API version 7.22)
[ 0.292021] SGI XFS with security attributes, realtime, large block/inode numbers, no debug enabled
[ 0.293246] msgmni has been set to 460
[ 0.293851] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.293858] io scheduler noop registered
[ 0.293874] io scheduler cfq registered (default)
[ 0.294113] brcm-gisb-arb f0400000.gisb-arb: registered mem: fc400000, irqs: 258, 259
[ 0.360325] brcm-cma brcm-cma.0: Initialized Broadcom CMA root device
[ 0.360862] brcm-cma brcm-cma.0: Added CMA device @ PA=0x10000000 LEN=0x1f800000
[ 0.371581] brcm-cma brcm-cma.0: Pre-allocated 0x1f800000 bytes @ 0x10000000
[ 0.372155] brcm-cma brcm-cma.1: Added CMA device @ PA=0x2f800000 LEN=0x10400000
[ 0.377850] brcm-cma brcm-cma.1: Pre-allocated 0x10400000 bytes @ 0x2f800000
[ 0.378438] brcm-cma brcm-cma.2: Added CMA device @ PA=0x80000000 LEN=0x3fc00000
[ 0.398835] brcm-cma brcm-cma.2: Pre-allocated 0x3fc00000 bytes @ 0x80000000
[ 0.399274] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.400792] f040a900.serial: ttyS0 at MMIO 0xf040a900 (irq = 107, base_baud = 5062500) is a 16550A
[ 1.263682] console [ttyS0] enabled
[ 1.267554] f040a940.serial: ttyS1 at MMIO 0xf040a940 (irq = 108, base_baud = 5062500) is a 16550A
[ 1.276868] f040a980.serial: ttyS2 at MMIO 0xf040a980 (irq = 109, base_baud = 5062500) is a 16550A
[ 1.291174] brd: module loaded
[ 1.296709] loop: module loaded
[ 1.300487] ahci brcmstb-ahci.0: can't get clock
[ 1.305201] ahci brcmstb-ahci.0: SSS flag set, parallel bus scan disabled
[ 1.322939] ahci brcmstb-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 1.331566] ahci brcmstb-ahci.0: flags: 64bit ncq sntf stag pm clo pmp slum part
[ 1.341013] scsi0 : ahci_platform
[ 1.344648] scsi1 : ahci_platform
[ 1.348181] ata1: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x100 irq 91
[ 1.356113] ata2: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x180 irq 91
[ 1.365252] spi_brcmstb f03e3400.spi: 1-lane output, 3-byte address
[ 1.371647] spi_brcmstb f03e3400.spi: master is unqueued, this is deprecated
[ 1.378971] m25p80 spi32766.0: found gd25q32, expected m25p80
[ 1.384744] m25p80 spi32766.0: gd25q32 (4096 Kbytes)
[ 1.389738] 5 ofpart partitions found on MTD device spi32766.0
[ 1.395580] Creating 5 MTD partitions on "spi32766.0":
[ 1.400728] 0x000000000000-0x000000200000 : "flash0.bolt"
[ 1.406799] 0x000000200000-0x000000210000 : "flash0.macadr"
[ 1.412980] 0x000000210000-0x000000220000 : "flash0.nvram"
[ 1.419038] 0x000000220000-0x000000230000 : "flash0.devtree"
[ 1.425261] 0x000000000000-0x000000400000 : "flash0"
[ 1.431736] libphy: Fixed MDIO Bus: probed
[ 1.436408] bcmgenet f0b00000.ethernet: GENET 4.5 EPHY: 0x1001
[ 1.452927] libphy: bcmgenet MII bus: probed
[ 1.474934] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.481520] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[ 1.487369] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
[ 1.493841] xhci-brcm: xHCI BRCM driver
[ 1.497783] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
[ 1.503660] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 1
[ 1.511745] xhci-brcm f0471000.xhci_v2: irq 149, io mem 0xf0471000
[ 1.518430] hub 1-0:1.0: USB hub found
[ 1.522220] hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 1.529481] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
[ 1.535286] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 2
[ 1.543552] hub 2-0:1.0: USB hub found
[ 1.547322] hub 2-0:1.0: 2 ports detected
[ 1.551693] ehci-brcm: EHCI BRCM driver
[ 1.555625] ehci-brcm f0470300.ehci_v2: EHCI Host Controller
[ 1.561441] ehci-brcm f0470300.ehci_v2: new USB bus registered, assigned bus number 3
[ 1.579394] ehci-brcm f0470300.ehci_v2: irq 145, io mem 0xf0470300
[ 1.590929] ehci-brcm f0470300.ehci_v2: USB 2.0 started, EHCI 1.00
[ 1.597574] hub 3-0:1.0: USB hub found
[ 1.601346] hub 3-0:1.0: 1 port detected
[ 1.605480] ehci-brcm f0470500.ehci_v2: EHCI Host Controller
[ 1.607935] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.616708] ehci-brcm f0470500.ehci_v2: new USB bus registered, assigned bus number 4
[ 1.634661] ehci-brcm f0470500.ehci_v2: irq 146, io mem 0xf0470500
[ 1.645928] ehci-brcm f0470500.ehci_v2: USB 2.0 started, EHCI 1.00
[ 1.652538] hub 4-0:1.0: USB hub found
[ 1.656307] hub 4-0:1.0: 1 port detected
[ 1.660535] ohci-brcm: OHCI BRCM driver
[ 1.664451] ohci-brcm f0470400.ohci_v2: BRCM OHCI controller
[ 1.670260] ohci-brcm f0470400.ohci_v2: new USB bus registered, assigned bus number 5
[ 1.678140] ohci-brcm f0470400.ohci_v2: irq 147, io mem 0xf0470400
[ 1.739387] hub 5-0:1.0: USB hub found
[ 1.743160] hub 5-0:1.0: 1 port detected
[ 1.747274] ohci-brcm f0470600.ohci_v2: BRCM OHCI controller
[ 1.753162] ohci-brcm f0470600.ohci_v2: new USB bus registered, assigned bus number 6
[ 1.761062] ohci-brcm f0470600.ohci_v2: irq 148, io mem 0xf0470600
[ 1.822326] hub 6-0:1.0: USB hub found
[ 1.826099] hub 6-0:1.0: 1 port detected
[ 1.830313] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.836860] ehci-pci: EHCI PCI platform driver
[ 1.841390] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.847608] ohci-pci: OHCI PCI platform driver
[ 1.852286] usbcore: registered new interface driver usb-storage
[ 1.855369] usb 2-2: new SuperSpeed USB device number 2 using xhci-brcm
[ 1.865063] mousedev: PS/2 mouse device common for all mice
[ 1.867092] usb 2-2: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 1.880218] i2c /dev entries driver
[ 1.884077] IR NEC protocol handler initialized
[ 1.888713] IR RC5(x) protocol handler initialized
[ 1.893559] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 1.899680] IR RC6 protocol handler initialized
[ 1.904221] IR JVC protocol handler initialized
[ 1.905042] scsi2 : usb-storage 2-2:1.0
[ 1.912616] IR Sony protocol handler initialized
[ 1.917251] IR RC5 (streamzap) protocol handler initialized
[ 1.922852] IR SANYO protocol handler initialized
[ 1.927572] IR MCE Keyboard/mouse protocol handler initialized
[ 1.933644] cpufreq_cpu0: failed to get cpu0 regulator: -19
[ 1.939470] sdhci: Secure Digital Host Controller Interface driver
[ 1.945663] sdhci: Copyright(c) Pierre Ossman
[ 1.950026] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.956802] mmc0: no vqmmc regulator found
[ 1.960908] mmc0: no vmmc regulator found
[ 1.995928] mmc0: SDHCI controller on f03e0000.sdhci [f03e0000.sdhci] using ADMA
[ 2.005414] mmc1: no vqmmc regulator found
[ 2.009525] mmc1: no vmmc regulator found
[ 2.028941] usb 3-1: new high-speed USB device number 2 using ehci-brcm
[ 2.042931] mmc1: SDHCI controller on f03e0200.sdhci [f03e0200.sdhci] using ADMA
[ 2.050606] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.059403] usbcore: registered new interface driver usbhid
[ 2.064986] usbhid: USB HID core driver
[ 2.073029] TCP: cubic registered
[ 2.076355] Initializing XFRM netlink socket
[ 2.084525] NET: Registered protocol family 10
[ 2.089689] NET: Registered protocol family 17
[ 2.094162] NET: Registered protocol family 15
[ 2.098859] Key type dns_resolver registered
[ 2.103184] Registering SWP/SWPB emulation handler
[ 2.108371] regulator-dummy: disabling
[ 2.116366] ALSA device list:
[ 2.119349] No soundcards found.
[ 2.121580] mmc1: BKOPS_EN bit is not set
[ 2.127088] Waiting for root device /dev/mmcblk0p4...
[ 2.127815] mmc1: new high speed MMC card at address 0001
[ 2.137806] mmcblk0: mmc1:0001 4FPD3R 3.64 GiB
[ 2.142508] mmcblk0boot0: mmc1:0001 4FPD3R partition 1 4.00 MiB
[ 2.148535] mmcblk0boot1: mmc1:0001 4FPD3R partition 2 4.00 MiB
[ 2.154538] mmcblk0rpmb: mmc1:0001 4FPD3R partition 3 512 KiB
[ 2.164084] mmcblk0: p1 p2 p3 p4
[ 2.170337] mmcblk0boot1: unknown partition table
[ 2.176179] mmcblk0boot0: unknown partition table
[ 2.369438] EXT4-fs (mmcblk0p4): recovery complete
[ 2.374925] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 2.383051] VFS: Mounted root (ext4 filesystem) on device 179:4.
[ 2.389512] devtmpfs: mounted
[ 2.392617] Freeing unused kernel memory: 264K (c0877000 - c08b9000)
[ 2.806182] random: nonblocking pool is initialized
[ 2.928466] scsi 2:0:0:0: Direct-Access Kingston DataTraveler 3.0 PQ: 0 ANSI: 6
[ 2.940196] sd 2:0:0:0: [sda] 60437492 512-byte logical blocks: (30.9 GB/28.8 GiB)
[ 2.950074] sd 2:0:0:0: [sda] Write Protect is off
[ 2.954943] sd 2:0:0:0: [sda] Mode Sense: 4f 00 00 00
[ 2.957907] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.960986] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2.975373] sda: sda1
[ 2.982132] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 3.220091] Platform init...
[ 3.315187] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.060252] Platform init... ok.
[ 4.092927] [Front Version = 40]
[ 4.096171] >> No hwtype = 8
[ 4.122575] input: LUNIX3 4K remote control (native) as /devices/virtual/input/input0
[ 4.139789] LUNIX3 4K Linux DVB BCM73xx CI Driver Release Time (27/04/21)
[ 4.828113] BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
[ 4.834670]
[ 4.837330] BKNI_Malloc(linuxkernel) top users:
[ 4.837330] blocks, bytes, filename:line
[ 4.846311]
[ 4.847940] 966, 205800, ../BSEAV/lib/utils/balloc.c:31
[ 4.853879]
[ 5.563607] scanning fe...ftt9760.
[ 5.693825] DVB: registering new adapter (bcmdvb-0)
[ 12.288119] (NULL device *): DVB: registering adapter 0 frontend 0 (BCM7252S DVB-S2)...
[ 12.296200] tunercnt 0 name bcmdvb-0 adapter0
[ 12.308621] DVB: registering new adapter (bcmdvb-1)
[ 12.446516] (NULL device *): DVB: registering adapter 1 frontend 1 (BCM7252S DVB-S2)...
[ 12.454584] tunercnt 1 name bcmdvb-1 adapter1
[ 12.459470] DVB: registering new adapter (bcmdvb-2)
[ 12.566259] (NULL device *): DVB: registering adapter 2 frontend 2 (BCM7252S DVB-S2)...
[ 12.574311] tunercnt 2 name bcmdvb-2 adapter2
[ 12.579004] DVB: registering new adapter (bcmdvb-3)
[ 12.684677] (NULL device *): DVB: registering adapter 3 frontend 3 (BCM7252S DVB-S2)...
[ 12.692710] tunercnt 3 name bcmdvb-3 adapter3
[ 12.697427] DVB: registering new adapter (bcmdvb-4)
[ 12.800196] (NULL device *): DVB: registering adapter 4 frontend 4 (BCM7252S DVB-S2)...
[ 12.808276] tunercnt 4 name bcmdvb-4 adapter4
[ 12.813021] DVB: registering new adapter (bcmdvb-5)
[ 12.920715] (NULL device *): DVB: registering adapter 5 frontend 5 (BCM7252S DVB-S2)...
[ 12.928743] tunercnt 5 name bcmdvb-5 adapter5
[ 12.933424] DVB: registering new adapter (bcmdvb-6)
[ 13.039977] (NULL device *): DVB: registering adapter 6 frontend 6 (BCM7252S DVB-S2)...
[ 13.048096] tunercnt 6 name bcmdvb-6 adapter6
[ 13.052804] DVB: registering new adapter (bcmdvb-7)
[ 13.158876] (NULL device *): DVB: registering adapter 7 frontend 7 (BCM7252S DVB-S2)...
[ 13.166903] tunercnt 7 name bcmdvb-7 adapter7
[ 13.171581] DVB: registering new adapter (bcmdvb-8)
[ 13.182056] (NULL device *): DVB: registering adapter 8 frontend 8 (FTT9760 DVB-C/T/T2)...
[ 13.194427] tunercnt 8 name bcmdvb-8 adapter8
[ 13.204609] DVB: registering new adapter (bcmdvb-9)
[ 13.221872] DVB: registering new adapter (bcmdvb-10)
[ 13.232110] >>>vtuner0: register
[ 13.237498] DVB: registering new adapter (bcmdvb-11)
[ 13.249065] DVB: registering new adapter (bcmdvb-12)
[ 13.259617] DVB: registering new adapter (bcmdvb-13)
[ 13.273461] DVB: registering new adapter (bcmdvb-14)
[ 13.294590] Registering device 'sci', major '238'
[ 13.301261] Version of smartcard driver: [1.0.0]
[ 13.464737] @@^!^@@
[ 13.544072] vmap allocation for size 10301440 failed: use vmalloc=<size> to increase size.
[ 13.552390] vmalloc: allocation failure: 10296543 bytes
[ 13.557712] modprobe: page allocation failure: order:0, mode:0xd0
[ 13.563829] CPU: 0 PID: 1137 Comm: modprobe Tainted: G O 3.14.28 #1
[ 13.571149] [<c0015ff8>] (unwind_backtrace) from [<c0011e9c>] (show_stack+0x10/0x14)
[ 13.578920] [<c0011e9c>] (show_stack) from [<c0651efc>] (dump_stack+0x6c/0x7c)
[ 13.586297] [<c0651efc>] (dump_stack) from [<c00923cc>] (warn_alloc_failed+0xc8/0x10c)
[ 13.594241] [<c00923cc>] (warn_alloc_failed) from [<c00bd074>] (__vmalloc_node_range+0xa8/0xb4)
[ 13.603077] [<c00bd074>] (__vmalloc_node_range) from [<c0012cf8>] (module_alloc+0x40/0x48)
[ 13.611403] [<c0012cf8>] (module_alloc) from [<c0079250>] (module_alloc_update_bounds+0xc/0x5c)
[ 13.620126] [<c0079250>] (module_alloc_update_bounds) from [<c0079ae8>] (load_module+0x838/0x22c4)
[ 13.629224] [<c0079ae8>] (load_module) from [<c007b724>] (SyS_finit_module+0x94/0xcc)
[ 13.637077] [<c007b724>] (SyS_finit_module) from [<c000efa0>] (ret_fast_syscall+0x0/0x30)
[ 13.645375] Mem-info:
[ 13.647658] Normal per-cpu:
[ 13.650496] CPU 0: hi: 90, btch: 15 usd: 46
[ 13.655296] CPU 1: hi: 90, btch: 15 usd: 66
[ 13.660099] HighMem per-cpu:
[ 13.663063] CPU 0: hi: 0, btch: 1 usd: 0
[ 13.667870] CPU 1: hi: 0, btch: 1 usd: 0
[ 13.672707] active_anon:213 inactive_anon:0 isolated_anon:0
[ 13.672707] active_file:3875 inactive_file:1359 isolated_file:0
[ 13.672707] unevictable:0 dirty:18 writeback:0 unstable:0
[ 13.672707] free:228812 slab_reclaimable:569 slab_unreclaimable:1726
[ 13.672707] mapped:385 shmem:1 pagetables:30 bounce:0
[ 13.672707] free_cma:191899
[ 13.704212] Normal free:161740kB min:1940kB low:2424kB high:2908kB active_anon:392kB inactive_anon:0kB active_file:15500kB inactive_file:5432kB unevictable:0kB isolated(
anon):0kB isolated(file):0kB present:262144kB managed:236048kB mlocked:0kB dirty:72kB writeback:0kB mapped:1540kB shmem:4kB slab_reclaimable:2276kB slab_unreclaimable:6904k
B kernel_stack:736kB pagetables:120kB unstable:0kB bounce:0kB free_cma:14088kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 13.746088] lowmem_reserve[]: 0 14272 14272
[ 13.750383] HighMem free:753520kB min:512kB low:4268kB high:8024kB active_anon:424kB inactive_anon:0kB active_file:0kB inactive_file:4kB unevictable:0kB isolated(anon):0
kB isolated(file):0kB present:1835008kB managed:1826816kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:
0kB pagetables:0kB unstable:0kB bounce:0kB free_cma:753520kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 13.790564] lowmem_reserve[]: 0 0 0
[ 13.794287] Normal: 116*4kB (EM) 35*8kB (UEMC) 13*16kB (EM) 3*32kB (EM) 3*64kB (UM) 2*128kB (EM) 2*256kB (UC) 4*512kB (UEMC) 4*1024kB (UEMC) 1*2048kB (U) 37*4096kB (MRC)
= 161752kB
[ 13.810832] HighMem: 1*4kB (C) 1*8kB (C) 0*16kB 1*32kB (C) 0*64kB 0*128kB 3*256kB (C) 2*512kB (C) 2*1024kB (C) 2*2048kB (C) 182*4096kB (C) = 753452kB
[ 13.824637] 5234 total pagecache pages
[ 13.828400] 0 pages in swap cache
[ 13.831760] Swap cache stats: add 0, delete 0, find 0/0
[ 13.836999] Free swap = 0kB
[ 13.839929] Total swap = 0kB
[ 13.854761] 524288 pages of RAM
[ 13.857929] 228992 free pages
[ 13.861039] 8572 reserved pages
[ 13.864202] 460800 cma reserved pages
[ 13.868032] 1304 slab pages
[ 13.870836] 2321 pages shared
[ 13.873810] 0 pages swap cached
[ 14.010069] EXT4-fs (mmcblk0p4): re-mounted. Opts: data=ordered
[ 14.173663] WARNING: You are using an experimental version of the media stack.
[ 14.173663] As the driver is backported to an older kernel, it doesn't offer
[ 14.173663] enough quality for its usage in production.
[ 14.173663] Use it with care.
[ 14.173663] Latest git patches (needed if you report a bug to
[email protected]):
[ 14.173663] 8ed8bba70b4355b1ba029b151ade84475dd12991 media: imx274: remove non-indexed pointers from mode_table
[ 14.173663] 4eb7846d3ead1c2f461811e41e63462016e19ae7 media: imx274: rename and reorder register address definitions
[ 14.173663] f067ddad003b67be8acb7fd739172dcfb4817a2a media: imx274: remove unused data from struct imx274_frmfmt
[ 14.241187] LED trigger rc-feedback failed to register (-17)
[ 14.246876] WARNING: You are using an experimental version of the media stack.
[ 14.246876] As the driver is backported to an older kernel, it doesn't offer
[ 14.246876] enough quality for its usage in production.
[ 14.246876] Use it with care.
[ 14.246876] Latest git patches (needed if you report a bug to
[email protected]):
[ 14.246876] 8ed8bba70b4355b1ba029b151ade84475dd12991 media: imx274: remove non-indexed pointers from mode_table
[ 14.246876] 4eb7846d3ead1c2f461811e41e63462016e19ae7 media: imx274: rename and reorder register address definitions
[ 14.246876] f067ddad003b67be8acb7fd739172dcfb4817a2a media: imx274: remove unused data from struct imx274_frmfmt
[ 14.325392] dvb-usb: found a 'Microsoft Xbox One Digital TV Tuner' in cold state, will try to load a firmware
[ 14.352355] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[ 14.560974] dib0700: firmware started successfully.
[ 15.067121] dvb-usb: found a 'Microsoft Xbox One Digital TV Tuner' in warm state.
[ 15.075170] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 15.090496] dvb-usb: Microsoft Xbox One Digital TV Tuner error while loading driver (-23)
[ 15.102205] usbcore: registered new interface driver dvb_usb_dib0700
[ 16.639933] f0b00000.etherne:01: Broadcom BCM7439 (2) PHY revision: 0x10, patch: 1
[ 16.651051] f0b00000.ethernet: configuring instance for internal PHY
[ 16.657468] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.654013] libphy: f0b00000.etherne:01 - Link is Down
[ 20.437671] libphy: f0b00000.etherne:01 - Link is Up - 1000/Full
[ 20.443752] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 39.488636] UDF-fs: warning (device mmcblk0p1): udf_fill_super: No partition found (2)
[ 39.556319] UDF-fs: warning (device mmcblk0p1): udf_fill_super: No partition found (2)
[ 39.585307] UDF-fs: warning (device mmcblk0p3): udf_fill_super: No partition found (2)
[ 39.646319] UDF-fs: warning (device mmcblk0p3): udf_fill_super: No partition found (2)
[ 39.686804] UDF-fs: warning (device mtdblock2): udf_fill_super: No partition found (2)
[ 39.697887] isofs_fill_super: bread failed, dev=mtdblock2, iso_blknum=32, block=64
[ 39.731693] isofs_fill_super: bread failed, dev=mtdblock2, iso_blknum=32, block=64
[ 39.739899] UDF-fs: warning (device mtdblock2): udf_fill_super: No partition found (2)
[ 46.752504] no vt opened...
[ 46.755402] set source 8 bf852ae8 0.
[ 84.862898] - HD_VideoClip out -
[ 86.637402] UDF-fs: warning (device mmcblk0p1): udf_fill_super: No partition found (2)
[ 86.708856] UDF-fs: warning (device mmcblk0p1): udf_fill_super: No partition found (2)
[ 86.737951] UDF-fs: warning (device mmcblk0p3): udf_fill_super: No partition found (2)
[ 86.800534] UDF-fs: warning (device mmcblk0p3): udf_fill_super: No partition found (2)
[ 86.841027] UDF-fs: warning (device mtdblock2): udf_fill_super: No partition found (2)
[ 86.852063] isofs_fill_super: bread failed, dev=mtdblock2, iso_blknum=32, block=64
[ 86.886334] isofs_fill_super: bread failed, dev=mtdblock2, iso_blknum=32, block=64
[ 86.894499] UDF-fs: warning (device mtdblock2): udf_fill_super: No partition found (2)
[ 92.485645] no vt opened...
[ 92.488481] set source 8 bf852ae8 0.
