- 28 Ene 2008
- 37
Hola compañeros llevo ya dos semanas configurando newcs para que me lea la card de jsc sport via 4 para compartirla con cccam y poder verla en mi casa del pueblo pero no tengo narices a que lea la card no se donde puede estar el fallo, cuando ejecuto newcs.xml no lee la card la tengo que sacar y volver a entrar para que me de una lectura aun asi no me funciona por favor maestros una ayudita
/camd/OpenXCAS/newcs/newcs -c /camd/Open
XCAS/newcs/newcs.xml
Reading Config file from /camd/OpenXCAS/newcs/newcs.xml
****** INTERNAL enabled
TCP-log password is disabled!
level: internal
type: all
output: console, tcp
logger config: level 16777215 type 255 output 5
Console log options: level 16777215 type 255
tcp port: 1001
[ 14:02:14 ] logger: bind error: error! 125: Address already in use
logger: tcp port open failed, tcp log disabled
[ 14:02:14 ] [ Box detect ] Box type 9
[ 14:02:14 ] [ Config ] Value in <boxkey> for device 0 (upper) is INVALID, skipping...
[ 14:02:14 ] [ Config ] Value in <rsa> for device 0 (upper) is INVALID, skipping...
[ 14:02:14 ] [ Config ] /dev/scard ECM priority: hard
[ 14:02:14 ] [ Config ] No SIDFILTER is configured, disabling SidOverride for device 0 (upper)!
[ 14:02:14 ] [ Newcamd ] Server name : local
[ 14:02:14 ] [ Newcamd ] Des key : 0102030405060708091011121314
[ 14:02:14 ] [ Newcamd ] User 2: dummy, Pass: dummy, Host 127.0.0.1, Port: 12000, Au: Off, Spider allowed: No, Sidoverride: No, reader control: No, level: 0
[ 14:02:14 ] [ EMM Cache ] Initialising Cache with 10 entries
[ 14:02:14 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 1283
[ 14:02:15 ] Calibrating delay loops
[ 14:02:15 ] usleep(5) takes: 0 s 12 us
[ 14:02:15 ] usleep(10) takes: 0 s 16 us
[ 14:02:15 ] usleep(100) takes: 0 s 105 us
[ 14:02:15 ] usleep(500) takes: 0 s 506 us
[ 14:02:15 ] [ Loader ] Reader type 11 on node /dev/scard
[ 14:02:15 ] [ azbox ] Opening device /dev/scard
[ 14:02:15 ] [ azbox ] Could not get device /dev/scard
[ 14:02:16 ] [ azbox ] Could not get device /dev/scard
[ 14:02:17 ] [ azbox ] Could not get device /dev/scard
[ 14:02:18 ] [ azbox ] Could not get device /dev/scard
[ 14:02:19 ] [ azbox ] Could not get device /dev/scard
[ 14:02:20 ] [ azbox ] Could not get device /dev/scard
[ 14:02:21 ] [ azbox ] Could not get device /dev/scard
[ 14:02:22 ] [ azbox ] Could not get device /dev/scard
[ 14:02:23 ] [ azbox ] Could not get device /dev/scard
[ 14:02:24 ] [ azbox ] Could not get device /dev/scard
[ 14:02:25 ] [ Loader ] Reset failed ...
[ 14:02:25 ] [ Loader ] Starting Newcamd Server on port 20000
[ 14:02:25 ] [ NewCS ] Ready to GO!
AZBox[~]$ [ 14:02:25 ] [ Card queue /dev/scard ] Starting...
[ 14:02:25 ] bind: error! 125: Address already in use
[ 14:02:25 ] [ Newcamd ] Stopping port 20000
[ 14:02:25 ] [ Loader ] Reader type 11 on node /dev/scard
[ 14:02:25 ] [ azbox ] Opening device /dev/scard
[ 14:02:25 ] [ azbox ] Could not get device /dev/scard
[ 14:02:26 ] [ azbox ] Could not get device /dev/scard
[ 14:02:27 ] [ azbox ] Could not get device /dev/scard
[ 14:02:28 ] [ azbox ] Could not get device /dev/scard
[ 14:02:29 ] [ azbox ] Could not get device /dev/scard
[ 14:02:30 ] [ azbox ] Could not get device /dev/scard
[ 14:02:31 ] [ azbox ] Could not get device /dev/scard
[ 14:02:32 ] [ azbox ] Could not get device /dev/scard
[ 14:02:33 ] [ azbox ] Could not get device /dev/scard
[ 14:02:34 ] [ azbox ] Could not get device /dev/scard
[ 14:02:35 ] [ Loader ] Reset failed ...
[ 14:02:35 ] [ Loader ] Reader type 11 on node /dev/scard
[ 14:02:35 ] [ azbox ] Opening device /dev/scard
[ 14:02:35 ] [ azbox ] Could not get device /dev/scard
[ 14:02:36 ] [ azbox ] Could not get device /dev/scard
[ 14:02:37 ] [ azbox ] Could not get device /dev/scard
[ 14:02:38 ] [ azbox ] Could not get device /dev/scard
[ 14:02:39 ] [ azbox ] Could not get device /dev/scard
[ 14:02:40 ] [ azbox ] Could not get device /dev/scard
[ 14:02:41 ] [ azbox ] Could not get device /dev/scard
[ 14:02:42 ] [ azbox ] Could not get device /dev/scard
[ 14:02:43 ] [ azbox ] Could not get device /dev/scard
[ 14:02:44 ] [ azbox ] Could not get device /dev/scard
[ 14:02:45 ] [ Loader ] Reset failed ...
[ 14:02:45 ] [ Loader ] Reader type 11 on node /dev/scard
[ 14:02:45 ] [ azbox ] Opening device /dev/scard
SCARD_IOC_CHECKCARD: ATR len=12
[ 14:02:47 ] ATR: xxxxxxxxxxxxxxxxxxxxxxxxxx
[ 14:02:47 ] [ CardMan ] Atr header is 3F 77 [INVERSE]
[ 14:02:47 ] [ ATR ] T=0 1etu=31.00us Guardtime:12etu WWT:115200etu
[ 14:02:47 ] [ ATR ] Fi 1 (372) Di 8 (12)
[ 14:02:47 ] [ ATR ] Historical bytes: [C2] z B [02] h [90] [00]
[ 14:02:47 ] [ ATR ] freq 1000000.000 sciFreq 3580000.000
[ 14:02:47 ] [ azbox ] Set card type to 0x500 (mode 2)
[ 14:02:47 ] [ Loader ] Init Viaccess card
[ 14:02:47 ] [ Viaccess ] Sending to Card: CAA4000000
[ 14:02:47 ] [ azbox ] Delay is 8us
[ 14:02:47 ] write: CA A4 00 00 00
[ 14:02:47 ] [ azbox ] Timeout is 997518us
[ 14:02:47 ] read: 90
[ 14:02:47 ] read: 00
[ 14:02:47 ] [ Viaccess ] Status Word from Card: 9000
[ 14:02:47 ] [ Viaccess ] Sending to Card: CAACA40000
[ 14:02:47 ] write: CA AC A4 00 00
[ 14:02:48 ] read: 90
[ 14:02:48 ] [ azbox ] Timeout is 997518us
[ 14:02:48 ] read: 00
[ 14:02:48 ] [ Viaccess ] Status Word from Card: 9000
[ 14:02:48 ] [ Viaccess ] Sending to Card: CAB8000007
[ 14:02:48 ] [ azbox ] Delay is 8us
[ 14:02:48 ] write: CA B8 00 00 07
[ 14:02:48 ] read: B8
[ 14:02:48 ] read: A4 05 00 C0 24 34 BE
[ 14:02:48 ] read: 08
[ 14:02:48 ] [ Viaccess ] Status Word from Card: 9008
[ 14:02:48 ] [ Keyman ] Adding key C02434BE type 0 on Provider 000000 for caid 0500 ID=0
[ 14:02:48 ] [ Viaccess ] Sending to Card: CAA4000000
[ 14:02:48 ] write: CA A4 00 00 00
[ 14:02:48 ] [ Viaccess ] Sending to Card: CAC000001A
[ 14:02:48 ] write: CA C0 00 00 1A
[ 14:02:48 ] read: C0
[ 14:02:48 ] read: FF F9 20 40 00 00 53 DD 62 F5 00 01 02 FF FF FF
[ 14:02:48 ] read: FF FF FF 09 0A FF FF FF FF 0F
[ 14:02:48 ] [ Viaccess ] Sending to Card: CAACA50000
[ 14:02:48 ] write: CA AC A5 00 00
[ 14:02:48 ] [ Viaccess ] Sending to Card: CAB8000006
[ 14:02:48 ] write: CA B8 00 00 06
[ 14:02:48 ] read: A5 04 C0 24 34 BE
[ 14:02:48 ] [ Keyman ] Adding key C02434BE type 1 on Provider FFF920 for caid 0500 ID=0
[ 14:02:48 ] [ Viaccess ] Sending to Card: CAA4020000
[ 14:02:48 ] write: CA A4 02 00 00
[ 14:02:48 ] read: 04 24 08 40 00 3F 53 DD 62 F5 00 01 02 FF FF FF
[ 14:02:48 ] read: FF FF 08 09 0A 0B 0C 0D 0E 0F
[ 14:02:48 ] [ Keyman ] Adding key C02434BE type 1 on Provider 042400 for caid 0500 ID=1
[ 14:02:49 ] read: 04 24 10 40 00 3F 53 DD 62 F5 00 01 02 FF FF FF
[ 14:02:49 ] read: FF FF 08 09 0A 0B 0C 0D 0E 0F
[ 14:02:49 ] [ azbox ] Timeout is 997518us
[ 14:02:49 ] read: 90
[ 14:02:49 ] read: 00
[ 14:02:49 ] [ Viaccess ] Status Word from Card: 9000
[ 14:02:49 ] [ Viaccess ] Sending to Card: CAACA50000
[ 14:02:49 ] [ azbox ] Delay is 8us
[ 14:02:49 ] write: CA AC A5 00 00
[ 14:02:49 ] [ Viaccess ] Sending to Card: CAB8000006
[ 14:02:49 ] write: CA B8 00 00 06
[ 14:02:49 ] read: B8
[ 14:02:49 ] read: A5 04 C0 24 34 BE
[ 14:02:49 ] read: 08
[ 14:02:49 ] [ Viaccess ] Status Word from Card: 9008
[ 14:02:49 ] [ Keyman ] Adding key C02434BE type 1 on Provider 042410 for caid 0500 ID=2
[ 14:02:49 ] [ Viaccess ] Sending to Card: CAA4020000
[ 14:02:49 ] write: CA A4 02 00 00
[ 14:02:49 ] [ 0500 ] Init took: 1.653539
[ 14:02:49 ] [ Loader ] Card 0500 on port /dev/scard ready
level: internal
type: all
tcp port: 1001
