Vu+ Solo2 Problema con el MediaCenter
fadero2
13 Abr 2009
271
18
Versión de OpenSpa:
7.02.004
Desde que he instalado esta versión puedo acceder al MediaCenter pero solo al apartado de "mis videos", si intento entrar en "Mi música" o "Mis fotos" salta pantalla de crash y se reinicia.
Por si fuera el Skin he probado a instalar varios y en todos ocurre el mismo problema, tambien he probado a cambiar en el Mediacenter entre los distintos formatos, "clasico","kodi" y el problema persiste.
Características especiales:
No tiene
Se adjunta Crash-log: Si
Crash-log:
openSPA Enigma2 crash log
crashdate=jue feb 1 20:54:52 2018
compiledate=Jan 15 2018
skin=MetrixJRSD/skin.xml
sourcedate=2018-01-14
branch=master
rev=ca6a68b
component=Enigma2
stbmodel=solo2
stbmodel=dm8000
kernelcmdline=ubiroot rootflags=sync bmem=192M@64M bmem=256M@512M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs
nimsockets=NIM Socket 0:
imageversion=box_type=vusolo2
imageissue=Welcome to openSPA for %h
open demux /dev/dvb/adapter0/demux0
20:54:47.2858 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.2859 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.2860 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.2861 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.2862 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.2863 [ ] dvb/dvb.cpp:1484 DVBChannelStateChanged [eDVBResourceManager] stop release channel timer
20:54:47.2864 [ ] dvb/epgcache.cpp:2071 startChannel [eEPGCache] next update in 2 sec
20:54:47.2864 [ ] dvb/dvb.cpp:2410 getDemux [eDVBChannel] getDemux cap=01
20:54:47.2865 [ ] dvb/dvb.cpp:1098 allocateDemux [eDVBResourceManager] allocate demux cap=01
20:54:47.2866 [ ] dvb/dvb.cpp:1207 allocateDemux [eDVBResourceManager] allocating shared demux adapter=0, demux=0, source=0
20:54:47.2866 [ ] dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!!
20:54:47.2867 [ ] service/servicedvb.cpp:1203 serviceEvent [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
20:54:47.2867 < > service/servicedvb.cpp:2872 updateDecoder [eDVBServicePlay] have 1 video stream(s) (0bf5), and 1 audio stream(s) (0bf6), and the pcr pid is 1fdc, and the text pid is ffffffff
20:54:47.2868 [ ] dvb/dvb.cpp:2410 getDemux [eDVBChannel] getDemux cap=01
20:54:47.2939 [ ] service/servicedvb.cpp:3556 setAC3Delay [eDVBServicePlay] Setting audio delay: setAC3Delay, 0 + 0
20:54:47.2943 [ ] service/servicedvb.cpp:3567 setPCMDelay [eDVBServicePlay] Setting audio delay: setPCMDelay, 0 + 0
20:54:47.2945 [ ] dvb/decoder.cpp:836 setState [eTSMPEGDecoder] decoder state: play, vpid=0bf5, apid=0bf6
20:54:47.2946 < > dvb/decoder.cpp:707 startPid [eDVBPCR0] DMX_SET_PES_FILTER pid=0x1fdc ok
20:54:47.2946 < > dvb/decoder.cpp:715 startPid [eDVBPCR0] DEMUX_START ok
20:54:47.2980 < > dvb/decoder.cpp:84 startPid [eDVBAudio0] DMX_SET_PES_FILTER pid=0x0bf6 ok
20:54:47.2981 < > dvb/decoder.cpp:92 startPid [eDVBAudio0] DEMUX_START ok
20:54:47.2983 < > dvb/decoder.cpp:138 startPid [eDVBAudio0] AUDIO_SET_BYPASS bypass=1 ok
20:54:47.3039 < > dvb/decoder.cpp:191 freeze [eDVBAudio0] AUDIO_PAUSE ok
20:54:47.3061 < > dvb/decoder.cpp:146 startPid [eDVBAudio0] AUDIO_PLAY ok
20:54:47.3121 [ ] dvb/decoder.cpp:265 eDVBVideo [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
20:54:47.3122 [ ] dvb/decoder.cpp:276 eDVBVideo [eDVBVideo] demux device: /dev/dvb/adapter0/demux0
20:54:47.3155 < > dvb/decoder.cpp:356 startPid [eDVBVideo0] VIDEO_SET_STREAMTYPE 0 - ok
20:54:47.3185 < > dvb/decoder.cpp:391 startPid [eDVBVideo0] DMX_SET_PES_FILTER pid=0x0bf5 ok
20:54:47.3186 < > dvb/decoder.cpp:399 startPid [eDVBVideo0] DEMUX_START ok
20:54:47.3187 < > dvb/decoder.cpp:460 freeze [eDVBVideo0] VIDEO_FREEZE ok
20:54:47.3212 < > dvb/decoder.cpp:414 startPid [eDVBVideo0] VIDEO_PLAY ok
20:54:47.3290 < > dvb/decoder.cpp:484 setSlowMotion [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
20:54:47.3323 < > dvb/decoder.cpp:499 setFastForward [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
20:54:47.3357 < > dvb/decoder.cpp:472 unfreeze [eDVBVideo0] VIDEO_CONTINUE ok
20:54:47.3385 < > dvb/decoder.cpp:203 unfreeze [eDVBAudio0] AUDIO_CONTINUE ok
20:54:47.3439 [ ] dvb/teletext.cpp:222 eDVBTeletextParser [eDVBTeletextParser] Starting!
20:54:47.3440 [ ] dvb/teletext.cpp:645 setPageAndMagazine [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
20:54:47.3441 [!W!] dvb/demux.cpp:359 eDVBPESReader [eDVBPESReader] Created. Opening demux
20:54:47.3441 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.3442 [ ] dvb/teletext.cpp:230 eDVBTeletextParser [eDVBTeletextParser] created teletext subtitle PES reader!
20:54:47.3443 [!W!] dvb/demux.cpp:359 eDVBPESReader [eDVBPESReader] Created. Opening demux
20:54:47.3444 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.3445 [ ] dvb/teletext.cpp:463 start [eDVBTeletextParser] starting PES reader on pid=ffffffff
20:54:47.3460 [ ] service/servicedvb.cpp:1728 timeshift [eDVBServicePlay] timeshift
20:54:47.3468 [ ] service/servicedvb.cpp:1728 timeshift [eDVBServicePlay] timeshift
20:54:47.3475 [ ] service/servicedvb.cpp:1728 timeshift [eDVBServicePlay] timeshift
20:54:47.3491 { E } Components/Pixmap.py:139 setPixmapNum setPixmapNum(0) failed! defined pixmaps: []
20:54:47.3503 [ ] service/servicedvb.cpp:1728 timeshift [eDVBServicePlay] timeshift
20:54:47.3621 [ ] dvb/cahandler.cpp:267 registerService [eDVBCAService] new service 1:0:1:6FF0:42A:1:C00000:0:0:0:
20:54:47.3622 [ ] dvb/cahandler.cpp:285 registerService [eDVBCAService] add demux 0 to slot 0 service 1:0:1:6FF0:42A:1:C00000:0:0:0:
20:54:47.3626 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.3628 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:54:47.3909 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.3910 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
20:54:47.3960 { E } Tools/Notifications.py:36 RemovePopup RemovePopup, id = ZapError
20:54:47.3962 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.3963 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:54:47.5997 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
20:54:47.6026 { } Screens/InfoBarGenerics.py:200 actionA KEY: 352 0 KEY_OK OK
20:54:47.6031 { } Components/ActionMap.py:46 action [ActionMap] WizardActions ok
20:54:47.6238 { } skin.py:1475 readSkin [SKIN] processing screen spzSubMenu:
20:54:47.6362 { W } skin.py:419 applyAll [SKIN] Attribute "valign" with value "bottom" in object of type "eListbox" is not implemented
20:54:47.6409 { } Screens/Screen.py:151 show [SCREENNAME] spzSubMenu
20:54:47.6538 [ ] dvb/pmt.cpp:207 PATready [eDVBServicePMTHandler] PATready
20:54:47.6539 [ ] dvb/pmt.cpp:218 PATready [eDVBServicePMTHandler] PAT TSID: 0x042a (1066)
20:54:47.6540 [ ] dvb/pmt.cpp:247 PATready [eDVBServicePMTHandler] use pmtpid 013c for service_id 6ff0
20:54:47.6541 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.6543 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=316
20:54:47.6549 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.6551 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:54:47.6589 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.6591 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=311
20:54:47.6597 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:47.6599 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=17
20:54:47.6842 [ ] dvb/frontend.cpp:2264 tuneLoopInt [SEC] set dynamic current limiting
20:54:47.8305 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 160 1
20:54:47.8336 { } Screens/InfoBarGenerics.py:200 actionA KEY: 352 1 KEY_OK OK
20:54:48.0044 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.0046 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=312
20:54:48.0077 [ ] service/servicedvb.cpp:1203 serviceEvent [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
20:54:48.0102 < > service/servicedvb.cpp:2872 updateDecoder [eDVBServicePlay] have 1 video stream(s) (0bf5), and 1 audio stream(s) (0bf6), and the pcr pid is 1fdc, and the text pid is ffffffff
20:54:48.0108 [ ] service/servicedvb.cpp:3556 setAC3Delay [eDVBServicePlay] Setting audio delay: setAC3Delay, 0 + 0
20:54:48.0113 [ ] service/servicedvb.cpp:3567 setPCMDelay [eDVBServicePlay] Setting audio delay: setPCMDelay, 0 + 0
20:54:48.0114 [ ] dvb/decoder.cpp:836 setState [eTSMPEGDecoder] decoder state: play, vpid=0bf5, apid=0bf6
20:54:48.0115 < > dvb/decoder.cpp:484 setSlowMotion [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
20:54:48.0145 < > dvb/decoder.cpp:499 setFastForward [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
20:54:48.0178 < > dvb/decoder.cpp:472 unfreeze [eDVBVideo0] VIDEO_CONTINUE ok
20:54:48.0206 < > dvb/decoder.cpp:203 unfreeze [eDVBAudio0] AUDIO_CONTINUE ok
20:54:48.0395 [ ] dvb_ci/dvbci.cpp:1030 gotPMT [eDVBCIInterfaces] gotPMT
20:54:48.0396 [ ] dvb/cahandler.cpp:624 buildCAPMT [eDVBCAService] don't build/send the same CA PMT twice
20:54:48.0398 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.0399 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=316
20:54:48.1075 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.1076 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=314
20:54:48.2827 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.2829 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=315
20:54:48.2844 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.2846 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=316
20:54:48.3609 [ ] service/servicedvb.cpp:1728 timeshift [eDVBServicePlay] timeshift
20:54:48.3635 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
20:54:48.3668 { } Screens/InfoBarGenerics.py:200 actionA KEY: 103 0 KEY_UP UP
20:54:48.3673 { } Components/ActionMap.py:46 action [ActionMap] WizardActions up
20:54:48.3836 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.3841 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=317
20:54:48.4885 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
20:54:48.4922 { } Screens/InfoBarGenerics.py:200 actionA KEY: 103 1 KEY_UP UP
20:54:48.6828 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.6829 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=319
20:54:48.6848 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.6849 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=320
20:54:48.7097 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
20:54:48.7131 { } Screens/InfoBarGenerics.py:200 actionA KEY: 103 0 KEY_UP UP
20:54:48.7137 { } Components/ActionMap.py:46 action [ActionMap] WizardActions up
20:54:48.7598 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.7599 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=321
20:54:48.8082 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.8083 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=322
20:54:48.8345 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
20:54:48.8379 { } Screens/InfoBarGenerics.py:200 actionA KEY: 103 1 KEY_UP UP
20:54:48.8682 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:48.8683 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
20:54:49.1121 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
20:54:49.1122 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=323
20:54:49.2103 [ ] dvb/pmt.cpp:950 SDTScanEvent [eDVBServicePMTHandler] sdt update done!
20:54:49.2152 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
20:54:49.2185 { } Screens/InfoBarGenerics.py:200 actionA KEY: 352 0 KEY_OK OK
20:54:49.2190 { } Components/ActionMap.py:46 action [ActionMap] WizardActions ok
20:54:49.2362 [ ] dvb/cahandler.cpp:333 unregisterService [eDVBCAService] free slot 0 demux 0 for service 1:0:1:6FF0:42A:1:C00000:0:0:0:
20:54:49.2365 [ ] dvb/cahandler.cpp:497 ~eDVBCAService [eDVBCAService] free service 1:0:1:6FF0:42A:1:C00000:0:0:0:
20:54:49.2479 [ ] service/servicedvb.cpp:1728 timeshift [eDVBServicePlay] timeshift
20:54:49.2486 [ ] service/servicedvb.cpp:1728 timeshift [eDVBServicePlay] timeshift
20:54:49.2500 [ ] dvb/decoder.cpp:836 setState [eTSMPEGDecoder] decoder state: play, vpid=ffffffff, apid=ffffffff
20:54:49.2501 < > dvb/decoder.cpp:728 stop [eDVBPCR0] DEMUX_STOP ok
20:54:49.2502 [ ] dvb/decoder.cpp:739 ~eDVBPCR [eDVBPCR0] destroy
20:54:49.2503 < > dvb/decoder.cpp:427 stop [eDVBVideo0] DEMUX_STOP ok
20:54:49.2513 < > dvb/decoder.cpp:436 stop [eDVBVideo0] VIDEO_STOP ok
20:54:49.2539 [ ] dvb/decoder.cpp:528 ~eDVBVideo [eDVBVideo0] destroy
20:54:49.2540 < > dvb/decoder.cpp:159 stop [eDVBAudio0] AUDIO_STOP ok
20:54:49.2896 < > dvb/decoder.cpp:167 stop [eDVBAudio0] DEMUX_STOP ok
20:54:49.2897 < > dvb/decoder.cpp:203 unfreeze [eDVBAudio0] AUDIO_CONTINUE
20:54:49.2955 [ ] dvb/epgcache.cpp:1594 startEPG [eEPGCache] start caching events(1517514889)
20:54:49.2957 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=211
ok20:54:49.2962 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=561
20:54:49.2962 [ ] dvb/decoder.cpp:247 ~eDVBAudio [eDVBAudio0] destroy
20:54:49.2971 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=3842
20:54:49.2977 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=3003
20:54:49.2984 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
20:54:49.2990 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
20:54:49.3001 [ ] dvb/dvb.cpp:1490 DVBChannelStateChanged [eDVBResourceManager] start release channel timer
20:54:49.3009 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
20:54:49.3103 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=5000
20:54:49.3116 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=5000
20:54:49.3126 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=57
20:54:52.7496 [ ] gdi/grc.cpp:193 thread [gRC] main thread is non-idle! display spinner!
20:54:52.8192 { D } Traceback (most recent call last):
20:54:52.8194 { D } File "/usr/lib/enigma2/python/Components/ActionMap.py", line 48, in action
20:54:52.8317 { D } File "tmp/work/mips32el-oe-linux/enigma2-plugin-extensions-spzmenu/1.0+gitAUTOINC+50a0634d62-r0/git/spzmenu/plugin/plugin.py", line 901, in plugin.plugin.spazeTeamMenu.n_ok (/mnt/storage/jenkinsWS/OpenSpa/openspa-7.2/builds/openspa/vusolo2/tmp/work/mips32el-oe-linux/enigma2-plugin-extensions-spzmenu/1.0+gitAUTOINC+50a0634d62-r0/git/spzmenu/plugin/plugin.c:22979)
20:54:52.8437 { D } continue
20:54:52.8439 { D } File "tmp/work/mips32el-oe-linux/enigma2-plugin-extensions-spzmenu/1.0+gitAUTOINC+50a0634d62-r0/git/spzmenu/plugin/plugin.py", line 932, in plugin.plugin.spazeTeamMenu.devSub (/mnt/storage/jenkinsWS/OpenSpa/openspa-7.2/builds/openspa/vusolo2/tmp/work/mips32el-oe-linux/enigma2-plugin-extensions-spzmenu/1.0+gitAUTOINC+50a0634d62-r0/git/spzmenu/plugin/plugin.c:23736)
20:54:52.8460 { D } for line in tmpfile:
20:54:52.8463 { D } File "tmp/work/mips32el-oe-linux/enigma2-plugin-extensions-spzmenu/1.0+gitAUTOINC+50a0634d62-r0/git/spzmenu/plugin/plugin.py", line 2791, in plugin.plugin.runSpaActions (/mnt/storage/jenkinsWS/OpenSpa/openspa-7.2/builds/openspa/vusolo2/tmp/work/mips32el-oe-linux/enigma2-plugin-extensions-spzmenu/1.0+gitAUTOINC+50a0634d62-r0/git/spzmenu/plugin/plugin.c:74648)
20:54:52.8596 { D }
20:54:52.8598 { D } File "/usr/lib/enigma2/python/mytest.py", line 362, in open
20:54:52.8618 { D } raise RuntimeError("modal open are allowed only from a screen which is modal!")
20:54:52.8622 { D } RuntimeError: modal open are allowed only from a screen which is modal!
20:54:52.8626 [ E ] python/python.cpp:209 call [ePyObject] (PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x61876850>>,('WizardActions', 'ok')) failed)
dmesg
<4>[VID]: VIDEO_SET_STREAMTYPE 0
<4>[VID]: VIDEO_SELECT_SOURCE 1 0
<4>[VID]: VIDEO_PLAY 1 2 0
<4>[VID]: VIDEO_CONTINUE 1 1
<4>[VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[VID]: VIDEO_STOP 0 1
<4>[VID]: VIDEO_SELECT_SOURCE 0 0
<3>[LCD]: unknown cmd 0x1015
<3>UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
<4>[AUD]: HDMI Max Audio PCM Channels=8
<4>[AUD]: AUDIO_SET_MUTE 0
<4>[AUD]: AUDIO_SET_MIXER -864911888
<4>[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>FE tune
<4>[AUD]: AUDIO_SELECT_SOURCE 0
<4>[AUD]: AUDIO_SET_BYPASS_MODE 1
<4>[AUD]: downmix 1 state : 0
<4>[AUD]: AUDIO_PAUSE 0
<4>[AUD]: AUDIO_PLAY 0 decoder start : 0
<4>[VID]: VIDEO_GET_SIZE src w: 1280 h:720 display w:1280 h:720
<4>[VID]: VIDEO_GET_SIZE aspect: 1 3
<4>[VID]: VIDEO_FREEZE 0 0
<4>[VID]: VIDEO_PLAY 0 2 2
<4>[VID]: VIDEO_SLOWMOTION 0 1
<4>[VID]: VIDEO_FAST_FORWARD 0 1
<4>[VID]: VIDEO_CONTINUE 0 1
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcfec2a80
<4>[AUD]: Mute : 0
<4>[AUD]: AUDIO_CHANNEL_SELECT 0
<4>[AUD]: Mute : 0
<4>[VID]: VIDEO_STOP 1 1
<4>[AUD]: AUDIO_STOP 0
<4>[AUD]: AUDIO_CONTINUE 0 0 aph=0x0
<4>[AUD]: AUDIO_CONTINUE aph=0 0 0
<4>[AUD]: AUDIO_SET_MIXER -864625168
<4>FE tune
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcc560480
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>FE tune
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcfec1880
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
<4>FE tune
<4>[AUD]: AUDIO_CONTINUE 0 1 aph=0xcf4d9500
<4>[AUD]: Mute : 0
<4>[AUD]: Mute : 0
casej55
24 Dic 2014
105
13
Hola fadero2, tengo el mismo problema, has conseguido solucionarlo.
16.771
Algo tenéis que provoca esa incompatibilidad, pero es imposible saberlo con ese crashlog. Yo he probado en varios decos y no consigo que me pete.
26 Ago 2009
8.533
2.650
Que manias de poner los crashlogs sin las etiquetas spoiler para que no se haga el hilo eterno.
