Plantilla:VU+Ultimo4K
Usando tapatalk (tablet/movil) no se ven estos datos y la firma que tengas tampoco sale.
Versión de OpenSpa: 7.3.009
Descripción del fallo: Al hacer streaming, crashea enigma2
Características especiales: Ninguna
Se adjunta Crash-log: Si
Al hacer streaming mediante enigma2, al cabo de un tiempo, crashea. Probe a hacer el serviceapp, pero sigue igual.
openSPA Enigma2 crash log
crashdate=sáb jun 15 20:43:16 2019
compiledate=Jun 1 2019
skin=MetrixJRSD/skin.xml
sourcedate=2019-05-30
branch=master
rev=ccbad05
component=enigma2, signal
stbmodel=ultimo4k
stbmodel=dm8000
kernelcmdline=root=/dev/mmcblk0p4 rootfstype=ext4 rootflags=data=journal rootwait rw coherent_pool=2M vmalloc=622m bmem=630m@394m bmem=383m@1665m bmem=443m@2625m
nimsockets=NIM Socket 0:
imageversion=box_type=vuultimo4k
imageissue=Welcome to openSPA for %h
//127.0.0.1:8554/stream=21
Server: enigma2/0.1
Content-Length: 184
m=video 0 RTP/AVP 33
c=IN IP4 0.0.0.0
a=control:stream=22
a=fmtp:33 ver=1.0;src=1;tuner=1,0,1,0,10906,v,8psk,,0.35,dvbs2,22000,23;pids=0,86,87,161,1025,8187
b=AS:5000
a=sendonly
20:43:15.9720 [ ] dvb/rtspstreamserver.cpp:857 http_response wrote successfully 391
20:43:15.9720 [ ] dvb/frontend.cpp:2418 tuneLoopInt [SEC] invalidate current switch params
20:43:15.9721 [ ] dvb/rtspstreamserver.cpp:1013 notifier rtsp read 95
PLAY rtsp://127.0.0.1:8554/stream=21?addpids=1,16,17 RTSP/1.0
CSeq: 4
Session: 1819100762
20:43:15.9722 [ ] dvb/rtspstreamserver.cpp:1034 notifier URL = rtsp://127.0.0.1:8554/stream=21?addpids=1,16,17
20:43:15.9722 [ ] dvb/rtspstreamserver.cpp:1035 notifier method = /PLAY /
20:43:15.9722 [ ] dvb/rtspstreamserver.cpp:356 satip2enigma Start satip2enigma
20:43:15.9722 [ ] dvb/rtspstreamserver.cpp:363 satip2enigma Is URL rtsp://127.0.0.1:8554/stream=21?addpids=1,16,17 valid? 1 fe= src= freq= msys= pol= sid= addpids=1,16,17 delpids= pids=
20:43:15.9723 [ ] dvb/rtspstreamserver.cpp:401 satip2enigma initial values, freq 0, pol -1, sys 0, old freq = 10906000, tune 0
20:43:15.9723 [ ] dvb/rtspstreamserver.cpp:307 process_pids process_pids: operation 1, pid_str 1,16,17 (len pids: 6)
20:43:15.9723 [ ] dvb/rtspstreamserver.cpp:670 update_pids update pids called: 7 pids in the queue
20:43:15.9723 [ ] dvb/rtspstreamserver.cpp:670 update_pids update pids called: 8 pids in the queue
20:43:15.9724 [ ] dvb/rtspstreamserver.cpp:670 update_pids update pids called: 9 pids in the queue
20:43:15.9724 [ ] dvb/rtspstreamserver.cpp:580 update_service_list Service Ref 1:0:64:7538:426:1:C00000:0:0:0: still does not have cached pids, adding
20:43:15.9724 [ ] dvb/rtspstreamserver.cpp:600 update_service_list Found SR 1:0:19:7532:426:1:C00000:0:0:0: for pid 86
20:43:15.9725 [ ] dvb/rtspstreamserver.cpp:600 update_service_list Found SR 1:0:19:7532:426:1:C00000:0:0:0: for pid 161
20:43:15.9725 [ ] dvb/rtspstreamserver.cpp:195 getOrbitalPosition LNB OP 192
20:43:15.9725 [ ] dvb/rtspstreamserver.cpp:202 getOrbitalPosition 0: orbital position 192, m_slot_mask 15, lnNum 1, old OP -1
20:43:15.9725 [ ] dvb/rtspstreamserver.cpp:205 getOrbitalPosition orbital position matched to 192
20:43:15.9725 [ ] dvb/rtspstreamserver.cpp:212 getOrbitalPosition found orbital position 192 for src 0
20:43:15.9726 [ ] dvb/rtspstreamserver.cpp:465 satip2enigma no service ref used
20:43:15.9726 [ ] dvb/rtspstreamserver.cpp:825 http_response reply to 89, mr (nil), len 158: RTSP/1.0 200 OK
Date: sáb, jun 15 18:43:15 2019 GMT
Session: 1819100762
Cseq: 4
Public: OPTIONS, DESCRIBE, SETUP, PLAY, TEARDOWN
Server: enigma2/0.1
20:43:15.9727 [ ] dvb/rtspstreamserver.cpp:857 http_response wrote successfully 158
20:43:15.9728 [ ] dvb/rtspstreamserver.cpp:1013 notifier rtsp read 108
DESCRIBE rtsp://127.0.0.1:8554/stream=21 RTSP/1.0
CSeq: 5
Session: 1819100762
Accept: application/sdp
20:43:15.9728 [ ] dvb/rtspstreamserver.cpp:1034 notifier URL = rtsp://127.0.0.1:8554/stream=21
20:43:15.9729 [ ] dvb/rtspstreamserver.cpp:1035 notifier method = /DESCRIBE /
20:43:16.0137 [!W!] dvb/frontend.cpp:1859 readFrontendData [eDVBFrontend] Slow ioctl 'FE_GET_PROPERTY(DTV_FREQUENCY)', potential driver issue, 36ms
20:43:16.0138 [ ] dvb/rtspstreamserver.cpp:920 describe_frontend describe_frontend: adapter 3 slot 3 frequency 11127685, snr: 0 -> 0, strength: 0 -> 0
20:43:16.0138 [ ] dvb/rtspstreamserver.cpp:987 describe_frontend describe_frontend => ver=1.0;src=1;tuner=1,0,1,0,10906,v,8psk,,0.35,dvbs2,22000,23;pids=0,1,16,17,86,87,161,1025,8187
20:43:16.0139 [ ] dvb/rtspstreamserver.cpp:825 http_response reply to 89, mr (nil), len 399: RTSP/1.0 200 OK
Date: sáb, jun 15 18:43:16 2019 GMT
Session: 1819100762
Cseq: 5
Content-type: application/sdp
Content-Base: rtsp://127.0.0.1:8554/stream=21
Server: enigma2/0.1
Content-Length: 192
c=IN IP4 0.0.0.0
a=control:stream=22
a=fmtp:33 ver=1.0;src=1;tuner=1,0,1,0,10906,v,8psk,,0.35,dvbs2,22000,23;pids=0,1,16,17,86,87,161,1025,8187
b=AS:5000
a=sendonly
20:43:16.0141 [ ] dvb/rtspstreamserver.cpp:857 http_response wrote successfully 399
20:43:16.0144 [ ] dvb/rtspstreamserver.cpp:1013 notifier rtsp read 108
CSeq: 6
Session: 1819100762
20:43:16.0145 [ ] dvb/rtspstreamserver.cpp:1034 notifier URL = rtsp://127.0.0.1:8554/stream=21
20:43:16.0145 [ ] dvb/rtspstreamserver.cpp:1035 notifier method = /DESCRIBE /
20:43:16.0554 [ ] dvb/rtspstreamserver.cpp:920 describe_frontend describe_frontend: adapter 3 slot 3 frequency 11127685, snr: 0 -> 0, strength: 0 -> 0
20:43:16.0555 [ ] dvb/rtspstreamserver.cpp:987 describe_frontend describe_frontend => ver=1.0;src=1;tuner=1,0,1,0,10906,v,8psk,,0.35,dvbs2,22000,23;pids=0,1,16,17,86,87,161,1025,8187
20:43:16.0555 [ ] dvb/rtspstreamserver.cpp:825 http_response reply to 89, mr (nil), len 399: RTSP/1.0 200 OK
Session: 1819100762
Cseq: 6
Server: enigma2/0.1
Content-Length: 192
c=IN IP4 0.0.0.0
a=control:stream=22
b=AS:5000
a=sendonly
20:43:16.0558 [ ] dvb/rtspstreamserver.cpp:857 http_response wrote successfully 399
20:43:16.0558 [ ] dvb/frontend.cpp:2428 tuneLoopInt [SEC] update current switch params
20:43:16.0563 [ ] dvb/frontend.cpp:2182 tuneLoopInt [SEC] tuner 3 startTuneTimeout 5000
20:43:16.0563 [ ] dvb/frontend.cpp:2175 tuneLoopInt [SEC] tuner 3 setFrontend: events enabled
20:43:16.0564 [ ] dvb/frontend.cpp:2655 setFrontend setting frontend 3 events: on
20:43:16.0564 [ ] dvb/frontend.cpp:1090 feEvent [eDVBFrontend] (3)fe event: status 0, inversion off, m_tuning 1
20:43:16.0714 [ ] dvb/frontend.cpp:2071 tuneLoopInt [eDVBFrontend] [SEC] tuner 3 sleep 500ms
20:43:16.1265 [ ] dvb/frontend.cpp:1090 feEvent [eDVBFrontend] (3)fe event: status 7, inversion off, m_tuning 2
20:43:16.2109 [ ] dvb/frontend.cpp:1090 feEvent [eDVBFrontend] (3)fe event: status 1f, inversion off, m_tuning 3
20:43:16.2109 [ ] dvb/dvb.cpp:1886 frontendStateChanged [eDVBChannel] OURSTATE: tuner 3 ok
20:43:16.2110 [ ] dvb/dvbtime.cpp:684 DVBChannelStateChanged [eDVBLocalTimerHandler] channel 0x12a2598 running
20:43:16.2110 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
20:43:16.2110 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2111 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=20
20:43:16.2116 [ ] dvb/epgcache.cpp:684 DVBChannelStateChanged [eEPGCache] channel 0x12a2598 running
20:43:16.2117 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
20:43:16.2117 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2118 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2119 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2120 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2121 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2122 [ ] dvb/epgcache.cpp:2076 startChannel [eEPGCache] next update in 2 sec
20:43:16.2122 [ ] dvb/dvb.cpp:1488 DVBChannelStateChanged [eDVBResourceManager] stop release channel timer
20:43:16.2122 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=01
20:43:16.2123 [ ] dvb/dvb.cpp:1102 allocateDemux [eDVBResourceManager] allocate demux cap=01
20:43:16.2123 [ ] dvb/dvb.cpp:1211 allocateDemux [eDVBResourceManager] allocating shared demux adapter=0, demux=2, source=3
20:43:16.2123 [ ] dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!!
20:43:16.2123 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2124 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:43:16.2128 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 6
20:43:16.2128 [ ] service/servicedvbstream.cpp:34 serviceEvent [eDVBServiceStream] tuned.. m_state 1 m_want_record 1
20:43:16.2129 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2129 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
20:43:16.2132 [ ] dvb/demux.cpp:656 eDVBRecordStreamThread [eDVBRecordStreamThread] allocated 40 buffers of 192 kB
20:43:16.2133 [ ] service/servicedvbstream.cpp:154 doRecord [eDVBServiceStream] start streaming...
20:43:16.2133 [ ] service/servicedvbstream.cpp:337 recordCachedPids [eDVBServiceStream] no cached pids found
20:43:16.2134 [ E ] service/servicedvbstream.cpp:165 doRecord [eDVBServiceStream] getting program info failed.
20:43:16.2134 [ ] dvb/rtspstreamserver.cpp:711 eventUpdate eventUpdate Tuned
20:43:16.2134 [ ] dvb/rtspstreamserver.cpp:735 eventUpdate Setting protocol 2
20:43:16.2134 [ ] dvb/rtspstreamserver.cpp:670 update_pids update pids called: 9 pids in the queue
20:43:16.2135 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0000
20:43:16.2135 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0001
20:43:16.2135 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0010
20:43:16.2135 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0011
20:43:16.2135 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0056
20:43:16.2135 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0057
20:43:16.2136 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 00a1
20:43:16.2136 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0401
20:43:16.2136 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 1ffb
20:43:16.2141 [ ] base/ioprio.cpp:91 setIoPrio [setIoPrio] realtime level 7 ok
20:43:16.2142 [ ] dvb/filepush.cpp:542 thread [eFilePushThreadRecorder] THREAD START
20:43:16.2154 [ ] dvb/rtspstreamserver.cpp:580 update_service_list Service Ref 1:0:64:7538:426:1:C00000:0:0:0: still does not have cached pids, adding
20:43:16.2154 [ ] dvb/rtspstreamserver.cpp:600 update_service_list Found SR 1:0:19:7532:426:1:C00000:0:0:0: for pid 86
20:43:16.2155 [ ] dvb/rtspstreamserver.cpp:600 update_service_list Found SR 1:0:19:7532:426:1:C00000:0:0:0: for pid 161
20:43:16.2155 [ ] dvb/rtspstreamserver.cpp:627 update_service_list New PMT Handler for SR 1:0:19:7532:426:1:C00000:0:0:0:
20:43:16.2155 [ ] dvb/dvb.cpp:1395 allocateChannel [eDVBResourceManager] use cached_channel, frontend=3
20:43:16.2155 [ ] dvb/pmt.cpp:1049 tuneExt [eDVBServicePMTHandler] allocate Channel: res 0
20:43:16.2156 [ ] dvb_ci/dvbci.cpp:904 addPMTHandler [eDVBCIInterfaces] addPMTHandler 1:0:19:7532:426:1:C00000:0:0:0:
20:43:16.2157 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=01
20:43:16.2157 [ ] dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!!
20:43:16.2157 [ ] dvb/cahandler.cpp:267 registerService [eDVBCAService] new service 1:0:19:7532:426:1:C00000:0:0:0:
20:43:16.2158 [ ] dvb/cahandler.cpp:285 registerService [eDVBCAService] add demux 2 to slot 0 service 1:0:19:7532:426:1:C00000:0:0:0:
20:43:16.2158 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2159 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:43:16.2165 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
20:43:16.2166 [ ] dvb/rtspstreamserver.cpp:641 update_service_list got demux 2 adapter 0, original demux: 2 adapter 0
20:43:16.2167 [ ] dvb/rtspstreamserver.cpp:627 update_service_list New PMT Handler for SR 1:0:64:7538:426:1:C00000:0:0:0:
20:43:16.2167 [ ] dvb/dvb.cpp:1395 allocateChannel [eDVBResourceManager] use cached_channel, frontend=3
20:43:16.2167 [ ] dvb/pmt.cpp:1049 tuneExt [eDVBServicePMTHandler] allocate Channel: res 0
20:43:16.2168 [ ] dvb_ci/dvbci.cpp:904 addPMTHandler [eDVBCIInterfaces] addPMTHandler 1:0:64:7538:426:1:C00000:0:0:0:
20:43:16.2168 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=01
20:43:16.2169 [ ] dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!!
20:43:16.2169 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2169 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:43:16.2177 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
20:43:16.2178 [ ] dvb/rtspstreamserver.cpp:641 update_service_list got demux 2 adapter 0, original demux: 2 adapter 0
20:43:16.2179 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2179 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:43:16.2346 [ ] dvb/pmt.cpp:214 PATready [eDVBServicePMTHandler] PATready
20:43:16.2347 [ ] dvb/pmt.cpp:225 PATready [eDVBServicePMTHandler] PAT TSID: 0x0426 (1062)
20:43:16.2347 [ ] dvb/pmt.cpp:250 PATready [eDVBServicePMTHandler] no PAT entry found.. start delay
20:43:16.2347 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2348 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:43:16.2368 [ ] dvb/pmt.cpp:214 PATready [eDVBServicePMTHandler] PATready
20:43:16.2369 [ ] dvb/pmt.cpp:225 PATready [eDVBServicePMTHandler] PAT TSID: 0x0426 (1062)
20:43:16.2369 [ ] dvb/pmt.cpp:254 PATready [eDVBServicePMTHandler] use pmtpid 0401 for service_id 7532
20:43:16.2369 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2369 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1025
20:43:16.2372 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2373 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:43:16.2393 [ ] dvb/pmt.cpp:214 PATready [eDVBServicePMTHandler] PATready
20:43:16.2394 [ ] dvb/pmt.cpp:225 PATready [eDVBServicePMTHandler] PAT TSID: 0x0426 (1062)
20:43:16.2394 [ ] dvb/pmt.cpp:254 PATready [eDVBServicePMTHandler] use pmtpid 0407 for service_id 7538
20:43:16.2394 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2395 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1031
20:43:16.2397 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
20:43:16.2398 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
20:43:16.2412 [ ] dvb/cahandler.cpp:267 registerService [eDVBCAService] new service 1:0:64:7538:426:1:C00000:0:0:0:
20:43:16.2412 [ ] dvb/cahandler.cpp:285 registerService [eDVBCAService] add demux 2 to slot 0 service 1:0:64:7538:426:1:C00000:0:0:0:
20:43:16.2418 [ ] dvb_ci/dvbci.cpp:1030 gotPMT [eDVBCIInterfaces] gotPMT
20:43:16.2429 [ ] bsod.cpp:368 print_backtrace Backtrace:
20:43:16.2431 [ ] bsod.cpp:376 print_backtrace /usr/bin/enigma2(_Z17handleFatalSignaliP9siginfo_tPv) [0x85968]
20:43:16.2473 [ ] bsod.cpp:376 print_backtrace /lib/libc.so.6(__default_rt_sa_restorer) [0xB60A2AD0]
20:43:16.2473 [ ] bsod.cpp:388 handleFatalSignal -------FATAL SIGNAL
dmesg
<6>[ 0.000000] Booting Linux on physical CPU 0x0
<5>[ 0.000000] Linux version 3.14.28-1.12 (oe-user@oe-host) (gcc version 6.3.0 (GCC) ) #1 SMP Sat Apr 13 15:38:15 CEST 2019
<6>[ 0.000000] CPU: ARMv7 Processor [420f00f3] revision 3 (ARMv7), cr=30c7387d
<6>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
<6>[ 0.000000] Machine model: ULTIMO4K
<6>[ 0.000000] moving dtb from 0x0000000007628000 to 0x000000000095ca38
<6>[ 0.000000] bmem: Reserved 630 MiB at 0x0000000018a00000
<6>[ 0.000000] bmem: Reserved 383 MiB at 0x0000000068100000
<6>[ 0.000000] bmem: Reserved 443 MiB at 0x00000000a4100000
<6>[ 0.000000] cma: Reserved 16 MiB at 0x0000000017000000
<6>[ 0.000000] Memory policy: Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 786432
<7>[ 0.000000] Normal zone: 772 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 98816 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 5372 pages used for memmap
<7>[ 0.000000] HighMem zone: 687616 pages, LIFO batch:31
<6>[ 0.000000] MCP: Enabling write pairing
<6>[ 0.000000] PERCPU: Embedded 8 pages/cpu @d81b0000 s9728 r8192 d14848 u32768
<7>[ 0.000000] pcpu-alloc: s9728 r8192 d14848 u32768 alloc=8*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 785660
<5>[ 0.000000] Kernel command line: root=/dev/mmcblk0p4 rootfstype=ext4 rootflags=data=journal rootwait rw coherent_pool=2M vmalloc=622m bmem=630m@394m bmem=383m@1665m bmem=443m@2625m
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<4>[ 0.000000] Memory: 1599384K/3145728K available (6647K kernel code, 365K rwdata, 2056K rodata, 269K init, 204K bss, 1529960K reserved, 16384K cma-reserved, 1255412K highmem)
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xd8800000 - 0xff000000 ( 616 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xd8200000 ( 386 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc088818c (8705 kB)
<5>[ 0.000000] .init : 0xc0889000 - 0xc08cc600 ( 270 kB)
<5>[ 0.000000] .data : 0xc08ce000 - 0xc09296b0 ( 366 kB)
<5>[ 0.000000] .bss : 0xc09296b8 - 0xc095ca38 ( 205 kB)
<6>[ 0.000000] Hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc403000, parent irq: 94)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc3e1000, parent irq: 64)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc410640, parent irq: 96)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc4d1200, parent irq: 48)
<6>[ 0.000000] Architected cp15 timer(s) running at 27.00MHz (virt).
<6>[ 0.000003] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 2545165795328ns
<6>[ 0.000010] Switching to timer-based delay loop
<6>[ 0.000277] Console: colour dummy device 80x30
<6>[ 0.000297] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
<6>[ 0.000307] pid_max: default: 32768 minimum: 301
<6>[ 0.000405] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.000411] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.005829] CPU: Testing write buffer coherency: ok
<6>[ 0.006040] CPU0: update cpu_power 1024
<6>[ 0.006047] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>[ 0.006184] Setting up static identity map for 0x6588a8 - 0x658900
<4>[ 0.008756] CPU1: Booted secondary processor
<6>[ 0.008775] CPU1: update cpu_power 1024
<6>[ 0.008777] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
<4>[ 0.009438] CPU2: Booted secondary processor
<6>[ 0.009449] CPU2: update cpu_power 1024
<6>[ 0.009451] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
<4>[ 0.010070] CPU3: Booted secondary processor
<6>[ 0.010081] CPU3: update cpu_power 1024
<6>[ 0.010084] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
<6>[ 0.010166] Brought up 4 CPUs
<6>[ 0.010183] SMP: Total of 4 processors activated.
<6>[ 0.010188] CPU: All CPU(s) started in SVC mode.
<6>[ 0.010589] devtmpfs: initialized
<6>[ 0.014272] VFP support v0.3: implementor 42 architecture 4 part 00 variant 0 rev 0
<6>[ 0.015274] regulator-dummy: no parameters
<6>[ 0.015459] NET: Registered protocol family 16
<6>[ 0.017626] DMA: preallocated 2048 KiB pool for atomic coherent allocations
<6>[ 0.018421] cpuidle: using governor ladder
<6>[ 0.018426] cpuidle: using governor menu
<4>[ 0.021609] irq: no irq domain found for /rdb/interrupt-controller@f040a780 !
<4>[ 0.021754] irq: no irq domain found for /rdb/interrupt-controller@f0417280 !
<4>[ 0.025593] irq: no irq domain found for /rdb/interrupt-controller@f03e1a00 !
<6>[ 0.025861] syscon f0404000.syscon: regmap [mem 0xf0404000-0xf040451b] registered
<6>[ 0.026635] syscon f0404100.syscon: regmap [mem 0xf0404100-0xf040415b] registered
<6>[ 0.026784] syscon f040415c.syscon: regmap [mem 0xf040415c-0xf040419b] registered
<6>[ 0.026928] syscon f0410700.syscon: regmap [mem 0xf0410700-0xf041070b] registered
<6>[ 0.027066] syscon f041070c.syscon: regmap [mem 0xf041070c-0xf0410713] registered
<6>[ 0.027231] syscon f1101004.syscon: regmap [mem 0xf1101004-0xf1101403] registered
<6>[ 0.027375] syscon f1181004.syscon: regmap [mem 0xf1181004-0xf1181403] registered
<6>[ 0.027522] syscon f1201004.syscon: regmap [mem 0xf1201004-0xf1201403] registered
<6>[ 0.027656] syscon f0404080.syscon: regmap [mem 0xf0404080-0xf0404083] registered
<6>[ 0.027792] syscon f04040a4.syscon: regmap [mem 0xf04040a4-0xf04040a7] registered
<6>[ 0.028007] syscon f03e0154.syscon: regmap [mem 0xf03e0154-0xf03e0157] registered
<6>[ 0.028159] syscon f03e0354.syscon: regmap [mem 0xf03e0354-0xf03e0357] registered
<6>[ 0.028295] syscon f03e0400.syscon: regmap [mem 0xf03e0400-0xf03e0403] registered
<4>[ 0.028855] irq: no irq domain found for /rdb/interrupt-controller@f0417280 !
<6>[ 0.029405] syscon f03e2400.syscon: regmap [mem 0xf03e2400-0xf03e27ff] registered
<6>[ 0.029556] syscon f0452000.syscon: regmap [mem 0xf0452000-0xf04520ff] registered
<6>[ 0.029851] No ATAGs?
<6>[ 0.029871] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.029876] hw-breakpoint: maximum watchpoint size is 8 bytes.
<6>[ 0.030007] Broadcom Brahma-B15 readahead cache at: 0xfc3e2478
<6>[ 0.045621] bio: create slab <bio-0> at 0
<5>[ 0.046424] SCSI subsystem initialized
<7>[ 0.046628] libata version 3.00 loaded.
<6>[ 0.047018] usbcore: registered new interface driver usbfs
<6>[ 0.047096] usbcore: registered new interface driver hub
<6>[ 0.047183] usbcore: registered new device driver usb
<6>[ 0.047320] Linux video capture interface: v2.00
<6>[ 0.047524] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.047528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
<6>[ 0.047582] PTP clock support registered
<6>[ 0.048174] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.048924] cfg80211: Calling CRDA to update world regulatory domain
<6>[ 0.049598] brcm-pci f0460000.pcie: adjusting to legacy (broken) pcie DT
<6>[ 0.049773] brcm-pci f0490000.pcie: adjusting to legacy (broken) pcie DT
<6>[ 0.150065] brcm-pci f0460000.pcie: link down
<6>[ 0.250086] brcm-pci f0490000.pcie: link down
<6>[ 0.250135] Switched to clocksource arch_sys_counter
<5>[ 0.250336] FS-Cache: Loaded
<4>[ 0.259534] thermal thermal_zone0: failed to read out thermal zone 0
<6>[ 0.259627] NET: Registered protocol family 2
<6>[ 0.260024] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.260052] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.260096] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.260188] TCP: reno registered
<6>[ 0.260195] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.260208] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.260331] NET: Registered protocol family 1
<6>[ 0.260513] RPC: Registered named UNIX socket transport module.
<6>[ 0.260517] RPC: Registered udp transport module.
<6>[ 0.260520] RPC: Registered tcp transport module.
<6>[ 0.260524] RPC: Registered tcp NFSv4.1 backchannel transport module.
<7>[ 0.260530] PCI: CLS 0 bytes, default 64
<6>[ 0.260775] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
<6>[ 0.262082] futex hash table entries: 1024 (order: 4, 65536 bytes)
<4>[ 0.262821] bounce pool size: 64 pages
<5>[ 0.263379] NFS: Registering the id_resolver key type
<5>[ 0.263405] Key type id_resolver registered
<5>[ 0.263410] Key type id_legacy registered
<6>[ 0.263420] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
<6>[ 0.263425] Installing knfsd (copyright (C) 1996 [email protected]).
<5>[ 0.263576] FS-Cache: Netfs 'cifs' registered for caching
<5>[ 0.263636] Key type cifs.spnego registered
<6>[ 0.263789] fuse init (API version 7.22)
<6>[ 0.263950] SGI XFS with security attributes, realtime, large block/inode numbers, no debug enabled
<6>[ 0.264290] msgmni has been set to 703
<6>[ 0.265049] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ 0.265056] io scheduler noop registered
<6>[ 0.265060] io scheduler deadline registered
<6>[ 0.265081] io scheduler cfq registered (default)
<6>[ 0.265320] brcm-gisb-arb f0400000.gisb-arb: registered mem: fc400000, irqs: 258, 259
<6>[ 0.295569] brcm-waketimer f0417580.waketimer: registered, with irq 260
<6>[ 0.295855] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
<6>[ 0.297281] f040ab00.serial: ttyS0 at MMIO 0xf040ab00 (irq = 107, base_baud = 5062500) is a 16550A
<6>[ 1.136369] console [ttyS0] enabled
<6>[ 1.140295] f040ab40.serial: ttyS1 at MMIO 0xf040ab40 (irq = 108, base_baud = 5062500) is a 16550A
<6>[ 1.149646] f040ab80.serial: ttyS2 at MMIO 0xf040ab80 (irq = 109, base_baud = 5062500) is a 16550A
<6>[ 1.162191] loop: module loaded
<3>[ 1.165950] ahci brcmstb-ahci.0: can't get clock
<6>[ 1.170665] ahci brcmstb-ahci.0: SSS flag set, parallel bus scan disabled
<6>[ 1.188152] ahci brcmstb-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
<6>[ 1.196783] ahci brcmstb-ahci.0: flags: 64bit ncq sntf stag pm clo pmp slum part
<6>[ 1.206434] scsi0 : ahci_platform
<6>[ 1.210083] scsi1 : ahci_platform
<6>[ 1.213636] ata1: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x100 irq 62
<6>[ 1.221571] ata2: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x180 irq 62
<6>[ 1.230763] spi_brcmstb f03e3400.spi: 1-lane output, 3-byte address
<6>[ 1.237158] spi_brcmstb f03e3400.spi: master is unqueued, this is deprecated
<4>[ 1.244476] m25p80 spi32766.0: found mx25l3255e, expected m25p80
<6>[ 1.250505] m25p80 spi32766.0: mx25l3255e (4096 Kbytes)
<5>[ 1.255763] 5 ofpart partitions found on MTD device spi32766.0
<5>[ 1.261608] Creating 5 MTD partitions on "spi32766.0":
<5>[ 1.266759] 0x000000000000-0x000000200000 : "flash0.bolt"
<5>[ 1.272844] 0x000000200000-0x000000210000 : "flash0.macadr"
<5>[ 1.279075] 0x000000210000-0x000000220000 : "flash0.nvram"
<5>[ 1.285223] 0x000000220000-0x000000230000 : "flash0.devtree"
<5>[ 1.291537] 0x000000000000-0x000000400000 : "flash0"
<6>[ 1.298221] libphy: Fixed MDIO Bus: probed
<6>[ 1.304775] libphy: unimac MII bus: probed
<6>[ 1.313137] unimac-mdio f0b403c0.mdio: Broadcom UniMAC MDIO bus at 0xfcb403c0
<6>[ 1.321120] brcm-systemport f04a0000.ethernet: Broadcom SYSTEMPORTv 1.00 at 0xfc4a0000 (irqs: 54, 55, TXQs: 32, RXQs: 1)
<6>[ 1.334698] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
<6>[ 1.338158] ata1: SATA link down (SStatus 0 SControl 300)
<6>[ 1.345949] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
<6>[ 1.352444] xhci-brcm: xHCI BRCM driver
<6>[ 1.356380] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
<6>[ 1.362218] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 1
<6>[ 1.370344] xhci-brcm f0471000.xhci_v2: irq 115, io mem 0xf0471000
<6>[ 1.377069] hub 1-0:1.0: USB hub found
<3>[ 1.380849] hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
<6>[ 1.388115] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
<6>[ 1.393934] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 2
<6>[ 1.402275] hub 2-0:1.0: USB hub found
<6>[ 1.406054] hub 2-0:1.0: 2 ports detected
<6>[ 1.410481] ehci-brcm: EHCI BRCM driver
<6>[ 1.414396] ehci-brcm f0470300.ehci_v2: EHCI Host Controller
<6>[ 1.420225] ehci-brcm f0470300.ehci_v2: new USB bus registered, assigned bus number 3
<6>[ 1.438191] ehci-brcm f0470300.ehci_v2: irq 111, io mem 0xf0470300
<6>[ 1.450142] ehci-brcm f0470300.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.456837] hub 3-0:1.0: USB hub found
<6>[ 1.459149] ata2: SATA link down (SStatus 0 SControl 300)
<6>[ 1.466023] hub 3-0:1.0: 1 port detected
<6>[ 1.470171] ehci-brcm f0470500.ehci_v2: EHCI Host Controller
<6>[ 1.476006] ehci-brcm f0470500.ehci_v2: new USB bus registered, assigned bus number 4
<6>[ 1.493967] ehci-brcm f0470500.ehci_v2: irq 112, io mem 0xf0470500
<6>[ 1.506142] ehci-brcm f0470500.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.512831] hub 4-0:1.0: USB hub found
<6>[ 1.516609] hub 4-0:1.0: 1 port detected
<6>[ 1.520758] ehci-brcm f0480300.ehci_v2: EHCI Host Controller
<6>[ 1.526585] ehci-brcm f0480300.ehci_v2: new USB bus registered, assigned bus number 5
<6>[ 1.544532] ehci-brcm f0480300.ehci_v2: irq 117, io mem 0xf0480300
<6>[ 1.556141] ehci-brcm f0480300.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.562829] hub 5-0:1.0: USB hub found
<6>[ 1.566608] hub 5-0:1.0: 1 port detected
<6>[ 1.570749] ehci-brcm f0480500.ehci_v2: EHCI Host Controller
<6>[ 1.576590] ehci-brcm f0480500.ehci_v2: new USB bus registered, assigned bus number 6
<6>[ 1.594543] ehci-brcm f0480500.ehci_v2: irq 118, io mem 0xf0480500
<6>[ 1.606141] ehci-brcm f0480500.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.612796] hub 6-0:1.0: USB hub found
<6>[ 1.616575] hub 6-0:1.0: 1 port detected
<6>[ 1.620850] ohci-brcm: OHCI BRCM driver
<6>[ 1.624762] ohci-brcm f0470400.ohci_v2: BRCM OHCI controller
<6>[ 1.630581] ohci-brcm f0470400.ohci_v2: new USB bus registered, assigned bus number 7
<6>[ 1.638460] ohci-brcm f0470400.ohci_v2: irq 113, io mem 0xf0470400
<6>[ 1.699601] hub 7-0:1.0: USB hub found
<6>[ 1.703421] hub 7-0:1.0: 1 port detected
<6>[ 1.707565] ohci-brcm f0470600.ohci_v2: BRCM OHCI controller
<6>[ 1.713400] ohci-brcm f0470600.ohci_v2: new USB bus registered, assigned bus number 8
<6>[ 1.721285] ohci-brcm f0470600.ohci_v2: irq 114, io mem 0xf0470600
<6>[ 1.782614] hub 8-0:1.0: USB hub found
<6>[ 1.786392] hub 8-0:1.0: 1 port detected
<6>[ 1.790525] ohci-brcm f0480400.ohci_v2: BRCM OHCI controller
<6>[ 1.796356] ohci-brcm f0480400.ohci_v2: new USB bus registered, assigned bus number 9
<6>[ 1.804239] ohci-brcm f0480400.ohci_v2: irq 119, io mem 0xf0480400
<6>[ 1.865607] hub 9-0:1.0: USB hub found
<6>[ 1.869386] hub 9-0:1.0: 1 port detected
<6>[ 1.873517] ohci-brcm f0480600.ohci_v2: BRCM OHCI controller
<6>[ 1.879262] usb 5-1: new high-speed USB device number 2 using ehci-brcm
<6>[ 1.885973] ohci-brcm f0480600.ohci_v2: new USB bus registered, assigned bus number 10
<6>[ 1.893970] ohci-brcm f0480600.ohci_v2: irq 120, io mem 0xf0480600
<6>[ 1.955624] hub 10-0:1.0: USB hub found
<6>[ 1.959489] hub 10-0:1.0: 1 port detected
<6>[ 1.963831] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[ 1.970380] ehci-pci: EHCI PCI platform driver
<6>[ 1.974921] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
<6>[ 1.981122] ohci-pci: OHCI PCI platform driver
<6>[ 1.985872] usbcore: registered new interface driver usb-storage
<6>[ 1.992058] mousedev: PS/2 mouse device common for all mice
<6>[ 1.998063] i2c /dev entries driver
<6>[ 2.001923] IR NEC protocol handler initialized
<6>[ 2.006469] IR RC5(x) protocol handler initialized
<6>[ 2.011289] IR RC6 protocol handler initialized
<6>[ 2.015845] IR JVC protocol handler initialized
<6>[ 2.020404] IR Sony protocol handler initialized
<6>[ 2.025046] IR RC5 (streamzap) protocol handler initialized
<6>[ 2.030646] IR SANYO protocol handler initialized
<6>[ 2.035364] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 2.041552] hub 5-1:1.0: USB hub found
<6>[ 2.043217] brcmstb_thermal f04d1500.thermal: registered AVS TMON of-sensor driver
<4>[ 2.043439] cpufreq_cpu0: failed to get cpu0 regulator: -19
<6>[ 2.043727] sdhci: Secure Digital Host Controller Interface driver
<6>[ 2.043728] sdhci: Copyright(c) Pierre Ossman
<6>[ 2.043730] sdhci-pltfm: SDHCI platform and OF driver helper
<6>[ 2.044854] mmc0: no vqmmc regulator found
<6>[ 2.044857] mmc0: no vmmc regulator found
<6>[ 2.075139] mmc0: SDHCI controller on f03e0200.sdhci [f03e0200.sdhci] using ADMA
<6>[ 2.090382] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 2.092505] hub 5-1:1.0: 4 ports detected
<6>[ 2.100220] usbcore: registered new interface driver usbhid
<6>[ 2.105809] usbhid: USB HID core driver
<6>[ 2.110346] TCP: cubic registered
<6>[ 2.113740] NET: Registered protocol family 10
<6>[ 2.118688] NET: Registered protocol family 17
<5>[ 2.123258] Distributed Switch Architecture driver version 0.1
<6>[ 2.129168] sys0[0]: detected a Broadcom Starfighter 2 switch
<6>[ 2.135140] Starfighter 2 top: 4.00, core: 2.00 base: 0xfcb00000, IRQs: 56, 57
<6>[ 2.142521] libphy: dsa slave smi: probed
<6>[ 2.176791] mmc0: BKOPS_EN bit is not set
<6>[ 2.187059] mmc0: new high speed MMC card at address 0001
<6>[ 2.192748] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
<6>[ 2.197383] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
<6>[ 2.203143] f0b403c0.mdio:05: Broadcom BCM7445 PHY revision: 0x10, patch: 3
<6>[ 2.210372] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
<6>[ 2.216392] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
<6>[ 2.225403] mmcblk0: p1 p2 p3 p4
<6>[ 2.231624] mmcblk0boot1: unknown partition table
<6>[ 2.237306] mmcblk0boot0: unknown partition table
<6>[ 2.368252] usb 5-1.1: new high-speed USB device number 3 using ehci-brcm
<6>[ 2.438110] attached PHY at address 5 [Broadcom BCM7445]
<3>[ 2.443948] net eth0: PHY already attached
<5>[ 2.448250] Key type dns_resolver registered
<5>[ 2.452635] Registering SWP/SWPB emulation handler
<6>[ 2.457865] regulator-dummy: disabling
<6>[ 2.465165] ALSA device list:
<6>[ 2.468149] No soundcards found.
<4>[ 2.472396] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
<6>[ 2.535258] usb 5-1.2: new full-speed USB device number 4 using ehci-brcm
<6>[ 2.794739] EXT4-fs (mmcblk0p4): recovery complete
<6>[ 2.799990] EXT4-fs (mmcblk0p4): mounted filesystem with journalled data mode. Opts: data=journal
<6>[ 2.808910] VFS: Mounted root (ext4 filesystem) on device 179:4.
<6>[ 2.815383] devtmpfs: mounted
<6>[ 2.818573] Freeing unused kernel memory: 268K (c0889000 - c08cc000)
<5>[ 3.079052] random: nonblocking pool is initialized
<6>[ 3.500398] EXT4-fs (mmcblk0p4): re-mounted. Opts: nodelalloc,data=journal
<6>[ 4.881382] usb 5-1.1: USB disconnect, device number 3
<6>[ 4.908577] usbcore: registered new interface driver dbus_usbdev
<6>[ 4.983781] IPv6: ADDRCONF(NETDEV_UP): sys0: link is not ready
<4>[ 5.000633] bcm_event: module license 'Proprietary' taints kernel.
<4>[ 5.006867] Disabling lock debugging due to kernel taint
<6>[ 5.068312] usb 5-1.1: new high-speed USB device number 5 using ehci-brcm
<4>[ 5.163991] Dongle Host Driver, version 1.363.110.16 (r620666)
<4>[ 5.163991] Compiled in on Oct 27 2016 at 18:59:23
<4>[ 5.175914] Register interface [wlan3] MAC: 00:90:4c:11:22:33
<4>[ 5.175914]
<6>[ 6.986157] libphy: fixed-0:00 - Link is Up - 1000/Full
<6>[ 6.991431] IPv6: ADDRCONF(NETDEV_CHANGE): sys0: link becomes ready
<6>[ 11.344758] DVB: registering new adapter (_vuplus_ultimo4k_)
<4>[ 11.665234] bcm7444: hotplug_callback():
<4>[ 11.665234] Hotplug - status.connected 1:0:1
<4>[ 11.672251] bcm7444: hotplug_callback():
<4>[ 11.672251] Hotplug - connecting HDMI to display 0xe
<6>[ 11.893137] brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
<4>[ 12.009613] [MPVR]: >> misc_pvr_init
<4>[ 12.015449] [VID]: 6bcm7335_video_init
<4>[ 12.061015] [AUD]: 6bcm7335_audio_init
<4>[ 12.065844] [AUD]: >> bcm_audio_capture_init
<4>[ 12.074186] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.096197] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.104135] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.119909] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.128056] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.143647] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.151839] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.167868] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.175778] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.191860] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.199937] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.215718] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.223598] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.239483] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.247522] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.263324] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.271262] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0
<6>[ 12.277351] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.285317] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0
<6>[ 12.291208] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.299435] -----------10 slot is empty ----------------
<4>[ 12.304786] -----------11 slot is empty ----------------
<4>[ 12.310120] -----------12 slot is empty ----------------
<4>[ 12.315695] -----------13 slot is empty ----------------
<4>[ 12.321118] -----------14 slot is empty ----------------
<4>[ 12.326452] -----------15 slot is empty ----------------
<4>[ 12.331997] -----------16 slot is empty ----------------
<4>[ 12.337331] -----------17 slot is empty ----------------
<4>[ 12.342718] bcm7444: bcm7335_frontend_init():
<4>[ 12.344318] bcm7444: hotplug_callback():
<4>[ 12.344321] Hotplug - status.connected 1:1:3
<4>[ 12.355546] vtuner1 : 11 m_nfbc=0 m_fbc=10
<4>[ 12.378332] BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
<4>[ 12.386051] BKNI_Malloc(linuxkernel) top users:
<4>[ 12.386051] blocks, bytes, filename:line
<4>[ 12.395073] 901, 198356, BSEAV/lib/utils/balloc.c:31
<6>[ 12.441613] input: dreambox advanced remote control (native) as /devices/virtual/input/input0
<6>[ 12.454681] [LCD]: registered
<4>[ 12.790651] GPIO Init...
<6>[ 12.803799] [CI]: registered ci0
<6>[ 12.807471] [CI]: registered ci1
<6>[ 12.816910] [CI]: CI interface initialised
<6>[ 12.816910]
<6>[ 12.830481] [DFP]: registered dbox fp
<6>[ 12.838033] [SC]: registered sci0
<6>[ 12.841920] [SC]: registered sci1
<4>[ 12.996189] system_time_set wakeup mode get
<4>[ 13.060152] system_time_set wakeup mode get 0xc4
<4>[ 13.098153] BKNI_P_GetTrackAllocEntry_resize: resizing from 8704->14080
<4>[ 13.106777] BKNI_Malloc(linuxkernel) top users:
<4>[ 13.106777] blocks, bytes, filename:line
<4>[ 13.115770] 2277, 497532, BSEAV/lib/utils/balloc.c:31
<4>[ 13.261753] FPGA Version 0x11
<6>[ 13.391221] wakeup_drv: Initializing wakeup driver
<6>[ 13.396770] wakeup_drv: Initialization complete
<4>[ 13.476377] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 13.480736] [VID]: VIDEO_SELECT_SOURCE 1 0
<4>[ 13.485017] [VID]: VIDEO_PLAY 1 2 0
<4>[ 13.494016] [VID]: VIDEO_CONTINUE 1 1
<4>[ 13.497886] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[ 13.777734] [VID]: VIDEO_STOP 0 1
<4>[ 13.793249] [VID]: VIDEO_SELECT_SOURCE 0 0
<6>[ 13.878641] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
<6>[ 15.248034] Bluetooth: Core ver 2.18
<6>[ 15.251932] NET: Registered protocol family 31
<6>[ 15.256409] Bluetooth: HCI device and connection manager initialized
<6>[ 15.262833] Bluetooth: HCI socket layer initialized
<6>[ 15.267759] Bluetooth: L2CAP socket layer initialized
<6>[ 15.272875] Bluetooth: SCO socket layer initialized
<6>[ 15.562175] libphy: f0b403c0.mdio:05 - Link is Down
<4>[ 17.441259] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 17.445716] [VID]: VIDEO_SELECT_SOURCE 1 0
<4>[ 17.450007] [VID]: VIDEO_PLAY 1 2 0
<4>[ 17.458894] [VID]: VIDEO_CONTINUE 1 1
<4>[ 17.463076] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<6>[ 17.594226] libphy: f0b403c0.mdio:05 - Link is Up - 1000/Full
<6>[ 17.600029] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
<4>[ 17.744300] [VID]: VIDEO_STOP 0 1
<4>[ 17.759438] [VID]: VIDEO_SELECT_SOURCE 0 0
<3>[ 17.847993] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 17.897059] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 17.951036] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.000360] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.058871] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.107966] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.169242] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.218848] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<4>[ 19.338586] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0 mode=1
<6>[ 19.345090] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 20.358467] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0 mode=1
<6>[ 20.364972] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 23.003974] [AUD]: AUDIO_SET_MUTE 0
<4>[ 23.008020] [AUD]: AUDIO_SET_MIXER -779624824
<4>[ 23.012493] [AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[ 23.017572] [AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
<4>[ 23.024208] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 29.883805] [AUD]: AUDIO_SET_MIXER -779624824
<4>[ 29.888300] [AUD]: AUDIO_SET_MIXER : amixl 32, amixr 32
<4>[ 29.893552] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 29.900573] [AUD]: AUDIO_SET_MIXER : next left volume -2355, right volume -2355
<4>[ 30.264529] FE tune
<4>[ 30.854023] [AUD]: AUDIO_SELECT_SOURCE 0
<4>[ 30.858732] [AUD]: AUDIO_SET_BYPASS_MODE 0
<4>[ 30.863488] [AUD]: AC3 downmix 0 state : 0
<4>[ 30.867762] [AUD]: AUDIO_PAUSE 0
<4>[ 30.871135] [AUD]: AUDIO_PLAY 0 decoder start : 0
<4>[ 30.889171] [VID]: VIDEO_SELECT_SOURCE 0 0
<4>[ 30.893429] [VID]: VIDEO_GET_SIZE src w: 1920 h:1080 display w:1920 h:1080
<4>[ 30.900362] [VID]: VIDEO_GET_SIZE aspect: 1 3
<4>[ 30.905063] [VID]: VIDEO_SET_STREAMTYPE 1
<4>[ 30.909352] [VID]: VIDEO_FREEZE 0 0
<4>[ 30.913142] [VID]: VIDEO_PLAY 0 5 2
<4>[ 30.923580] [VID]: VIDEO_SLOWMOTION 0 1
<4>[ 30.928911] [VID]: VIDEO_FAST_FORWARD 0 1 0
<4>[ 30.934721] [VID]: VIDEO_CONTINUE 0 1
<4>[ 30.939816] [AUD]: AUDIO_CONTINUE 0 1 aph=0xd1889c80
<4>[ 30.946246] [AUD]: Mute : 0
<4>[ 30.950466] [AUD]: AUDIO_CHANNEL_SELECT 0
<4>[ 32.925268] FE tune
<4>[ 40.118352] FE tune
<4>[ 40.291051] [VID]: VIDEO_STOP 1 1
<4>[ 40.294956] [AUD]: AUDIO_STOP 0
<4>[ 40.304664] [AUD]: AUDIO_CONTINUE 0 0 aph=0x0
<4>[ 40.309070] [AUD]: AUDIO_CONTINUE aph=0 0 0
<4>[ 61.594410] FE tune
<4>[ 86.129944] FE tune
<4>[ 100.800362] FE tune
<4>[ 165.112116] FE tune
<4>[ 2351.848468] FE tune
<4>[ 3005.727613] FE tune
<4>[ 3042.560774] FE tune
<4>[ 3146.902593] FE tune
<4>[ 3157.253956] FE tune
<4>[ 4784.634620] FE tune
<4>[ 4986.601766] FE tune
<4>[ 4998.598773] FE tune
<4>[ 9079.295507] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0 mode=0
<6>[ 9079.301995] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 9080.321489] FE tune
<4>[ 9103.673264] FE tune
<4>[ 9158.925717] FE tune
<4>[41692.698287] FE tune
<4>[61285.250127] FE tune
<4>[62917.333067] FE tune
<4>[63043.312246] FE tune
<4>[63191.793446] FE tune
<4>[65316.576975] FE tune
<4>[66296.986198] FE tune
<4>[67712.312303] FE tune
<4>[67902.485035] FE tune
<4>[67980.313395] FE tune
<4>[67995.874781] FE tune
<4>[68147.410830] FE tune
<4>[68327.637831] FE tune
<4>[69594.992721] FE tune
<4>[69639.122489] FE tune
<4>[69803.973356] FE tune
<4>[69956.587310] FE tune
<4>[71171.562040] FE tune
<4>[71711.043633] FE tune
<4>[72142.563734] FE tune
<4>[72169.676208] FE tune
<4>[72949.011182] FE tune
<4>[73923.201198] FE tune
<4>[74502.764683] FE tune
<4>[76120.423727] FE tune
<4>[77092.130158] FE tune
<4>[79715.997601] FE tune
<4>[85678.087965] FE tune
<4>[85841.505012] FE tune
<4>[85901.037125] FE tune
<4>[85923.459663] FE tune
<4>[93584.670718] FE tune
<4>[98701.896383] FE tune
<4>[99001.893711] FE tune
<4>[115644.324993] FE tune
<4>[127479.102472] FE tune
<4>[127500.131916] FE tune
<4>[151412.545055] FE tune
<4>[151682.553825] FE tune
<4>[152024.593396] FE tune
<4>[152394.604700] FE tune
<4>[152779.712584] FE tune
<4>[152791.901135] FE tune
<4>[153485.418872] FE tune
<4>[155233.537312] FE tune
<4>[155460.821486] FE tune
<4>[155895.474235] FE tune
<4>[159044.770493] FE tune
<4>[159113.486442] FE tune
<4>[167555.658065] FE tune
<4>[168872.741678] FE tune
<6>[168928.388354] libphy: f0b403c0.mdio:05 - Link is Down
<6>[168935.493920] libphy: f0b403c0.mdio:05 - Link is Up - 1000/Full
<4>[169150.062329] FE tune
<4>[169173.906984] FE tune
<4>[173035.242882] FE tune
<4>[173053.891917] FE tune
<4>[174202.059184] FE tune
<4>[174210.976227] FE tune
<4>[174223.020169] FE tune
<4>[174359.550486] FE tune
<4>[174426.016002] FE tune
<4>[174681.368039] FE tune
<4>[176589.102728] FE tune
<4>[176614.666036] FE tune
<4>[176685.901558] FE tune
<4>[176788.059210] FE tune
<4>[176849.986737] FE tune
<4>[176927.596047] FE tune
<4>[177291.888664] FE tune
<4>[177326.406156] FE tune
<4>[177332.906173] FE tune
<4>[177374.918816] FE tune
<4>[177555.219292] FE tune
<4>[177557.819417] FE tune
<4>[179833.410030] FE tune
<4>[180597.737220] FE tune
<4>[180621.988500] FE tune
<4>[181688.372573] FE tune
<4>[181900.264904] FE tune
<4>[181976.154004] FE tune
<4>[182000.321455] FE tune
<4>[184051.618181] FE tune
<4>[184702.336246] FE tune
<4>[184779.892899] FE tune
<4>[184887.207362] FE tune
<4>[184995.312090] FE tune
<4>[185027.498936] FE tune
<4>[214574.135612] FE tune
<4>[214627.402552] FE tune
<4>[218072.563168] FE tune
<6>[218620.176207] libphy: f0b403c0.mdio:05 - Link is Down
<6>[219973.036564] libphy: f0b403c0.mdio:05 - Link is Up - 1000/Full
<6>[219975.057636] libphy: f0b403c0.mdio:05 - Link is Down
<6>[219977.090606] libphy: f0b403c0.mdio:05 - Link is Up - 1000/Full
<6>[220662.317327] usb 2-2: new SuperSpeed USB device number 2 using xhci-brcm
<4>[220662.334454] usb 2-2: Parent hub missing LPM exit latency info. Power management will be impacted.
<6>[220662.345710] usb-storage 2-2:1.0: USB Mass Storage device detected
<6>[220662.352384] scsi2 : usb-storage 2-2:1.0
<5>[220663.360602] scsi 2:0:0:0: Direct-Access WD My Book 25EE 4007 PQ: 0 ANSI: 6
<5>[220663.371433] sd 2:0:0:0: [sda] Spinning up disk...
<5>[220663.376780] sd 2:0:0:0: Attached scsi generic sg0 type 0
<5>[220663.383769] scsi 2:0:0:1: Enclosure WD SES Device 4007 PQ: 0 ANSI: 6
<5>[220663.395515] scsi 2:0:0:1: Attached scsi generic sg1 type 13
<4>[220664.377201] .................ready
<5>[220680.396172] sd 2:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
<5>[220680.403814] sd 2:0:0:0: [sda] 15628052480 512-byte logical blocks: (8.00 TB/7.27 TiB)
<5>[220680.411754] sd 2:0:0:0: [sda] 4096-byte physical blocks
<5>[220680.417286] sd 2:0:0:0: [sda] Write Protect is off
<7>[220680.422204] sd 2:0:0:0: [sda] Mode Sense: 47 00 10 08
<3>[220680.422472] sd 2:0:0:0: [sda] No Caching mode page found
<3>[220680.428009] sd 2:0:0:0: [sda] Assuming drive cache: write through
<5>[220680.437147] sd 2:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
<3>[220680.445264] sd 2:0:0:0: [sda] No Caching mode page found
<3>[220680.450683] sd 2:0:0:0: [sda] Assuming drive cache: write through
<6>[220681.792309] sda: sda1 sda2
<5>[220681.797469] sd 2:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
<3>[220681.806574] sd 2:0:0:0: [sda] No Caching mode page found
<3>[220681.812003] sd 2:0:0:0: [sda] Assuming drive cache: write through
<5>[220681.818230] sd 2:0:0:0: [sda] Attached SCSI disk
<4>[220682.268583] UDF-fs: warning (device sda1): udf_fill_super: No partition found (2)
<4>[220682.329366] UDF-fs: warning (device sda1): udf_fill_super: No partition found (2)
<4>[220682.507535] UDF-fs: warning (device sda2): udf_fill_super: No partition found (2)
<4>[241141.115275] FE tune
<4>[242450.801095] FE tune
<4>[242473.789677] FE tune
<4>[242496.573560] FE tune
<4>[243325.290324] FE tune
<4>[243628.031998] FE tune
<4>[244108.219742] FE tune
<4>[244190.540979] FE tune
<4>[245115.037495] FE tune
<4>[245148.354388] FE tune
<4>[246539.634777] FE tune
<4>[246862.145713] FE tune
<4>[249163.386973] FE tune
<4>[249525.992291] FE tune
<4>[250372.268866] FE tune
<4>[253997.477869] FE tune
<4>[254830.249214] FE tune
<4>[254865.916992] FE tune
<4>[254928.098822] FE tune
<4>[254991.134821] FE tune
<4>[255026.694214] FE tune
<4>[255727.795821] FE tune
<4>[255844.755908] FE tune
<4>[259377.953711] FE tune
<4>[259383.177200] FE tune
<4>[259400.132374] FE tune
<4>[259414.622077] FE tune
<4>[259653.126114] FE tune
<4>[259870.330622] FE tune
<4>[259876.780176] FE tune
<4>[259930.526262] FE tune
<4>[260010.056838] FE tune
<4>[260048.835193] FE tune
<4>[260474.090579] FE tune
crashdate=dom jun 16 00:20:45 2019
branch=master
rev=ccbad05
stbmodel=ultimo4k
stbmodel=dm8000
.cpp:34 serviceEvent [eDVBServiceStream] tuned.. m_state 1 m_want_record 0
00:20:44.9302 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux3
00:20:44.9302 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
00:20:44.9308 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
00:20:44.9310 [ ] dvb/demux.cpp:656 eDVBRecordStreamThread [eDVBRecordStreamThread] allocated 40 buffers of 192 kB
00:20:44.9310 [ ] service/servicedvbstream.cpp:154 doRecord [eDVBServiceStream] start streaming...
00:20:44.9310 [ ] service/servicedvbstream.cpp:337 recordCachedPids [eDVBServiceStream] no cached pids found
00:20:44.9311 < > service/servicedvbstream.cpp:207 doRecord [eDVBServiceStream] have 1 video stream(s) (00b0), and 1 audio stream(s) (0090), and the pcr pid is 00b0, and the text pid is ffffffff
00:20:44.9311 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0000
00:20:44.9311 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0012
00:20:44.9312 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0014
00:20:44.9312 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0090
00:20:44.9312 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 00b0
00:20:44.9318 [ ] base/ioprio.cpp:91 setIoPrio [setIoPrio] realtime level 7 ok
00:20:44.9319 [ ] dvb/filepush.cpp:542 thread [eFilePushThreadRecorder] THREAD START
00:20:44.9467 [ ] dvb/pmt.cpp:214 PATready [eDVBServicePMTHandler] PATready
00:20:44.9467 [ ] dvb/pmt.cpp:225 PATready [eDVBServicePMTHandler] PAT TSID: 0x0412 (1042)
00:20:44.9467 [ ] dvb/pmt.cpp:254 PATready [eDVBServicePMTHandler] use pmtpid 0410 for service_id 7572
00:20:44.9468 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux3
00:20:44.9468 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1040
00:20:44.9472 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux3
00:20:44.9472 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
00:20:44.9583 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux4
00:20:44.9584 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1038
00:20:44.9842 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux4
00:20:44.9843 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1039
00:20:45.0102 [ ] dvb/frontend.cpp:1090 feEvent [eDVBFrontend] (7)fe event: status 1f, inversion off, m_tuning 3
00:20:45.0102 [ ] dvb/dvb.cpp:1886 frontendStateChanged [eDVBChannel] OURSTATE: tuner 7 ok
00:20:45.0103 [ ] dvb/dvbtime.cpp:684 DVBChannelStateChanged [eDVBLocalTimerHandler] channel 0x13585a8 running
00:20:45.0103 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
00:20:45.0103 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0104 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=20
00:20:45.0108 [ ] dvb/epgcache.cpp:684 DVBChannelStateChanged [eEPGCache] channel 0x13585a8 running
00:20:45.0108 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
00:20:45.0108 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0109 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0110 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0111 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0112 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0113 [ ] dvb/epgcache.cpp:2076 startChannel [eEPGCache] next update in 2 sec
00:20:45.0114 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=01
00:20:45.0114 [ ] dvb/dvb.cpp:1102 allocateDemux [eDVBResourceManager] allocate demux cap=01
00:20:45.0114 [ ] dvb/dvb.cpp:1211 allocateDemux [eDVBResourceManager] allocating shared demux adapter=0, demux=6, source=7
00:20:45.0114 [ ] dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!!
00:20:45.0114 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 5
00:20:45.0115 [ ] service/servicedvbstream.cpp:132 doRecord [eDVBServiceStream] try it again when we are tuned in
00:20:45.0115 [ ] dvb/cahandler.cpp:267 registerService [eDVBCAService] new service 1:0:1:7A49:410:1:C00000:0:0:0:
00:20:45.0116 [ ] dvb/cahandler.cpp:285 registerService [eDVBCAService] add demux 6 to slot 0 service 1:0:1:7A49:410:1:C00000:0:0:0:
00:20:45.0116 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0116 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
00:20:45.0120 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 6
00:20:45.0120 [ ] service/servicedvbstream.cpp:34 serviceEvent [eDVBServiceStream] tuned.. m_state 1 m_want_record 1
00:20:45.0120 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0121 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
00:20:45.0124 [ ] dvb/demux.cpp:656 eDVBRecordStreamThread [eDVBRecordStreamThread] allocated 40 buffers of 192 kB
00:20:45.0124 [ ] service/servicedvbstream.cpp:154 doRecord [eDVBServiceStream] start streaming...
00:20:45.0125 [ ] service/servicedvbstream.cpp:337 recordCachedPids [eDVBServiceStream] no cached pids found
00:20:45.0125 < > service/servicedvbstream.cpp:207 doRecord [eDVBServiceStream] have 1 video stream(s) (1f42), and 1 audio stream(s) (1fa6), and the pcr pid is 1f42, and the text pid is ffffffff
00:20:45.0126 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0000
00:20:45.0126 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0012
00:20:45.0126 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0014
00:20:45.0126 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 1f42
00:20:45.0126 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 1fa6
00:20:45.0132 [ ] base/ioprio.cpp:91 setIoPrio [setIoPrio] realtime level 7 ok
00:20:45.0133 [ ] dvb/filepush.cpp:542 thread [eFilePushThreadRecorder] THREAD START
00:20:45.0140 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux6
00:20:45.0140 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
00:20:45.0497 [ ] dvb/streamserver.cpp:167 notifier [eDVBServiceStream] stream ref: 1:0:1:757C:412:1:C00000:0:0:0:
00:20:45.0500 [ ] dvb/dvb.cpp:1409 allocateChannel [eDVBResourceManager] allocate channel.. 0412:0001
00:20:45.0500 [ ] dvb/dvb.cpp:1412 allocateChannel [eDVBResourceManager] available channel.. 03f4:0001
00:20:45.0500 [ ] dvb/dvb.cpp:1412 allocateChannel [eDVBResourceManager] available channel.. 040a:0001
00:20:45.0501 [ ] dvb/dvb.cpp:1412 allocateChannel [eDVBResourceManager] available channel.. 041e:0001
00:20:45.0501 [ ] dvb/dvb.cpp:1412 allocateChannel [eDVBResourceManager] available channel.. 0412:0001
00:20:45.0501 [ ] dvb/dvb.cpp:1420 allocateChannel [eDVBResourceManager] found shared channel.. i=3, frontend=4 (preferred=-1)
00:20:45.0502 [ ] dvb/pmt.cpp:1049 tuneExt [eDVBServicePMTHandler] allocate Channel: res 0
00:20:45.0502 [ ] dvb_ci/dvbci.cpp:904 addPMTHandler [eDVBCIInterfaces] addPMTHandler 1:0:1:757C:412:1:C00000:0:0:0:
00:20:45.0504 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=01
00:20:45.0504 [ ] dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!!
00:20:45.0504 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 5
00:20:45.0505 [ ] dvb/cahandler.cpp:267 registerService [eDVBCAService] new service 1:0:1:757C:412:1:C00000:0:0:0:
00:20:45.0505 [ ] dvb/cahandler.cpp:285 registerService [eDVBCAService] add demux 3 to slot 0 service 1:0:1:757C:412:1:C00000:0:0:0:
00:20:45.0506 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux3
00:20:45.0507 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
00:20:45.0533 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 6
00:20:45.0533 [ ] service/servicedvbstream.cpp:34 serviceEvent [eDVBServiceStream] tuned.. m_state 1 m_want_record 0
00:20:45.0533 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux3
00:20:45.0534 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
00:20:45.0542 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
00:20:45.0543 [ ] dvb/demux.cpp:656 eDVBRecordStreamThread [eDVBRecordStreamThread] allocated 40 buffers of 192 kB
00:20:45.0544 [ ] service/servicedvbstream.cpp:154 doRecord [eDVBServiceStream] start streaming...
00:20:45.0544 [ ] service/servicedvbstream.cpp:337 recordCachedPids [eDVBServiceStream] no cached pids found
00:20:45.0544 < > service/servicedvbstream.cpp:207 doRecord [eDVBServiceStream] have 1 video stream(s) (00b1), and 1 audio stream(s) (0094), and the pcr pid is 00b1, and the text pid is ffffffff
00:20:45.0545 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0000
00:20:45.0545 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0012
00:20:45.0545 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0014
00:20:45.0546 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0094
00:20:45.0546 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 00b1
00:20:45.0551 [ ] base/ioprio.cpp:91 setIoPrio [setIoPrio] realtime level 7 ok
00:20:45.0552 [ ] dvb/filepush.cpp:542 thread [eFilePushThreadRecorder] THREAD START
00:20:45.0583 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
00:20:45.0584 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1038
00:20:45.0591 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
00:20:45.0591 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1038
00:20:45.0600 [ ] dvb/streamserver.cpp:167 notifier [eDVBServiceStream] stream ref: 1:0:1:769E:41E:1:C00000:0:0:0:
00:20:45.0602 [ ] dvb/dvb.cpp:1409 allocateChannel [eDVBResourceManager] allocate channel.. 041e:0001
00:20:45.0602 [ ] dvb/dvb.cpp:1412 allocateChannel [eDVBResourceManager] available channel.. 03f4:0001
00:20:45.0602 [ ] dvb/dvb.cpp:1412 allocateChannel [eDVBResourceManager] available channel.. 040a:0001
00:20:45.0603 [ ] dvb/dvb.cpp:1412 allocateChannel [eDVBResourceManager] available channel.. 041e:0001
00:20:45.0603 [ ] dvb/dvb.cpp:1420 allocateChannel [eDVBResourceManager] found shared channel.. i=2, frontend=3 (preferred=-1)
00:20:45.0603 [ ] dvb/pmt.cpp:1049 tuneExt [eDVBServicePMTHandler] allocate Channel: res 0
00:20:45.0604 [ ] dvb_ci/dvbci.cpp:904 addPMTHandler [eDVBCIInterfaces] addPMTHandler 1:0:1:769E:41E:1:C00000:0:0:0:
00:20:45.0604 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=01
00:20:45.0605 [ ] dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!!
00:20:45.0605 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 5
00:20:45.0605 [ ] dvb/cahandler.cpp:267 registerService [eDVBCAService] new service 1:0:1:769E:41E:1:C00000:0:0:0:
00:20:45.0606 [ ] dvb/cahandler.cpp:285 registerService [eDVBCAService] add demux 2 to slot 0 service 1:0:1:769E:41E:1:C00000:0:0:0:
00:20:45.0606 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
00:20:45.0606 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
00:20:45.0616 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 6
00:20:45.0616 [ ] service/servicedvbstream.cpp:34 serviceEvent [eDVBServiceStream] tuned.. m_state 1 m_want_record 0
00:20:45.0617 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
00:20:45.0617 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=18
00:20:45.0627 [ ] dvb/dvb.cpp:2418 getDemux [eDVBChannel] getDemux cap=00
00:20:45.0628 [ ] dvb/demux.cpp:656 eDVBRecordStreamThread [eDVBRecordStreamThread] allocated 40 buffers of 192 kB
00:20:45.0628 [ ] service/servicedvbstream.cpp:154 doRecord [eDVBServiceStream] start streaming...
00:20:45.0629 [ ] service/servicedvbstream.cpp:337 recordCachedPids [eDVBServiceStream] no cached pids found
00:20:45.0629 < > service/servicedvbstream.cpp:207 doRecord [eDVBServiceStream] have 1 video stream(s) (0fa0), and 1 audio stream(s) (0fa1), and the pcr pid is 0fa0, and the text pid is ffffffff
00:20:45.0630 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0000
00:20:45.0630 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0012
00:20:45.0630 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0014
00:20:45.0630 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0fa0
00:20:45.0630 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0fa1
00:20:45.0636 [ ] base/ioprio.cpp:91 setIoPrio [setIoPrio] realtime level 7 ok
00:20:45.0636 [ ] dvb/filepush.cpp:542 thread [eFilePushThreadRecorder] THREAD START
00:20:45.0760 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux3
00:20:45.0761 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1038
00:20:45.0886 [ ] dvb/pmt.cpp:214 PATready [eDVBServicePMTHandler] PATready
00:20:45.0887 [ ] dvb/pmt.cpp:225 PATready [eDVBServicePMTHandler] PAT TSID: 0x041e (1054)
00:20:45.0887 [ ] dvb/pmt.cpp:254 PATready [eDVBServicePMTHandler] use pmtpid 0410 for service_id 769e
00:20:45.0888 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
00:20:45.0888 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=1040
00:20:45.0941 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux2
00:20:45.0942 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=0
00:20:45.0953 [ ] service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 5
00:20:45.0954 [ ] service/servicedvbstream.cpp:154 doRecord [eDVBServiceStream] start streaming...
00:20:45.0954 [ ] service/servicedvbstream.cpp:337 recordCachedPids [eDVBServiceStream] no cached pids found
00:20:45.0959 < > service/servicedvbstream.cpp:207 doRecord [eDVBServiceStream] have 1 video stream(s) (00b0), and 2 audio stream(s) (0090, 0091), and the pcr pid is 00b0, and the text pid is ffffffff
00:20:45.0960 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0091
00:20:45.0964 [ ] service/servicedvbstream.cpp:374 recordPids [eDVBServiceStream] ADD PID: 0410
00:20:45.0967 [ ] dvb_ci/dvbci.cpp:1030 gotPMT [eDVBCIInterfaces] gotPMT
00:20:45.0991 [ ] bsod.cpp:368 print_backtrace Backtrace:
00:20:45.0993 [ ] bsod.cpp:376 print_backtrace /usr/bin/enigma2(_Z17handleFatalSignaliP9siginfo_tPv) [0x85968]
00:20:45.1003 [ ] bsod.cpp:376 print_backtrace /lib/libc.so.6(__default_rt_sa_restorer) [0xB612EAD0]
00:20:45.1003 [ ] bsod.cpp:388 handleFatalSignal -------FATAL SIGNAL
dmesg
<6>[ 0.000004] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 2545165795328ns
<6>[ 0.000298] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
<6>[ 0.000306] pid_max: default: 32768 minimum: 301
<6>[ 0.000404] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.000410] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.005844] CPU: Testing write buffer coherency: ok
<6>[ 0.006057] CPU0: update cpu_power 1024
<6>[ 0.006064] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>[ 0.006195] Setting up static identity map for 0x6588a8 - 0x658900
<4>[ 0.008733] CPU1: Booted secondary processor
<6>[ 0.008751] CPU1: update cpu_power 1024
<6>[ 0.008754] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
<4>[ 0.009412] CPU2: Booted secondary processor
<6>[ 0.009423] CPU2: update cpu_power 1024
<6>[ 0.009425] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
<4>[ 0.010049] CPU3: Booted secondary processor
<6>[ 0.010060] CPU3: update cpu_power 1024
<6>[ 0.010063] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
<6>[ 0.010146] Brought up 4 CPUs
<6>[ 0.010164] SMP: Total of 4 processors activated.
<6>[ 0.010169] CPU: All CPU(s) started in SVC mode.
<6>[ 0.010572] devtmpfs: initialized
<6>[ 0.014256] VFP support v0.3: implementor 42 architecture 4 part 00 variant 0 rev 0
<6>[ 0.015249] regulator-dummy: no parameters
<6>[ 0.015435] NET: Registered protocol family 16
<6>[ 0.017600] DMA: preallocated 2048 KiB pool for atomic coherent allocations
<6>[ 0.018396] cpuidle: using governor ladder
<6>[ 0.018400] cpuidle: using governor menu
<4>[ 0.021559] irq: no irq domain found for /rdb/interrupt-controller@f040a780 !
<4>[ 0.021699] irq: no irq domain found for /rdb/interrupt-controller@f0417280 !
<4>[ 0.025574] irq: no irq domain found for /rdb/interrupt-controller@f03e1a00 !
<6>[ 0.025838] syscon f0404000.syscon: regmap [mem 0xf0404000-0xf040451b] registered
<6>[ 0.026609] syscon f0404100.syscon: regmap [mem 0xf0404100-0xf040415b] registered
<6>[ 0.026758] syscon f040415c.syscon: regmap [mem 0xf040415c-0xf040419b] registered
<6>[ 0.026899] syscon f0410700.syscon: regmap [mem 0xf0410700-0xf041070b] registered
<6>[ 0.027038] syscon f041070c.syscon: regmap [mem 0xf041070c-0xf0410713] registered
<6>[ 0.027193] syscon f1101004.syscon: regmap [mem 0xf1101004-0xf1101403] registered
<6>[ 0.027335] syscon f1181004.syscon: regmap [mem 0xf1181004-0xf1181403] registered
<6>[ 0.027482] syscon f1201004.syscon: regmap [mem 0xf1201004-0xf1201403] registered
<6>[ 0.027615] syscon f0404080.syscon: regmap [mem 0xf0404080-0xf0404083] registered
<6>[ 0.027751] syscon f04040a4.syscon: regmap [mem 0xf04040a4-0xf04040a7] registered
<6>[ 0.027894] syscon f03e0154.syscon: regmap [mem 0xf03e0154-0xf03e0157] registered
<6>[ 0.028042] syscon f03e0354.syscon: regmap [mem 0xf03e0354-0xf03e0357] registered
<6>[ 0.028180] syscon f03e0400.syscon: regmap [mem 0xf03e0400-0xf03e0403] registered
<4>[ 0.028739] irq: no irq domain found for /rdb/interrupt-controller@f0417280 !
<6>[ 0.029290] syscon f03e2400.syscon: regmap [mem 0xf03e2400-0xf03e27ff] registered
<6>[ 0.029437] syscon f0452000.syscon: regmap [mem 0xf0452000-0xf04520ff] registered
<6>[ 0.029733] No ATAGs?
<6>[ 0.029751] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.029756] hw-breakpoint: maximum watchpoint size is 8 bytes.
<6>[ 0.029891] Broadcom Brahma-B15 readahead cache at: 0xfc3e2478
<6>[ 0.045444] bio: create slab <bio-0> at 0
<5>[ 0.046335] SCSI subsystem initialized
<7>[ 0.046544] libata version 3.00 loaded.
<6>[ 0.046929] usbcore: registered new interface driver usbfs
<6>[ 0.047008] usbcore: registered new interface driver hub
<6>[ 0.047096] usbcore: registered new device driver usb
<6>[ 0.047220] Linux video capture interface: v2.00
<6>[ 0.047430] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.047434] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
<6>[ 0.047489] PTP clock support registered
<6>[ 0.048073] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.048818] cfg80211: Calling CRDA to update world regulatory domain
<6>[ 0.049391] brcm-pci f0460000.pcie: adjusting to legacy (broken) pcie DT
<6>[ 0.049565] brcm-pci f0490000.pcie: adjusting to legacy (broken) pcie DT
<6>[ 0.149861] brcm-pci f0460000.pcie: link down
<6>[ 0.249958] brcm-pci f0490000.pcie: link down
<6>[ 0.250011] Switched to clocksource arch_sys_counter
<5>[ 0.250201] FS-Cache: Loaded
<4>[ 0.259201] thermal thermal_zone0: failed to read out thermal zone 0
<6>[ 0.259287] NET: Registered protocol family 2
<6>[ 0.259688] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.259712] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.259756] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.259820] TCP: reno registered
<6>[ 0.259827] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.259839] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.259958] NET: Registered protocol family 1
<6>[ 0.260172] RPC: Registered named UNIX socket transport module.
<6>[ 0.260177] RPC: Registered udp transport module.
<6>[ 0.260180] RPC: Registered tcp transport module.
<6>[ 0.260184] RPC: Registered tcp NFSv4.1 backchannel transport module.
<7>[ 0.260190] PCI: CLS 0 bytes, default 64
<6>[ 0.260445] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
<6>[ 0.261775] futex hash table entries: 1024 (order: 4, 65536 bytes)
<4>[ 0.262489] bounce pool size: 64 pages
<5>[ 0.263049] NFS: Registering the id_resolver key type
<5>[ 0.263076] Key type id_resolver registered
<5>[ 0.263080] Key type id_legacy registered
<6>[ 0.263090] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
<6>[ 0.263095] Installing knfsd (copyright (C) 1996 [email protected]).
<5>[ 0.263251] FS-Cache: Netfs 'cifs' registered for caching
<5>[ 0.263305] Key type cifs.spnego registered
<6>[ 0.263449] fuse init (API version 7.22)
<6>[ 0.263597] SGI XFS with security attributes, realtime, large block/inode numbers, no debug enabled
<6>[ 0.263920] msgmni has been set to 703
<6>[ 0.264761] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ 0.264768] io scheduler noop registered
<6>[ 0.264772] io scheduler deadline registered
<6>[ 0.264793] io scheduler cfq registered (default)
<6>[ 0.265028] brcm-gisb-arb f0400000.gisb-arb: registered mem: fc400000, irqs: 258, 259
<6>[ 0.295436] brcm-waketimer f0417580.waketimer: registered, with irq 260
<6>[ 0.295713] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
<6>[ 0.297126] f040ab00.serial: ttyS0 at MMIO 0xf040ab00 (irq = 107, base_baud = 5062500) is a 16550A
<6>[ 1.136214] console [ttyS0] enabled
<6>[ 1.140123] f040ab40.serial: ttyS1 at MMIO 0xf040ab40 (irq = 108, base_baud = 5062500) is a 16550A
<6>[ 1.149470] f040ab80.serial: ttyS2 at MMIO 0xf040ab80 (irq = 109, base_baud = 5062500) is a 16550A
<6>[ 1.161984] loop: module loaded
<3>[ 1.165736] ahci brcmstb-ahci.0: can't get clock
<6>[ 1.170447] ahci brcmstb-ahci.0: SSS flag set, parallel bus scan disabled
<6>[ 1.188025] ahci brcmstb-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
<6>[ 1.196656] ahci brcmstb-ahci.0: flags: 64bit ncq sntf stag pm clo pmp slum part
<6>[ 1.206310] scsi0 : ahci_platform
<6>[ 1.209964] scsi1 : ahci_platform
<6>[ 1.213520] ata1: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x100 irq 62
<6>[ 1.221455] ata2: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x180 irq 62
<6>[ 1.230628] spi_brcmstb f03e3400.spi: 1-lane output, 3-byte address
<6>[ 1.237022] spi_brcmstb f03e3400.spi: master is unqueued, this is deprecated
<4>[ 1.244338] m25p80 spi32766.0: found mx25l3255e, expected m25p80
<6>[ 1.250364] m25p80 spi32766.0: mx25l3255e (4096 Kbytes)
<5>[ 1.255620] 5 ofpart partitions found on MTD device spi32766.0
<5>[ 1.261465] Creating 5 MTD partitions on "spi32766.0":
<5>[ 1.266622] 0x000000000000-0x000000200000 : "flash0.bolt"
<5>[ 1.272715] 0x000000200000-0x000000210000 : "flash0.macadr"
<5>[ 1.278929] 0x000000210000-0x000000220000 : "flash0.nvram"
<5>[ 1.285066] 0x000000220000-0x000000230000 : "flash0.devtree"
<5>[ 1.291381] 0x000000000000-0x000000400000 : "flash0"
<6>[ 1.298056] libphy: Fixed MDIO Bus: probed
<6>[ 1.304603] libphy: unimac MII bus: probed
<6>[ 1.312953] unimac-mdio f0b403c0.mdio: Broadcom UniMAC MDIO bus at 0xfcb403c0
<6>[ 1.320929] brcm-systemport f04a0000.ethernet: Broadcom SYSTEMPORTv 1.00 at 0xfc4a0000 (irqs: 54, 55, TXQs: 32, RXQs: 1)
<6>[ 1.334496] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
<6>[ 1.339020] ata1: SATA link down (SStatus 0 SControl 300)
<6>[ 1.345750] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
<6>[ 1.352251] xhci-brcm: xHCI BRCM driver
<6>[ 1.356185] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
<6>[ 1.362030] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 1
<6>[ 1.370171] xhci-brcm f0471000.xhci_v2: irq 115, io mem 0xf0471000
<6>[ 1.376893] hub 1-0:1.0: USB hub found
<3>[ 1.380673] hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
<6>[ 1.387936] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
<6>[ 1.393750] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 2
<6>[ 1.402096] hub 2-0:1.0: USB hub found
<6>[ 1.405875] hub 2-0:1.0: 2 ports detected
<6>[ 1.410298] ehci-brcm: EHCI BRCM driver
<6>[ 1.414219] ehci-brcm f0470300.ehci_v2: EHCI Host Controller
<6>[ 1.420049] ehci-brcm f0470300.ehci_v2: new USB bus registered, assigned bus number 3
<6>[ 1.438022] ehci-brcm f0470300.ehci_v2: irq 111, io mem 0xf0470300
<6>[ 1.450018] ehci-brcm f0470300.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.456715] hub 3-0:1.0: USB hub found
<6>[ 1.459023] ata2: SATA link down (SStatus 0 SControl 300)
<6>[ 1.465900] hub 3-0:1.0: 1 port detected
<6>[ 1.470048] ehci-brcm f0470500.ehci_v2: EHCI Host Controller
<6>[ 1.475879] ehci-brcm f0470500.ehci_v2: new USB bus registered, assigned bus number 4
<6>[ 1.493850] ehci-brcm f0470500.ehci_v2: irq 112, io mem 0xf0470500
<6>[ 1.506017] ehci-brcm f0470500.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.512722] hub 4-0:1.0: USB hub found
<6>[ 1.516501] hub 4-0:1.0: 1 port detected
<6>[ 1.520644] ehci-brcm f0480300.ehci_v2: EHCI Host Controller
<6>[ 1.526475] ehci-brcm f0480300.ehci_v2: new USB bus registered, assigned bus number 5
<6>[ 1.544427] ehci-brcm f0480300.ehci_v2: irq 117, io mem 0xf0480300
<6>[ 1.556016] ehci-brcm f0480300.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.562697] hub 5-0:1.0: USB hub found
<6>[ 1.566477] hub 5-0:1.0: 1 port detected
<6>[ 1.570619] ehci-brcm f0480500.ehci_v2: EHCI Host Controller
<6>[ 1.576449] ehci-brcm f0480500.ehci_v2: new USB bus registered, assigned bus number 6
<6>[ 1.594397] ehci-brcm f0480500.ehci_v2: irq 118, io mem 0xf0480500
<6>[ 1.606017] ehci-brcm f0480500.ehci_v2: USB 2.0 started, EHCI 1.00
<6>[ 1.612673] hub 6-0:1.0: USB hub found
<6>[ 1.616452] hub 6-0:1.0: 1 port detected
<6>[ 1.620782] ohci-brcm: OHCI BRCM driver
<6>[ 1.624693] ohci-brcm f0470400.ohci_v2: BRCM OHCI controller
<6>[ 1.630525] ohci-brcm f0470400.ohci_v2: new USB bus registered, assigned bus number 7
<6>[ 1.638405] ohci-brcm f0470400.ohci_v2: irq 113, io mem 0xf0470400
<6>[ 1.699484] hub 7-0:1.0: USB hub found
<6>[ 1.703305] hub 7-0:1.0: 1 port detected
<6>[ 1.707448] ohci-brcm f0470600.ohci_v2: BRCM OHCI controller
<6>[ 1.713287] ohci-brcm f0470600.ohci_v2: new USB bus registered, assigned bus number 8
<6>[ 1.721169] ohci-brcm f0470600.ohci_v2: irq 114, io mem 0xf0470600
<6>[ 1.782487] hub 8-0:1.0: USB hub found
<6>[ 1.786265] hub 8-0:1.0: 1 port detected
<6>[ 1.790407] ohci-brcm f0480400.ohci_v2: BRCM OHCI controller
<6>[ 1.796236] ohci-brcm f0480400.ohci_v2: new USB bus registered, assigned bus number 9
<6>[ 1.804119] ohci-brcm f0480400.ohci_v2: irq 119, io mem 0xf0480400
<6>[ 1.865480] hub 9-0:1.0: USB hub found
<6>[ 1.869262] hub 9-0:1.0: 1 port detected
<6>[ 1.873394] ohci-brcm f0480600.ohci_v2: BRCM OHCI controller
<6>[ 1.874036] usb 5-1: new high-speed USB device number 2 using ehci-brcm
<6>[ 1.885842] ohci-brcm f0480600.ohci_v2: new USB bus registered, assigned bus number 10
<6>[ 1.893815] ohci-brcm f0480600.ohci_v2: irq 120, io mem 0xf0480600
<6>[ 1.955489] hub 10-0:1.0: USB hub found
<6>[ 1.959357] hub 10-0:1.0: 1 port detected
<6>[ 1.963698] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[ 1.970247] ehci-pci: EHCI PCI platform driver
<6>[ 1.974805] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
<6>[ 1.981011] ohci-pci: OHCI PCI platform driver
<6>[ 1.985761] usbcore: registered new interface driver usb-storage
<6>[ 1.991964] mousedev: PS/2 mouse device common for all mice
<6>[ 1.997772] hub 5-1:1.0: USB hub found
<6>[ 1.997992] i2c /dev entries driver
<6>[ 1.998406] IR NEC protocol handler initialized
<6>[ 1.998408] IR RC5(x) protocol handler initialized
<6>[ 1.998410] IR RC6 protocol handler initialized
<6>[ 1.998411] IR JVC protocol handler initialized
<6>[ 1.998413] IR Sony protocol handler initialized
<6>[ 1.998414] IR RC5 (streamzap) protocol handler initialized
<6>[ 1.998416] IR SANYO protocol handler initialized
<6>[ 1.998417] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 2.044261] brcmstb_thermal f04d1500.thermal: registered AVS TMON of-sensor driver
<6>[ 2.044278] hub 5-1:1.0: 4 ports detected
<4>[ 2.056061] cpufreq_cpu0: failed to get cpu0 regulator: -19
<6>[ 2.061896] sdhci: Secure Digital Host Controller Interface driver
<6>[ 2.068093] sdhci: Copyright(c) Pierre Ossman
<6>[ 2.072460] sdhci-pltfm: SDHCI platform and OF driver helper
<6>[ 2.079243] mmc0: no vqmmc regulator found
<6>[ 2.083352] mmc0: no vmmc regulator found
<6>[ 2.118016] mmc0: SDHCI controller on f03e0200.sdhci [f03e0200.sdhci] using ADMA
<6>[ 2.125712] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 2.136586] usbcore: registered new interface driver usbhid
<6>[ 2.142174] usbhid: USB HID core driver
<6>[ 2.146749] TCP: cubic registered
<6>[ 2.150136] NET: Registered protocol family 10
<6>[ 2.159156] NET: Registered protocol family 17
<5>[ 2.163725] Distributed Switch Architecture driver version 0.1
<6>[ 2.171638] sys0[0]: detected a Broadcom Starfighter 2 switch
<6>[ 2.177605] Starfighter 2 top: 4.00, core: 2.00 base: 0xfcb00000, IRQs: 56, 57
<6>[ 2.186996] libphy: dsa slave smi: probed
<6>[ 2.236661] mmc0: BKOPS_EN bit is not set
<6>[ 2.246927] mmc0: new high speed MMC card at address 0001
<6>[ 2.249017] f0b403c0.mdio:05: Broadcom BCM7445 PHY revision: 0x10, patch: 3
<6>[ 2.259555] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
<6>[ 2.264188] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
<6>[ 2.270214] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
<6>[ 2.276232] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
<6>[ 2.285064] mmcblk0: p1 p2 p3 p4
<6>[ 2.290042] mmcblk0boot1: unknown partition table
<6>[ 2.295598] mmcblk0boot0: unknown partition table
<6>[ 2.368149] usb 5-1.1: new high-speed USB device number 3 using ehci-brcm
<6>[ 2.475040] attached PHY at address 5 [Broadcom BCM7445]
<3>[ 2.480896] net eth0: PHY already attached
<5>[ 2.485205] Key type dns_resolver registered
<5>[ 2.489592] Registering SWP/SWPB emulation handler
<6>[ 2.494830] regulator-dummy: disabling
<6>[ 2.501842] ALSA device list:
<6>[ 2.504824] No soundcards found.
<4>[ 2.508914] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
<6>[ 2.524454] EXT4-fs (mmcblk0p4): mounted filesystem with journalled data mode. Opts: data=journal
<6>[ 2.533365] VFS: Mounted root (ext4 filesystem) on device 179:4.
<6>[ 2.535157] usb 5-1.2: new full-speed USB device number 4 using ehci-brcm
<6>[ 2.550055] devtmpfs: mounted
<6>[ 2.553266] Freeing unused kernel memory: 268K (c0889000 - c08cc000)
<5>[ 3.035971] random: nonblocking pool is initialized
<6>[ 3.246200] EXT4-fs (mmcblk0p4): re-mounted. Opts: nodelalloc,data=journal
<6>[ 4.625278] usb 5-1.1: USB disconnect, device number 3
<6>[ 4.672096] usbcore: registered new interface driver dbus_usbdev
<6>[ 4.747649] IPv6: ADDRCONF(NETDEV_UP): sys0: link is not ready
<4>[ 4.764440] bcm_event: module license 'Proprietary' taints kernel.
<4>[ 4.770642] Disabling lock debugging due to kernel taint
<6>[ 4.834168] usb 5-1.1: new high-speed USB device number 5 using ehci-brcm
<4>[ 4.929770] Dongle Host Driver, version 1.363.110.16 (r620666)
<4>[ 4.929770] Compiled in on Oct 27 2016 at 18:59:23
<4>[ 4.942061] Register interface [wlan3] MAC: 00:90:4c:11:22:33
<4>[ 4.942061]
<6>[ 6.750106] libphy: fixed-0:00 - Link is Up - 1000/Full
<6>[ 6.755383] IPv6: ADDRCONF(NETDEV_CHANGE): sys0: link becomes ready
<6>[ 11.409635] DVB: registering new adapter (_vuplus_ultimo4k_)
<4>[ 11.730093] bcm7444: hotplug_callback():
<4>[ 11.730093] Hotplug - status.connected 1:0:1
<4>[ 11.737101] bcm7444: hotplug_callback():
<4>[ 11.737101] Hotplug - connecting HDMI to display 0xe
<6>[ 11.957012] brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
<4>[ 12.065029] [MPVR]: >> misc_pvr_init
<4>[ 12.071246] [VID]: 6bcm7335_video_init
<4>[ 12.108637] [AUD]: 6bcm7335_audio_init
<4>[ 12.113096] [AUD]: >> bcm_audio_capture_init
<4>[ 12.122046] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.142634] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.150384] bcm7444: hotplug_callback():
<4>[ 12.150930] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<4>[ 12.160142]
<4>[ 12.160142] Hotplug - status.connected 1:1:3
<6>[ 12.162614] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.177754] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.193815] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.201910] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.219363] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.228389] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.247890] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.256121] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.272530] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.280468] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.298262] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.306212] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 12.322108] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.330517] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0
<6>[ 12.336397] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.344616] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0
<6>[ 12.350507] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 12.358584] -----------10 slot is empty ----------------
<4>[ 12.363979] -----------11 slot is empty ----------------
<4>[ 12.369337] -----------12 slot is empty ----------------
<4>[ 12.374910] -----------13 slot is empty ----------------
<4>[ 12.380250] -----------14 slot is empty ----------------
<4>[ 12.385665] -----------15 slot is empty ----------------
<4>[ 12.391203] -----------16 slot is empty ----------------
<4>[ 12.396552] -----------17 slot is empty ----------------
<4>[ 12.401888] bcm7444: bcm7335_frontend_init(): vtuner1 : 11 m_nfbc=0 m_fbc=10
<4>[ 12.426637] BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
<4>[ 12.434611] BKNI_Malloc(linuxkernel) top users:
<4>[ 12.434611] blocks, bytes, filename:line
<4>[ 12.443623] 901, 198356, BSEAV/lib/utils/balloc.c:31
<6>[ 12.491629] input: dreambox advanced remote control (native) as /devices/virtual/input/input0
<6>[ 12.509920] [LCD]: registered
<4>[ 12.845443] GPIO Init...
<6>[ 12.858344] [CI]: registered ci0
<6>[ 12.862087] [CI]: registered ci1
<6>[ 12.870476] [CI]: CI interface initialised
<6>[ 12.870476]
<6>[ 12.884861] [DFP]: registered dbox fp
<6>[ 12.893257] [SC]: registered sci0
<6>[ 12.897237] [SC]: registered sci1
<4>[ 13.060015] system_time_set wakeup mode get
<4>[ 13.124075] system_time_set wakeup mode get 0xc4
<4>[ 13.159088] BKNI_P_GetTrackAllocEntry_resize: resizing from 8704->14080
<4>[ 13.167678] BKNI_Malloc(linuxkernel) top users:
<4>[ 13.167678] blocks, bytes, filename:line
<4>[ 13.176676] 2277, 497532, BSEAV/lib/utils/balloc.c:31
<4>[ 13.308278] FPGA Version 0x11
<6>[ 13.435251] wakeup_drv: Initializing wakeup driver
<6>[ 13.440412] wakeup_drv: Initialization complete
<4>[ 13.535869] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 13.540021] [VID]: VIDEO_SELECT_SOURCE 1 0
<4>[ 13.544287] [VID]: VIDEO_PLAY 1 2 0
<4>[ 13.553776] [VID]: VIDEO_CONTINUE 1 1
<4>[ 13.557653] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[ 13.837597] [VID]: VIDEO_STOP 0 1
<4>[ 13.853184] [VID]: VIDEO_SELECT_SOURCE 0 0
<6>[ 13.911178] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
<6>[ 15.262840] Bluetooth: Core ver 2.18
<6>[ 15.266756] NET: Registered protocol family 31
<6>[ 15.271233] Bluetooth: HCI device and connection manager initialized
<6>[ 15.277631] Bluetooth: HCI socket layer initialized
<6>[ 15.282535] Bluetooth: L2CAP socket layer initialized
<6>[ 15.287630] Bluetooth: SCO socket layer initialized
<6>[ 15.534070] libphy: f0b403c0.mdio:05 - Link is Down
<4>[ 17.365366] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 17.369540] [VID]: VIDEO_SELECT_SOURCE 1 0
<4>[ 17.373788] [VID]: VIDEO_PLAY 1 2 0
<4>[ 17.382919] [VID]: VIDEO_CONTINUE 1 1
<4>[ 17.386832] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<6>[ 17.566038] libphy: f0b403c0.mdio:05 - Link is Up - 1000/Full
<6>[ 17.571835] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
<4>[ 17.667562] [VID]: VIDEO_STOP 0 1
<4>[ 17.682796] [VID]: VIDEO_SELECT_SOURCE 0 0
<3>[ 17.778969] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 17.828681] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 17.881912] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 17.932231] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 17.988663] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.039056] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.087594] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<3>[ 18.136644] BRCM brcm_dvb0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 21
<4>[ 19.257365] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0 mode=1
<6>[ 19.263879] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 20.277351] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0 mode=1
<6>[ 20.283857] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 22.984301] [AUD]: AUDIO_SET_MUTE 0
<4>[ 22.988312] [AUD]: AUDIO_SET_MIXER -770294136
<4>[ 22.992792] [AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[ 22.997869] [AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
<4>[ 23.004506] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 29.864393] [AUD]: AUDIO_SET_MIXER -770294136
<4>[ 29.868880] [AUD]: AUDIO_SET_MIXER : amixl 32, amixr 32
<4>[ 29.874135] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 29.881121] [AUD]: AUDIO_SET_MIXER : next left volume -2355, right volume -2355
<4>[ 30.176496] FE tune
<4>[ 30.660488] [AUD]: AUDIO_SELECT_SOURCE 0
<4>[ 30.665153] [AUD]: AUDIO_SET_BYPASS_MODE 0
<4>[ 30.669618] [AUD]: AC3 downmix 0 state : 0
<4>[ 30.673858] [AUD]: AUDIO_PAUSE 0
<4>[ 30.677226] [AUD]: AUDIO_PLAY 0 decoder start : 0
<4>[ 30.695135] [VID]: VIDEO_SELECT_SOURCE 0 0
<4>[ 30.699455] [VID]: VIDEO_GET_SIZE src w: 1920 h:1080 display w:1920 h:1080
<4>[ 30.706365] [VID]: VIDEO_GET_SIZE aspect: 1 3
<4>[ 30.710875] [VID]: VIDEO_SET_STREAMTYPE 1
<4>[ 30.715242] [VID]: VIDEO_FREEZE 0 0
<4>[ 30.718863] [VID]: VIDEO_PLAY 0 5 2
<4>[ 30.729402] [VID]: VIDEO_SLOWMOTION 0 1
<4>[ 30.734495] [VID]: VIDEO_FAST_FORWARD 0 1 0
<4>[ 30.740299] [VID]: VIDEO_CONTINUE 0 1
<4>[ 30.745791] [AUD]: AUDIO_CONTINUE 0 1 aph=0xd2463600
<4>[ 30.751869] [AUD]: Mute : 0
<4>[ 30.756272] [AUD]: AUDIO_CHANNEL_SELECT 0
<4>[ 62.473572] [VID]: VIDEO_STOP 1 1
<4>[ 62.477480] [AUD]: AUDIO_STOP 0
<4>[ 62.489115] [AUD]: AUDIO_CONTINUE 0 0 aph=0x0
<4>[ 62.493559] [AUD]: AUDIO_CONTINUE aph=0 0 0
<4>[ 74.120932] FE tune
<4>[ 75.161367] FE tune
<4>[ 76.407669] FE tune
<4>[ 89.296535] FE tune
<4>[ 89.507117] FE tune
<4>[ 90.117159] FE tune
<4>[ 104.114692] FE tune
<4>[ 104.286559] FE tune
<4>[ 105.157452] FE tune
<4>[ 105.366828] FE tune
<4>[ 119.134417] FE tune
<4>[ 119.291032] FE tune
<4>[ 119.307565] FE tune
<4>[ 120.119827] FE tune
<4>[ 134.122434] FE tune
<4>[ 134.296391] FE tune
<4>[ 149.118731] FE tune
<4>[ 149.506514] FE tune
<4>[ 182.184332] FE tune
<4>[ 182.397402] FE tune
<4>[ 224.252071] FE tune
<4>[ 224.637922] FE tune
<4>[ 225.235898] FE tune
<4>[ 239.247540] FE tune
<4>[ 240.275683] FE tune
<4>[ 240.484676] FE tune
<4>[ 254.259487] FE tune
<4>[ 254.435862] FE tune
<4>[ 254.653921] FE tune
<4>[ 255.235281] FE tune
<4>[ 269.250446] FE tune
<4>[ 269.433996] FE tune
<4>[ 269.676751] FE tune
<4>[ 270.274893] FE tune
<4>[ 303.592762] FE tune
<4>[ 303.754273] FE tune
<4>[ 303.964208] FE tune
<4>[ 337.063287] FE tune
<4>[ 337.266520] FE tune
<4>[ 337.280898] FE tune
<4>[ 338.151771] FE tune
<4>[ 342.092796] FE tune
<4>[ 342.273173] FE tune
<4>[ 343.203633] FE tune
<4>[ 343.282918] FE tune
<4>[ 347.109491] FE tune
<4>[ 347.283022] FE tune
<4>[ 347.493107] FE tune
<4>[ 348.113862] FE tune
<4>[ 352.102193] FE tune
<4>[ 352.273165] FE tune
<4>[ 352.487102] FE tune
<4>[ 353.073396] FE tune
<4>[ 357.109539] FE tune
<4>[ 400.968163] FE tune
<4>[ 413.575598] FE tune
<4>[ 429.707391] FE tune
<4>[ 448.578828] FE tune
<4>[ 469.527667] FE tune
<4>[ 469.694433] FE tune
<4>[ 469.964088] FE tune
<4>[ 470.512021] FE tune
<4>[ 474.533866] FE tune
<4>[ 474.699214] FE tune
<4>[ 475.558236] FE tune
<4>[ 479.514987] FE tune
<4>[ 479.701258] FE tune
<4>[ 479.913744] FE tune
<4>[ 480.512594] FE tune
<4>[ 480.721389] FE tune
<4>[ 484.577067] FE tune
<4>[ 489.534835] FE tune
<4>[ 489.693440] FE tune
<4>[ 518.108211] FE tune
<4>[ 518.270879] FE tune
<4>[ 570.907311] FE tune
<4>[ 570.916688] FE tune
<4>[ 570.929780] FE tune
<4>[ 571.141182] FE tune
<6>[ 571.865329] TCP: TCP: Possible SYN flooding on port 8001. Sending cookies. Check SNMP counters.
<4>[ 571.887337] FE tune
