Bug general problema al cambiar el skin del lcd apagado
ALZIREÑO
Versión de OpenSpa:
7.3.005
cuando cambio skin en la pantalla LCD para la hora, osea el reloj que sale cuando esta apagago, se reinicia con pantallazo verde.
Características especiales:
nignuna
Se adjunta Crash-log: Si/ No
si
openSPA Enigma2 crash log
crashdate=lun ene 21 16:55:49 2019
compiledate=Jan 16 2019
skin=Nacht/skin.xml
sourcedate=2019-01-12
branch=master
rev=4c1add7
component=Enigma2
stbmodel=solo4k
stbmodel=dm8000
kernelcmdline=root=/dev/mmcblk0p4 rootwait rw rootflags=data=journal debug coherent_pool=2M bmem=633m@387m bmem=499m@2573m
nimsockets=NIM Socket 0:
imageversion=box_type=vusolo4k
imageissue=Welcome to openSPA for %h
foBarGenerics.py:245 actionA KEY: 139 0 KEY_MENU MENU
16:55:39.5821 { } Components/ActionMap.py:46 action [ActionMap] InfobarMenuActions mainMenu
16:55:39.6197 { } skin.py:1506 readSkin [SKIN] processing screen spazeTeamMenu:
16:55:39.6271 [ ] gdi/epng.cpp:24 loadPNG [ePNG] couldn't open /usr/lib/enigma2/python/Plugins/Extensions/spazeMenu/image/nm_sel-fs8.png
16:55:39.6273 { E } skin.py:374 loadPixmap pixmap file /usr/lib/enigma2/python/Plugins/Extensions/spazeMenu/image/nm_sel-fs8.png not found!
16:55:39.6305 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element estado2 in <class 'plugin.plugin.spazeTeamMenu'>
16:55:39.6313 { W } skin.py:422 applyAll [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6318 { W } skin.py:422 applyAll [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6321 { W } skin.py:422 applyAll [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6323 { W } skin.py:422 applyAll [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6325 { W } skin.py:422 applyAll [SKIN] Attribute "valign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6327 { W } skin.py:422 applyAll [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6330 { W } skin.py:422 applyAll [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6335 { W } skin.py:422 applyAll [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
16:55:39.6413 { } skin.py:1506 readSkin [SKIN] processing screen SimpleSummary:
16:55:39.6459 { } Screens/Screen.py:150 show [SCREENNAME] ['spazeTeamMenu_summary', 'SimpleSummary']
16:55:39.6466 { } Screens/Screen.py:150 show [SCREENNAME] spazeTeamMenu
16:55:39.8102 { } skin.py:1506 readSkin [SKIN] processing screen spzSubMenu:
16:55:39.8126 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element barrascroll_arr in <class 'plugin.plugin.spzSubMenu'>
16:55:39.8132 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element barrascroll_abj in <class 'plugin.plugin.spzSubMenu'>
16:55:39.8139 { W } skin.py:422 applyAll [SKIN] Attribute "valign" with value "bottom" in object of type "eListbox" is not implemented
16:55:39.8151 { } Screens/Screen.py:150 show [SCREENNAME] spzSubMenu
16:55:39.8213 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 8b 1
16:55:39.8231 { } Screens/InfoBarGenerics.py:245 actionA KEY: 139 1 KEY_MENU MENU
16:55:40.5918 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
16:55:40.5931 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 0 KEY_UP UP
16:55:40.5934 { } Components/ActionMap.py:46 action [ActionMap] WizardActions up
16:55:40.7073 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
16:55:40.7086 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 1 KEY_UP UP
16:55:42.9245 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
16:55:42.9258 { } Screens/InfoBarGenerics.py:245 actionA KEY: 352 0 KEY_OK OK
16:55:42.9260 { } Components/ActionMap.py:46 action [ActionMap] WizardActions ok
16:55:42.9427 { } skin.py:1506 readSkin [SKIN] processing screen menu_setup:
16:55:42.9498 { E } skin.py:1340 process_widget component with name 'key_red' was not found in skin of screen 'menu_setup'!
16:55:42.9562 [ ] gdi/epng.cpp:24 loadPNG [ePNG] couldn't open /usr/share/enigma2/skin_default/Nacht/e1/sel80.png
16:55:42.9564 { E } skin.py:374 loadPixmap pixmap file /usr/share/enigma2/skin_default/Nacht/e1/sel80.png not found!
16:55:42.9565 { W } skin.py:427 applyAll [Skin] attribute "selectionPixmap" with wrong (or unknown) value "/usr/share/enigma2/skin_default/Nacht/e1/sel80.png" in object of type "eListbox"
16:55:42.9596 { W } skin.py:422 applyAll [SKIN] Attribute "render" with value "Label" in object of type "eLabel" is not implemented
16:55:42.9601 { W } skin.py:422 applyAll [SKIN] Attribute "render" with value "Label" in object of type "eLabel" is not implemented
16:55:42.9605 { W } skin.py:422 applyAll [SKIN] Attribute "render" with value "Label" in object of type "eLabel" is not implemented
16:55:42.9612 [ E ] gdi/accel.cpp:463 accelAlloc [gAccel] accel alloc failed
16:55:42.9612 [ E ] gdi/gpixmap.cpp:216 gSurface [gSurface] ERROR: accelAlloc failed
16:55:43.0075 { } skin.py:1506 readSkin [SKIN] processing screen MenuSummary:
16:55:43.0147 { } Screens/Screen.py:150 show [SCREENNAME] MenuSummary
16:55:43.0155 { } Screens/Screen.py:150 show [SCREENNAME] ['menu_setup', 'Menu']
16:55:43.0377 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 160 1
16:55:43.0391 { } Screens/InfoBarGenerics.py:245 actionA KEY: 352 1 KEY_OK OK
16:55:43.5636 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
16:55:43.5649 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 0 KEY_DOWN DOWN
16:55:43.5652 { } Components/ActionMap.py:46 action [ActionMap] WizardActions down
16:55:43.6774 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
16:55:43.6787 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 1 KEY_DOWN DOWN
16:55:43.8138 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
16:55:43.8148 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 0 KEY_DOWN DOWN
16:55:43.8150 { } Components/ActionMap.py:46 action [ActionMap] WizardActions down
16:55:43.9273 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
16:55:43.9286 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 1 KEY_DOWN DOWN
16:55:44.0586 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
16:55:44.0600 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 0 KEY_DOWN DOWN
16:55:44.0602 { } Components/ActionMap.py:46 action [ActionMap] WizardActions down
16:55:44.1774 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
16:55:44.1787 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 1 KEY_DOWN DOWN
16:55:44.6002 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
16:55:44.6016 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 0 KEY_DOWN DOWN
16:55:44.6018 { } Components/ActionMap.py:46 action [ActionMap] WizardActions down
16:55:44.7174 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
16:55:44.7187 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 1 KEY_DOWN DOWN
16:55:45.2229 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
16:55:45.2243 { } Screens/InfoBarGenerics.py:245 actionA KEY: 352 0 KEY_OK OK
16:55:45.2245 { } Components/ActionMap.py:46 action [ActionMap] WizardActions ok
16:55:45.2246 { W } Components/ActionMap.py:53 action [ActionMap] unknown action WizardActions/ok! typo in keymap?
16:55:45.2247 { } Components/ActionMap.py:46 action [ActionMap] OkCancelActions ok
16:55:45.2711 { } skin.py:1506 readSkin [SKIN] processing screen menu_system:
16:55:45.2743 { E } skin.py:1340 process_widget component with name 'key_red' was not found in skin of screen 'menu_system'!
16:55:45.2815 [ ] gdi/epng.cpp:24 loadPNG [ePNG] couldn't open /usr/share/enigma2/skin_default/Nacht/e1/sel80.png
16:55:45.2816 { E } skin.py:374 loadPixmap pixmap file /usr/share/enigma2/skin_default/Nacht/e1/sel80.png not found!
16:55:45.2817 { W } skin.py:427 applyAll [Skin] attribute "selectionPixmap" with wrong (or unknown) value "/usr/share/enigma2/skin_default/Nacht/e1/sel80.png" in object of type "eListbox"
16:55:45.2841 { W } skin.py:422 applyAll [SKIN] Attribute "render" with value "Label" in object of type "eLabel" is not implemented
16:55:45.2846 { W } skin.py:422 applyAll [SKIN] Attribute "render" with value "Label" in object of type "eLabel" is not implemented
16:55:45.2850 { W } skin.py:422 applyAll [SKIN] Attribute "render" with value "Label" in object of type "eLabel" is not implemented
16:55:45.2857 [ E ] gdi/accel.cpp:463 accelAlloc [gAccel] accel alloc failed
16:55:45.2858 [ E ] gdi/gpixmap.cpp:216 gSurface [gSurface] ERROR: accelAlloc failed
16:55:45.3223 [ E ] gdi/accel.cpp:463 accelAlloc [gAccel] accel alloc failed
16:55:45.3223 [ E ] gdi/gpixmap.cpp:216 gSurface [gSurface] ERROR: accelAlloc failed
16:55:45.3330 { } skin.py:1506 readSkin [SKIN] processing screen MenuSummary:
16:55:45.3390 { } Screens/Screen.py:150 show [SCREENNAME] MenuSummary
16:55:45.3399 { } Screens/Screen.py:150 show [SCREENNAME] ['menu_system', 'Menu']
16:55:45.3425 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 160 1
16:55:45.3435 { } Screens/InfoBarGenerics.py:245 actionA KEY: 352 1 KEY_OK OK
16:55:46.0136 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6a 1
16:55:46.0149 { } Screens/InfoBarGenerics.py:245 actionA KEY: 106 0 KEY_RIGHT RIGHT
16:55:46.0151 { } Components/ActionMap.py:46 action [ActionMap] WizardActions right
16:55:46.1273 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6a 1
16:55:46.1286 { } Screens/InfoBarGenerics.py:245 actionA KEY: 106 1 KEY_RIGHT RIGHT
16:55:46.5792 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
16:55:46.5805 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 0 KEY_UP UP
16:55:46.5807 { } Components/ActionMap.py:46 action [ActionMap] WizardActions up
16:55:46.6973 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
16:55:46.6986 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 1 KEY_UP UP
16:55:46.8881 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
16:55:46.8893 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 0 KEY_UP UP
16:55:46.8896 { } Components/ActionMap.py:46 action [ActionMap] WizardActions up
16:55:47.0073 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
16:55:47.0086 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 1 KEY_UP UP
16:55:47.1444 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
16:55:47.1458 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 0 KEY_UP UP
16:55:47.1461 { } Components/ActionMap.py:46 action [ActionMap] WizardActions up
16:55:47.2574 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
16:55:47.2586 { } Screens/InfoBarGenerics.py:245 actionA KEY: 103 1 KEY_UP UP
16:55:47.7461 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
16:55:47.7475 { } Screens/InfoBarGenerics.py:245 actionA KEY: 352 0 KEY_OK OK
16:55:47.7478 { } Components/ActionMap.py:46 action [ActionMap] WizardActions ok
16:55:47.7478 { W } Components/ActionMap.py:53 action [ActionMap] unknown action WizardActions/ok! typo in keymap?
16:55:47.7479 { } Components/ActionMap.py:46 action [ActionMap] OkCancelActions ok
16:55:47.7644 { } skin.py:1506 readSkin [SKIN] processing screen Menu:
16:55:47.7679 { E } skin.py:1459 process [SKIN] SKIN ERROR in screen 'Menu' widget 'widget': {Nacht/skin.xml}: source 'key_red' was not found in screen 'Menu'!. Please contact the skin's author!
16:55:47.7743 [ ] gdi/epng.cpp:24 loadPNG [ePNG] couldn't open /usr/share/enigma2/skin_default/Nacht/e1/sel80.png
16:55:47.7745 { E } skin.py:374 loadPixmap pixmap file /usr/share/enigma2/skin_default/Nacht/e1/sel80.png not found!
16:55:47.7746 { W } skin.py:427 applyAll [Skin] attribute "selectionPixmap" with wrong (or unknown) value "/usr/share/enigma2/skin_default/Nacht/e1/sel80.png" in object of type "eListbox"
16:55:47.7783 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element key_yellow in <class 'Screens.Menu.Menu'>
16:55:47.7785 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element key_blue in <class 'Screens.Menu.Menu'>
16:55:47.7787 { W } Components/GUISkin.py:35 createGUIScreen warning, skin is missing element key_green in <class 'Screens.Menu.Menu'>
16:55:47.7795 [ E ] gdi/accel.cpp:463 accelAlloc [gAccel] accel alloc failed
16:55:47.7795 [ E ] gdi/gpixmap.cpp:216 gSurface [gSurface] ERROR: accelAlloc failed
16:55:47.8157 [ E ] gdi/accel.cpp:463 accelAlloc [gAccel] accel alloc failed
16:55:47.8158 [ E ] gdi/gpixmap.cpp:216 gSurface [gSurface] ERROR: accelAlloc failed
16:55:47.8260 { } skin.py:1506 readSkin [SKIN] processing screen MenuSummary:
16:55:47.8315 { } Screens/Screen.py:150 show [SCREENNAME] MenuSummary
16:55:47.8323 { } Screens/Screen.py:150 show [SCREENNAME] ['menu_display', 'Menu']
16:55:47.8578 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 160 1
16:55:47.8591 { } Screens/InfoBarGenerics.py:245 actionA KEY: 352 1 KEY_OK OK
16:55:48.4208 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
16:55:48.4220 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 0 KEY_DOWN DOWN
16:55:48.4222 { } Components/ActionMap.py:46 action [ActionMap] WizardActions down
16:55:48.5374 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
16:55:48.5387 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 1 KEY_DOWN DOWN
16:55:48.7625 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 6c 1
16:55:48.7637 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 0 KEY_DOWN DOWN
16:55:48.7640 { } Components/ActionMap.py:46 action [ActionMap] WizardActions down
16:55:48.9873 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 6c 1
16:55:48.9887 { } Screens/InfoBarGenerics.py:245 actionA KEY: 108 1 KEY_DOWN DOWN
16:55:49.3766 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
16:55:49.3781 { } Screens/InfoBarGenerics.py:245 actionA KEY: 352 0 KEY_OK OK
16:55:49.3783 { } Components/ActionMap.py:46 action [ActionMap] WizardActions ok
16:55:49.3784 { W } Components/ActionMap.py:53 action [ActionMap] unknown action WizardActions/ok! typo in keymap?
16:55:49.3785 { } Components/ActionMap.py:46 action [ActionMap] OkCancelActions ok
16:55:49.3826 { } skin.py:1256 readSkin [SKIN] Parsing embedded skin <embedded-in-'LCDClockSelector'>
16:55:49.3841 { } skin.py:1506 readSkin [SKIN] processing screen <embedded-in-'LCDClockSelector'>:
16:55:49.3877 { } Screens/Screen.py:150 show [SCREENNAME] ['menu_display', 'Menu']
16:55:49.3906 { D } Traceback (most recent call last):
16:55:49.3907 { D } File "/usr/lib/enigma2/python/Components/ActionMap.py", line 68, in action
16:55:49.3910 { D } File "/usr/lib/enigma2/python/Components/ActionMap.py", line 48, in action
16:55:49.3911 { D } File "/usr/lib/enigma2/python/Screens/Menu.py", line 81, in okbuttonClick
16:55:49.3913 { D } File "/usr/lib/enigma2/python/Tools/BoundFunction.py", line 9, in __call__
16:55:49.3915 { D } File "/usr/lib/enigma2/python/Screens/Menu.py", line 96, in runScreen
16:55:49.3916 { D } File "/usr/lib/enigma2/python/Screens/Menu.py", line 107, in openDialog
16:55:49.3917 { D } File "/usr/lib/enigma2/python/mytest.py", line 356, in openWithCallback
16:55:49.3929 { D } dlg = self.open(screen, *arguments, **kwargs)
16:55:49.3930 { D } File "/usr/lib/enigma2/python/mytest.py", line 369, in open
16:55:49.3933 { D } dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
16:55:49.3934 { D } File "/usr/lib/enigma2/python/mytest.py", line 304, in instantiateDialog
16:55:49.3936 { D } return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
16:55:49.3936 { D } File "/usr/lib/enigma2/python/mytest.py", line 333, in doInstantiateDialog
16:55:49.3939 { D } dlg.applySkin()
16:55:49.3939 { D } File "/usr/lib/enigma2/python/Components/GUISkin.py", line 118, in applySkin
16:55:49.3941 { D } File "/usr/lib/enigma2/python/Components/GUISkin.py", line 47, in createGUIScreen
16:55:49.3943 { D } File "/usr/lib/enigma2/python/Screens/LcdClockSelector.py", line 68, in layoutFinished
16:55:49.3944 { D } File "/usr/lib/enigma2/python/Screens/LcdClockSelector.py", line 111, in loadPreview
16:55:49.3945 { D } File "/usr/lib/enigma2/python/Tools/Directories.py", line 185, in resolveFilename
16:55:49.3947 { D } KeyError: '${datadir}/enigma2/display/clock_skin/noprev.png'
16:55:49.3948 [ E ] python/python.cpp:211 call [ePyObject] (PyObject_CallObject(<bound method NumberActionMap.action of <Components.ActionMap.NumberActionMap instance at 0x8f599cd8>>,('OkCancelActions', 'ok')) failed)
dmesg
<4>[ 796.352490] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 796.356609] [VID]: VIDEO_SELECT_SOURCE 1 0
<4>[ 796.361201] [VID]: VIDEO_PLAY 1 2 0
<4>[ 796.370156] [VID]: VIDEO_CONTINUE 1 1
<4>[ 796.374117] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[ 796.650974] [VID]: VIDEO_STOP 0 1
<4>[ 796.655423] [VID]: VIDEO_SELECT_SOURCE 0 0
<4>[ 799.980345] [AUD]: AUDIO_SET_MUTE 0
<4>[ 800.079786] [AUD]: AUDIO_SET_MIXER -891855224
<4>[ 800.084242] [AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[ 800.089336] [AUD]: AUDIO_SET_MIXER : next left volume -2355, right volume -2355
<4>[ 800.096653] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 805.463922] [AUD]: AUDIO_SET_MIXER -891855224
<4>[ 805.468389] [AUD]: AUDIO_SET_MIXER : amixl 32, amixr 32
<4>[ 805.473671] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[ 805.480676] [AUD]: AUDIO_SET_MIXER : next left volume -2355, right volume -2355
ALZIREÑO
metrix JR y NATCH, clock, el que trae de fabrica la imagen, no me deja cambiarlo, ya que me salta pantallazo.
El problema parece ser que no encuentra una imagen.
Para ver si es eso mete cualquier imagen con nombre noprev.png en la ruta /usr/share/enigma2/display/clock_skin/
Y reinicia GUI y pruebas a ver si ya no te da pantallazo.
