openspa-7.5.005 does not work in flash
Hacked
21 May 2022
10
Norway
Have problems with usb flash install of openspa-7.5.005-vuzero4k-20220219_usb.
It just does not work, after finished flashing I only get a start image with openspa logo and news & support at OpenSPA.info.
the box does not boot up.
Install in multiboot works just fine but with usb it does not work.
This is a brand new vu + zero4k, flash install with the same usb and original
firmware works fine.
aliseo2
22 Nov 2019
261
97
Has descomprimido el archivo Zip antes de instalar la imagen? , primero descomprime el archivo Zip que descargas de openspa, al descomprimir verás una carpeta llamada vuplus, está carpeta es la que debes pasar al USB para flahear, el USB cuanto más pequeño mejor( 4-8 gigas).
