Octagon sf4008 4K / FileZilla and Total Commander?!
ghita_49
12 May 2017
IP receiver connected. Do not connect FileZilla or Total Commander. What to do ? Thank you.
Never use the programs you indicate.
I was always able to read connection problems with Filezilla and win10.
Hopefully other colleagues who use them can comment that, says what system you have on the PC.
Nunca use los programas que indicas.
Siempre pude leer problemas de conexion con Filezilla y win10.
Esperemos que otros compañeros que los usen puedan comentar que tal, comenta que sistema tienes en el PC.
15.935
Installing spzAddIptv, creating a file in /etc named streams.m3u with urls inside and importing from spzAddIptv.
