He probado a meter el pincho con la imagen de booteo, a reiniciarlo con el pincho dentro, a meterlo con el deco encendido.. siempre que accedo a gestor de dispositivos dvb usb me da error.
El error que me da es:
Your receiver has a software problem detected. Since the last reboot it has occured 2 times.
El Log de error:
openSPA Enigma2 crash log
crashdate=lun dic 16 12:54:16 2019
compiledate=Dec 13 2019
skin=BlackSPA/skin.xml
sourcedate=2019-12-13
branch=7.4
rev=50bd40c
component=Enigma2
stbmodel=zero4k
stbmodel=dm8000
kernelcmdline=root=/dev/mmcblk0p7 rootfstype=ext4 rootflags=data=journal rootwait rw coherent_pool=2M rw bmem=699m@1317m
nimsockets=NIM Socket 0:
imageversion=box_type=vuzero4k
imageissue=Welcome to openSPA for %h
utDev] 0 ae 1
12:54:07.3545 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:07+0100 [-] KEY: 174 1 KEY_EXIT EXIT
12:54:07.6917 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 ae 1
12:54:07.6942 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:07+0100 [-] KEY: 174 0 KEY_EXIT EXIT
12:54:07.6950 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:07+0100 [-] [ActionMap] Keymap 'OkCancelActions' -> Action = 'cancel'.
12:54:07.7012 { E } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:07+0100 [-] [ChannelNumber] nimmanager.getTerrestrialDescription(nim) failed, nim: DVB-T
12:54:07.7126 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:07+0100 [-] [SCREENNAME] InfoBarSummary
12:54:07.7155 [ ] dvb/dvbtime.cpp:378 syncDVBTime [eDVBLocalTimeHandler] sync local time with transponder time!
12:54:07.7160 [ ] dvb/dvb.cpp:2420 getDemux [eDVBChannel] getDemux cap=00
12:54:07.7161 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
12:54:07.7161 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=20
12:54:07.7636 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:07+0100 [-] DVB-T 778.0 8 MHz 19:66:12:22D4:EEEE
12:54:07.7657 { E } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:07+0100 [-] [ChannelNumber] nimmanager.getTerrestrialDescription(nim) failed, nim: DVB-T
12:54:08.0303 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 ae 1
12:54:08.0329 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] KEY: 174 1 KEY_EXIT EXIT
12:54:08.5521 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] DVB-S2 02 Astra 19.2E 11435.5 Mhz 22 2/3 V 19:74D5:3F8:1:C0
12:54:08.5879 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 8b 1
12:54:08.5902 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] KEY: 139 0 KEY_MENU MENU
12:54:08.5912 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [ActionMap] Keymap 'InfobarMenuActions' -> Action = 'mainMenu'.
12:54:08.6188 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for lunes
12:54:08.6212 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for diciembre
12:54:08.6240 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for lunes
12:54:08.6269 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for diciembre
12:54:08.6319 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for martes
12:54:08.6357 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [ActionMap] Keymap(s) 'GlobalActions, WizardActions, DirectionActions, ColorActions, NumberActions, MenuActions, EPGSelectActions, InfobarActions' -> Undefined action(s) 'home'.
12:54:08.6398 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for diciembre
12:54:08.6419 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for lunes
12:54:08.6438 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] processing screen spazeTeamMenu:
12:54:08.6503 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [openSPATVGuide] fallback to default translation for diciembre
12:54:08.6559 [ ] gdi/epng.cpp:24 loadPNG [ePNG] couldn't open /usr/lib/enigma2/python/Plugins/Extensions/spazeMenu/image/nm_sel-fs8.png
12:54:08.6567 { E } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] pixmap file /usr/lib/enigma2/python/Plugins/Extensions/spazeMenu/image/nm_sel-fs8.png not found!
12:54:08.6609 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] warning, skin is missing element estado2 in <class 'plugin.plugin.spazeTeamMenu'>
12:54:08.6625 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6637 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6645 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6653 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6659 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "valign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6666 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6681 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6694 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "halign" with value "center" in object of type "ePixmap" is not implemented
12:54:08.6758 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Parsing embedded skin <embedded-in-'SimpleSummary'>
12:54:08.6771 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] processing screen <embedded-in-'SimpleSummary'>:
12:54:08.6795 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SCREENNAME] ['spazeTeamMenu_summary', 'SimpleSummary']
12:54:08.6816 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SCREENNAME] spazeTeamMenu
12:54:08.8195 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 8b 1
12:54:08.8232 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] KEY: 139 1 KEY_MENU MENU
12:54:08.8466 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] processing screen spzSubMenu:
12:54:08.8526 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SKIN] Attribute "valign" with value "bottom" in object of type "eListbox" is not implemented
12:54:08.8550 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:08+0100 [-] [SCREENNAME] spzSubMenu
12:54:09.4578 [ ] dvb/dvbtime.cpp:477 updateTime [eDVBLocalTimerHandler] Transponder time is 16.12.2019 12:54:09
12:54:09.4579 [ ] dvb/dvbtime.cpp:490 updateTime [eDVBLocalTimerHandler] diff is 0
12:54:09.4579 [ ] dvb/dvbtime.cpp:493 updateTime [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
12:54:09.4579 [ ] dvb/dvbtime.cpp:554 updateTime [eDVBLocalTimerHandler] not changed
12:54:09.4582 [ ] dvb/dvb.cpp:2420 getDemux [eDVBChannel] getDemux cap=00
12:54:09.8901 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
12:54:09.8927 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:09+0100 [-] KEY: 103 0 KEY_UP UP
12:54:09.8936 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:09+0100 [-] [ActionMap] Keymap 'WizardActions' -> Action = 'up'.
12:54:10.1214 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
12:54:10.1235 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:10+0100 [-] KEY: 103 1 KEY_UP UP
12:54:14.4092 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
12:54:14.4119 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] KEY: 352 0 KEY_OK OK
12:54:14.4127 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] [ActionMap] Keymap 'WizardActions' -> Action = 'ok'.
12:54:14.4275 [ ] gdi/epng.cpp:24 loadPNG [ePNG] couldn't open mainmenu/missing.png
12:54:14.4406 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] [SKIN] processing screen menu_setup:
12:54:14.5379 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] [SKIN] No skin to read...
12:54:14.5390 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] [SKIN] processing screen <embedded-in-'MenuSummary'>:
12:54:14.5398 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] [SCREENNAME] MenuSummary
12:54:14.5411 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] [SCREENNAME] ['menu_setup', 'Menu']
12:54:14.6413 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 160 1
12:54:14.6505 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:14+0100 [-] KEY: 352 1 KEY_OK OK
12:54:15.0867 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
12:54:15.0891 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:15+0100 [-] KEY: 103 0 KEY_UP UP
12:54:15.0903 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:15+0100 [-] [ActionMap] Keymap 'WizardActions' -> Action = 'up'.
12:54:15.3183 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
12:54:15.3203 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:15+0100 [-] KEY: 103 1 KEY_UP UP
12:54:15.6255 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 67 1
12:54:15.6279 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:15+0100 [-] KEY: 103 0 KEY_UP UP
12:54:15.6287 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:15+0100 [-] [ActionMap] Keymap 'WizardActions' -> Action = 'up'.
12:54:15.8574 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 0 67 1
12:54:15.8598 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:15+0100 [-] KEY: 103 1 KEY_UP UP
12:54:16.1923 [ ] driver/rcinput.cpp:38 handleCode [eRCDeviceInputDev] 1 160 1
12:54:16.1950 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] KEY: 352 0 KEY_OK OK
12:54:16.1957 { W } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] [ActionMap] Keymap 'WizardActions' -> Unknown action 'ok'! (Typo in keymap?)
12:54:16.1963 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] [ActionMap] Keymap 'OkCancelActions' -> Action = 'ok'.
12:54:16.2312 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] [SCREENNAME] ['menu_setup', 'Menu']
12:54:16.2358 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] Traceback (most recent call last):
12:54:16.2363 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "/usr/lib/enigma2/python/Components/ActionMap.py", line 77, in action
12:54:16.2371 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "/usr/lib/enigma2/python/Components/ActionMap.py", line 57, in action
12:54:16.2376 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "/usr/lib/enigma2/python/Screens/Menu.py", line 152, in okbuttonClick
12:54:16.2382 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "/usr/lib/enigma2/python/Tools/BoundFunction.py", line 9, in __call__
12:54:16.2394 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/enigma2-plugin-systemplugins-spzusbdevices/1.5+gitAUTOINC+71a31ba7b6-r0/git/spzusbdevices/plugin/plugin.py", line 426, in plugin.plugin.startConfig
12:54:16.2401 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "/usr/lib/enigma2/python/mytest.py", line 381, in open
12:54:16.2419 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
12:54:16.2426 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "/usr/lib/enigma2/python/mytest.py", line 316, in instantiateDialog
12:54:16.2435 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
12:54:16.2440 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "/usr/lib/enigma2/python/mytest.py", line 338, in doInstantiateDialog
12:54:16.2448 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] dlg = screen(self, *arguments, **kwargs)
12:54:16.2453 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/enigma2-plugin-systemplugins-spzusbdevices/1.5+gitAUTOINC+71a31ba7b6-r0/git/spzusbdevices/plugin/plugin.py", line 128, in plugin.plugin.UsbDevices.__init__
12:54:16.2458 { } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] File "tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/enigma2-plugin-systemplugins-spzusbdevices/1.5+gitAUTOINC+71a31ba7b6-r0/git/spzusbdevices/plugin/plugin.py", line 186, in plugin.plugin.UsbDevices.readall
12:54:16.2465 { E } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2019-12-16 12:54:16+0100 [-] IOError: [Errno 2] No such file or directory: '/etc/dvb-usb-devices.list'
12:54:16.2467 [ E ] python/python.cpp:211 call [ePyObject] (PyObject_CallObject(<bound method NumberActionMap.action of <Components.ActionMap.NumberActionMap instance at 0x98ff93a0>>,('OkCancelActions', 'ok')) failed)
