Mgcamd.sh4 plugin tuner locks Spark!
Spartacus5000
5 Dic 2011
145
17
Hello, if you often happens that when you switch encrypted channels and FTA tuner Spark suddenly freezes and does not respond to any commands from the remote control? Also, problems with searching for channels, while we want to find new frequencies, the tuner only shows the same frequencies without any channels after a restart tuner everything returns to normal? It turns out that these problems will aforementioned plugin Mgcamd.sh4 (all versions) so if you do not have to use this plugin you absolutely can simply Turn off and problems disappear ;) I spent quite a few months or even years to find this problem ;)
Reactions: Mecha
