[root@stlinux]#/var/bin/newcs
This is NewCS 1.67 RC1 [Build: 95] - the New CardServer by the Butter-team..
Compiled on Jul 14 2009 at 12:01:03
Reading Config file from /var/tuxbox/config/newcs.xml
TCP-log password is enabled, set to: NewCSpwd
level: internal
type: all
output: console,tcp
logger config: level 16777215 type 255 output 5
Console log options: level 16777215 type 255
TCP log options: level 1 type 255
[ 17:01:58 ] [ Box detect ] Box type 1 (General Boxtype - Generic)
[ 17:01:58 ] [ Config ] Option <blockc0> for device 0 (SCI Lower Slot) not present, defaulting to NO
[ 17:01:58 ] [ Config ] Option <blockga> for device 0 (SCI Lower Slot) not present, defaulting to NO
[ 17:01:58 ] [ Config ] Option <blockua> for device 0 (SCI Lower Slot) not present, defaulting to NO
[ 17:01:58 ] [ Config ] Option <blocksa> for device 0 (SCI Lower Slot) not present, defaulting to NO
[ 17:01:58 ] [ Config ] Option <crypto-special> for device 0 (SCI Lower Slot) not present, defaulting to NO
[ 17:01:58 ] [ Config ] Option <PTShandshake> for device 0 (SCI Lower Slot) not present, defaulting to NO
[ 17:01:58 ] [ Config ] Option <Seca-PPV> for device 0 (SCI Lower Slot) not present, defaulting to NO
[ 17:01:58 ] [ Config ] Pincode for device 0 (SCI Lower Slot): 0000
[ 17:01:58 ] [ Config ] Option <sid> for device 0 (SCI Lower Slot) not present, no static sids added to filter
[ 17:01:58 ] [ Config ] Option <protectedsid> for device 0 (SCI Lower Slot) not present, no PIN Code will be sent
[ 17:01:58 ] [ Config ] /dev/sci0 ECM priority: round
[ 17:01:58 ] [ DNS ] Resolved Hostname localhost to: 127.0.0.1
[ 17:01:58 ] [ Newcamd ] Server name : newcs
[ 17:01:58 ] [ Newcamd ] Des key : 0102030405060708091011121314
[ 17:01:58 ] [ Config ] Option <hostname> or <port> not present for User: dummy, DISABLING reverse login
[ 17:01:58 ] [ Newcamd ] User 2: dummy, Pass: dummy, Host none, Port: 0, Au: On, Spider allowed: No, Sidoverride: No, level: 1
[ 17:01:58 ] [ httpd ] httpd-user: dummy, password: dummy, accesslevel: admin
[ 17:01:58 ] [ EMM Cache ] Initialising dynamic Cache
[ 17:01:58 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 1448
[ 17:01:58 ] Calibrating delay loops
[ 17:01:58 ] usleep(5) takes: 0 s 10 us
[ 17:01:58 ] usleep(10) takes: 0 s 14 us
[ 17:01:58 ] usleep(100) takes: 0 s 104 us
[ 17:01:58 ] usleep(500) takes: 0 s 505 us
[ 17:01:58 ] Allocation memory for 200 regular users
[ 17:01:58 ] [ Loader ] Starting Telnet on port 12001
[ 17:01:58 ] bind: error! 98: Address already in use
[ 17:01:58 ] [ SockSrv ] Could not Bind to port 12001 EXITING!
[ 17:01:58 ] [ SockSrv ] Stopping port 12001
[ 17:01:58 ] [ SockSrv ] Server thread started
Can't create server: Address already in use
[ 17:01:58 ] [ Loader ] Reader type 5 on node /dev/sci0
[ 17:01:58 ] [ Sci ] Closing device /dev/sci0 [Handle=-1]
[ 17:01:58 ] [ CardMan ] Reseting reader parameters
[ 17:01:58 ] [ Sci ] Opening device /dev/sci0
SCI returned 0 on IOCTL IOCTL_SET_PARAMETERS
[ 17:01:58 ] [ Sci ] resetting card now
[ 17:01:58 ] [ Sci ] Reset
[ 17:01:58 ] [ Sci ] Card reset
[ 17:01:58 ] [ Sci ] Timeout is 3743808us
Connection closed by foreign host.
