<?xml version="1.0"?>
For setup-issues, look in readme.txt!
If there are other troubles, try different forums or irc channels around :o)
The configfile are NOT case-sensitive, and shouldnt care about dos/unix cr/lf.
<newCSconfig>
<readers name="AZBOX">
<device>
<!-- valid value for name are:
Any name of your choice, just to name the device for you to read. -->
<name>Internal Card Reader</name>
<!-- valid value for type are:
phoenix, dbox, sci, dragon, sc8, mp35, smartreader, pcsc (for own binary) or infinity(for own binary). -->
<type>azbox</type>
<!-- valid value for mhz are:
153(1.53mhz), 358(3.58mhz), 368(3,68Mhz), 450(4.5mhz), 536(5.36mhz), 600(6.00mhz), 715(7.15 mhz), 800(8.00mhz)
1000(10.00 mhz), 1071(10.71mhz), 1200 (12.00mhz), 1431(14.31 mhz), 1600 (16.00mhz)
This setting is now IMPORTANT, normal phoenix usually have 3.57mhz, and can usually be overclocked
to 6mhz. For the others you probably need extra crystal (be careful). -->
<mhz>600</mhz> #für V13 und V14 und cryptorks dann 358mhz!!!#
<!-- valid value for node are full path to device, f.ex /dev/tts/0,
/dev/sciX (for dreambox), /dev/cardreaderX (for dragon),
/dev/tts/USBX (for a usb2serial device).
COMx on Win32, COM1, COM2 etc.
For PC/SC this is just 0, 1 ,2 and so on (reader number) -->
<node>/dev/scard</node>
<!-- valid value for parity are:
Odd, Even, None (ignored on sci and dragon).
This is only used on serial _BEFORE_ ATR is recieved. -->
<parity>even</parity>
<!-- valid value for reset are:
normal, inverse (ignored on sci and dragon).
normal is phoenix, inverse is smartmouse -->
<reset>normal</reset>
<!-- valid value for export are:
Yes,No - if not exported only localhost can connect. -->
<export>Yes</export>
<!-- valid value for enabled are:
Yes,No - if not enabled it cant be used. -->
<enabled>Yes</enabled>
<!-- valid value for blocksa are:
Yes, No - block shared address emm to card. -->
<blocksa>yes</blocksa>
<!-- valid value for blockua are:
Yes, No - block unique address emm to card. -->
<blockua>No</blockua>
<!-- valid value for blockga are:
Yes, No - block group address emm to card. -->
<blockga>No</blockga>
<!-- valid value for boxkey are:
The boxkey/boxid of your nagra/nds STB. -->
<boxkey>79FDC0E18D278138</boxkey>
<rsa>9ED52515321F04BCF7772151149D6895154B559A8D825A4E7D711A9FAFD5C66BF64689501B254DF1832F754C21095379CF97B4E5BE6E0F1C9CEBF0A0E91D5ACD</rsa>
<!-- valid value for irdeto-camkey are:
8byte hex. -->
<!-- <irdeto-camkey>0000000000000000</irdeto-camkey> -->
<!-- valid value for camkey-data are:
64byte hex -->
<!-- <irdeto-camkey-data>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</irdeto-camkey-data> -->
<!-- valid value for crypto-special are:
Yes, No - Used to enable/disable real-time mosc on Cryptoworks. -->
<crypto-special>No</crypto-special>
<!-- valid value for ipk are:
64byte hex -->
<!-- <ipk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</ipk> -->
<!-- valid value for ucpk are:
64byte hex -->
<!-- <ucpk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</ucpk> -->
<!-- valid value for PTShanshake are:
Yes, No - Used to enable/disable real-time HighBaud on Cryptoworks and Viacess. -->
<PTShandshake>No</PTShandshake>
<!-- valid value for carddetect are:
Yes, No - Used to try to detect if card is present in you cardreader. -->
<carddetect>yes</carddetect>
<!-- valid value for newcamd_port are:
0,65535 - Which port newcamd server will listen for incomming connections. -->
<newcamd_port>20000</newcamd_port>
<!-- valid value for autosid are:
Yes, No - Let NewCS decide which sids should be allowed/denied based on card answers. -->
<autosid>yes</autosid>
<sid>
<allow>
</allow>
<deny>
</deny>
</sid>
<!-- valid value for Seca-PPV are:
<Seca-PPV>no</Seca-PPV>
<!-- valid value for Pincode are:
0000, 9999 - For f.ex PPV on Conax, also for parental lock on conax and cryptoworks. -->
<pincode>0000</pincode>
<!-- valid value for priority are:
hard, round, fifo - hard is lower userid, higher priority(gets ECM through before user with higher id),
round, there is an equal chance for all users to get ECM through, fifo, first sendt ECM gets through. -->
<priority>hard</priority>
</device>
</readers>
<cache>
<!-- valid value for emm are:
0-255 - Number of EMM's to cache. -->
<emm>10</emm>
<!-- valid value for ecm are:
0-255 - Number of ECM's to cache.
-1 - Dynamic ECM Cache. -->
<ecm>-1</ecm>
</cache>
<debug>
<!-- valid value for mode:
simple, advanced - Set TCP-Console to advanced mode to get access to
potentially dangerous features.-->
<!-- <mode>advanced</mode> -->
<darint39>sintoi51</darint39>
<!-- valid value for level are:
normal, verbose, spam - How extensive debug should be. -->
<level>internal</level>
Init, general, ecm, emm, net, all - Section of debug that should be displayed. -->
<type>all</type>
<!-- valid value for output are:
Console, udp, tcp, file, all - Where to show debug. -->
<output>console,tcp</output>
<logfile>/tmp/newcs.txt</logfile>
<!-- console_options are so you can set own loglevel/type for console-logger:
Should hold level and type-tags like above. -->
<console_options></console_options>
<file_options></file_options>
<udp_host>IP deines recivers oder dyndns</udp_host>
<udp_port>9000</udp_port>
<udp_options></udp_options>
<!-- valid value for tcp_port are:
0,65535 - Which port to listen for incomming tcp connections. -->
<tcp_port>9000</tcp_port>
<!-- tcp_options are so you can set own loglevel/type for tcp-logger:
<tcp_options></tcp_options>
</debug>
<newcamdserver>
Yes, No - Enable or Disable newcamd server. -->
Any name - Used to identify server to remote clients,
if the remote client isnt newcamd, this field have no purpouse. -->
<name>newcs</name>
<!-- valid value for deskey are:
any 14x2 numbers - Used to encrypt the communication between
the client and the server. -->
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>user1</name>
<password>user1</password>
<hostname>127.0.0.1</hostname>
<au>on</au>
<spider>yes</spider>
<rate>2</rate>
</user>
<user>
<name>user2</name>
<password>user2</password>
<hostname>IP deines recivers oder dyndns</hostname>
<au>on</au>
<rate>2</rate>
</user>
<user>
<name>user3</name>
<password>user3</password>
<au>on</au>
<rate>1</rate>
</user>
<user>
<name>duser4</name>
<password>passwort4</password>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>duser5</name>
<password>passwort5</password>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>duser6</name>
<password>passwort6</password>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<!-- Notes about users:
The first user doesnt have au without beeing it set to on (unlike newcamd cardserver).
You can add as many user-sections as you want, just put them under eachother. -->
<user>
<!-- valid value for userfile are:
Any username you'd like - Used for client to logon (its case sensitive). -->
<name>beispiel</name>
<!-- valid value for password are:
Any password you'd like - Used for client to logon (its case sensitive). -->
<password>passwort</password>
<!-- valid value for hostname are:
IP-address or DNS-name - Used for reverse login to the client. -->
<!-- valid value for au are:
On,Off - Wheather the client are allowed to send EMM to the server. -->
<au>on</au>
<!-- valid value for sidoverride are:
On,Off - Wheather the client are allowed to override the SID-filter. -->
<sidoverride>off</sidoverride>
<!-- valid value for spider are:
Yes,No - Wheather the client are allowed to be newcamd Cardspider. -->
<!-- valid value for rate are:
1-60 - number of seconds between each ecm -->
<rate>3</rate>
</user>
</newcamdserver>
</newCSconfig>
