How to enable Swap on Device memory ?
Spartacus5000
5 Dic 2011
145
17
Hello, a swap can be created on an external HDD, but how do I run a swap on the tuner's main memory ?
Moderator's Note:
Since you don't translate, I pass it on to the International section.
With this team and this image.
Receptor: Uclan
Imagen: OpenATV 6.4
Spartacus5000
5 Dic 2011
145
17
Open Telnet & login:
then copy & paste file:
dd if=/dev/zero of=/home/swapfile bs=1024 count=524288
then:
mkswap /home/swapfile
then:
swapon /home/swapfile
and then open:
/etc/fstab
add on fstab this:
/home/swapfile swap swap defaults 0 0
Restart device.
Njoy!
