- 11 Nov 2011
- 4
Hello,
I recently bought a GM9080HD, but im having problems with the Cable tuner...
When i do blind scan it only find 50 channels instead of 200+, so i manually entered the requencys of the channels.
That way i can find all my channels, but now there is a bigger problem. When i search for a channels manually it finds like 5 channels, before i scan for other channels, I test my last scanned channels if it works, well it works but after i search for other channels it doesnt work anymore only the channels i searched last works.
Example :
> Scanning, entered a frequency...
> BBC HD found and it works.
> Searching for new channels...
> Find BBC 2 after scanning with differect frequency.
> BBC HD dont work now...
> BBC 2 works.
So only the channels i scan last works.... How can i fix this.
I try'd like 10 images, all same
Is this a known problem on GoldenMedia receivers?
I hope someone can help me, im now busy for houurssssssss...
Example :
> BBC 2 works.
