Formuler F1 - problem with watch in standby
kamacnik1
24 Ene 2015
23
I got this problem (pretty big at least for me), when I turn off box, on lcd screen supposedly should be current time, for example 23:55
On my box that is little bit different, right side where minutes are is OK, but on the left where it should be current hour displayed is problem, instead of that countdowning seconds from 00 to 60
Thru menu -settings- display that feature should be fixed, but no mather what I choose there (4 or 5 combination what stay on lcd when box is turned off) situation remain same
Shore, lcd could be turned off when box is in standby, only that is not a solution
It happens only with OpenSpa image, until version 6.0.010 everything was ok, from that version on all newer versions problem is present
I did try any other images for this box, and they didnt occured on any of them
Pitty, I really like OpenSpa image, but this situation makes me mad
So, any suggestion are welcome
7.207
1.307
Works fine for me. Tell me the language you have configured in your recptor, maybe it is a translation problem
7.207
1.307
Yes, the problem is in translation file. Please, extract this file and put it in /usr/share/enigma2/po/hr/LC_MESSAGES. Then restart gui
  • enigma2.mo.zip
    13,7 KB · Visitas: 5
Reactions: kamacnik1
