*How to update TGS 200
Notice) The password of the ITGATE is blank.
Please make your own password newly with Control Center 2.2 if you want.
*Image for autoupdate by ITGATE Control Center
1) Download and Unzip the file below.
http://itgate.co.kr/Rel/2011/TGS200autowin_rel2011.zip
2) Run the ITGATE Control Center
3) Click "Update" icon.
4) Insert your IP address.
5) Click "Auto update" icon.
6) Select the folder containing update files.
7) Autoupdate will be started.
8) Wait until TGS 200 reboots automatically
*How to update TGS 200 by Flashing through serial port
1) For Serial update, please click hereunder to download the image.
http://itgate.co.kr/Rel/2011/TGS200srl_rel2011.zip
2) Turn TGS 200 off.
3) Turn TGS 200 on while pressing < CH- > button on front panel. If you can see UPGD on LED, release < CH- > button.
4) Run "ITGATE Control Center".
5) Click "Serial" icon.
6) Select the image file by clickiing FILE.
7) Press < VOL+ > button on front panel to start flashing.
8) When the flashing is done, LED shows Done and tool shows message, complete.
9) Turn TGS200 off and on again.
*How to update by Internet
1) Press MENU button on the remote controller and go into " Setup -> Expert Setup -> Software Update -> Internet Update" and select the image.
2) Follow as prompted on the menu..
Improvements are :
- Flash writing bug fixed(flash write timeout bug fixed inside kernel).
- Network Driver Upgrade(Davicom latest official Driver code) with better DHCP performance.
- RCU conflict bug fixed.
- PVR <-> Liver channel mode change bug fixed.
- Samba client fixed.
Thank you so much!
Improvements are :
Thank you so much!
