*How to update TGS 100
Notice) The password of the ITGATE is blank.
Please make your own password newly with Control Center 2.2 if you want.
*Image for autoupdate by ITGATE Control Center
1) Download and Unzip the file below.
http://itgate.co.kr/Rel/2011/TGS100autowin_rel2011.zip
2) Run the ITGATE Control Center.
3) Click "Update" icon.
4) Insert your IP address.
5) Click "Auto update" icon.
6) Select the folder containing update files.
7) Autoupdate will be started.
8) Wait until TGS 100 reboot automatically.
*How to update TGS100 with Memory Card automatically
1) Copy all files inside folder(after unzip) to the memory card.
http://itgate.co.kr/Rel/2011/TGS100automc_rel2011.zip
2) Switch off TGS 100 and insert the memory card into the memory card slot of front panel.
3) Switch on TGS 100 and you can see "doun" on LED display, it means downloading is started.
4) Soon after, you can see downloading process by number(1~100) on LED display. Please wait until it shows "done".
5) After checking "done" on LED display, remove Memory Card and switch off and on again.
6) Update completed!
Warning) Do not remove memory card during reading and writing mermory card in any cases.
*How to update TGS 100 by Flashing through serial port
1) For Serial update, please click hereunder to download the image
http://itgate.co.kr/Rel/2011/TGS100srl_rel2011.zip
2) Power off TGS 100.
3) Power on while pressing OK button on front panel. If you can see UPGD on LED, release OK button.
4) Run "ITGATE Control Center".
5) Click "Serial" icon.
6) Select the image file by clickiing FILE.
7) Press OK button on front panel to start flashing.
8) When the flashing is done, LED shows Done and tool shows message, "complete".
9) Power off and on again.
*How to update by Internet
1) Press MENU button on the remote controller and go into " Setup -> Expert Setup -> Software Update -> Internet Update" and select the image.
2) Follow as prompted on the menu..
Improvements are :
- Flash writing bug fixed(flash write timeout bug fixed inside kernel).
- Network Driver Upgrade(Davicom latest official Driver code) with better DHCP performance.
- RCU conflict bug fixed.
- PVR <-> Liver channel mode change bug fixed.
- Samba client fixed.
Thank you so much!
Improvements are :
Thank you so much!
