- 22 Mar 2007
- 708
- 1
aqui la info que he pillao por ahi,tiene un input rate de 90mbit/s,sera suficiente pa leer feeds hd y 422??
Mvision HD-500 USB - COMBO- NET alle specificaties:
1. Conditional Access Interface
.. SMART CARD 1 Slot
ISO 7816, GSM11.11 and EMV (payment systems) compatibility
.. PCMCIA 2 Slot
DVB Common Interface Standard
(pan tumaca,huevos al plato,NO FTA,spaguetti bolones,Crytoworks,AlpahCrypt …)
2. Tuner & Channel(DVB-S) SATELLIET !!!!
.. Type 1 × F Type, IEC169-24, Female
.. Frequency Range 950MHz to 2150MHz
.. RF Impedance 75 Ohm unbanlanced
.. Signal Level -65 to -25 dBm
.. LNB Power 13.5/18.5Vdc +/- 5%, 0.5Amax, Overload Protected
.. 22KHz Tone Frequency : 22KHz +/- 2KHz, 0.6Vpp +/- 0.2V
.. DiSEqC Control Version1.0, 1.2, Tone burst A/B, USALS
.. Demodulation QPSK, 8PSK
.. Input Symbol Rate DVB-S QPSK : 1~45 Msps
.. DVB-S2 8PSK/QPSK : 10~30Msps
.. FEC Decoder 1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10 in DVB-S2 mode.
1/2, 2/3, 3/4, 5/6 and 7/8 in DVB-S mode.
3. Tuner & Channel(DVB-T) DIGITENNE !!!!!
.. Type IEC60169-2(VHF/UHF) female, 75Ù nominal
.. Frequency Range VHF: 170MHz to 230MHz
.. UHF: 470MHz to 862MHz
.. Signal Level -78.5dBm ~ -25dBm
.. (64QAM, Code Rate 2/3, Guard Interval 1/8,Gaussian Channel)
.. COFDM Spectrum COFDM 2K/8K-Carrier
.. FEC Mode 1/2, 2/3, 3/4, 5/6, 7/8
4. System & Memory
.. Main Processor STI7109
.. Flash Memory 8 Mbytes
.. System Memory 128 Mbytes
.. Channel Capacity Digital Channel: 5,000
.. Front 7-pepito de ternera, VFD Display 5 Icon, 8 digit Alphanumeric)
5. MPEG Transport Stream & A/V Decoding
.. Transport Stream 13818-1 MPEG-2, H.264/AVC Transport stream Specification
.. Profile Level MPEG-2 MP@ML, MP@HL, MPEG-4 H.264/AVC
.. Input Rate Max. 90Mbit/s
.. Aspect Ratio 4:3, 16:9, Letter Box
.. Frame Rate 25Hz for PAL, 30Hz for NTSC
.. Video Resolution 576i, 576p, 720p, 1080i
.. Teletext Through VBI
.. Audio Decoding MPEG-1 Layer 1 & 2, Dolby Downmix
.. Audio Mode Single Channel/Dual Channel Joint Stereo/Stereo
.. Frequency Response 20~20kHz, <+/-2dB 60Hz ~ 18kHz <+/- 0.5dB
.. Sampling Rate 32, 44.1, 48KHz
6. A/V & Date In/Out
.. HDMI HD Video/Audio Output
.. TV SCART Output RGB, CVBS, L, R Output with Volume control
.. VCR Scart In/Out RGB, CVBS, L, R In CVBS, L, R Out
.. RCA Output CVBS, L, R Output(Yellow, White, Red Jack) with Volume Control, Component Video(YPbPr) Out
.. S-VHS Output 4 Pin Mini
.. SPDIF Dolby Digital Bitstream Out(Coaxal, Optical)
.. Data Interface - RS-232, Bit Rate: 115,200baud, Connector: 9-pin D-sub Male type
- USB : USB 2.0, Type A Connector, 2Port
.. Network Connection Ethernet 10/100 RJ45
7. RF Modulator
.. RF-Connector 75 ohm IEC 169-2, Male/Female
.. Frequency 470MHz to 860MHz
.. Output Channel CH21 ~ 69 for the Remodulator
.. TV Standard PAL G/I/K Selectable by Menu Setting
.. Audio Output Mono with Volume Control
.. Preset Channel CH 38(or TBD). Software changeable by Menu Screen
8. Power Supply
.. Input Voltage AC 90V ~ 250V, 50Hz ~ 60Hz
.. Power Consumption Max 40W
.. Standby Power Consumption <= 10W
.. Protection Separate Internal Fuse
The input shall the lighting protection
9. Physical Specification
.. Size(WxHxD) 340mm x 68mm x256mm
.. Weight 3 KG
10. Environmental Condition
.. Operating Temperature 0 °C ¡« 40 °C
.. Storage Temperature -10 °C ¡« 50 °C
.. Operating Humidity Range 10~85% RH, Non-condensing
.. Storage Humidity Range 5~90% RH, Non-condensing
.. PCMCIA 2 Slot
4. System & Memory
7. RF Modulator
8. Power Supply
.. Weight 3 KG
