- 19 Mar 2007
- 11.803
- 596
Especificaciones
Recursos del Sistema
Main Processor 396M Hz based CPU
Flash Memory 32M Bits
DDR SDRAM 1024Mbits
Sintonizadores
Tuner Type DVB-T (SD&HD)
Input Frequency 170-230MHz CH5-CH12, 470-860MHz CH21-CH69
RF Input Level "-70dBm to -8dBm"
Antenna power output 5V/50mA max
Demodulation COFDM 2K/8K
Number of carriers 1705/6817
Constellation QPSK, 16QAM, 64QAM
Guard Inter Val 1/4, 1/8, 1/16, 1/32
FEC Decoder 1/4, 2/3, 3/4, 5/6, 7/8, k=7
Tuner Type DVB-S / DVB-S2
Input Connector F-type, Connector, Female
Loop Through F-type, Connector, Female
Signal Level -65 to -25 dBm
LNB Power & Polarization Vertical: +13V
Horizontal: +18V
Current: Max. 500mA
Overload Protection
22KHz Tone Frequency: 22±1KHz
DiSEqC Control Amplitude: 0.6±0.2V
Version 1.0, 1.1 1.2, USALS Available
Demodulation QPSK, 8PSK
Input Symbol Rate 2-45 Mbps, Convolution Code Rate
1/2, 2/3, 3/4, 5/6, 7/8 and Auto
Alimentación
Input Voltage Free Voltage (100~240V AC, 50/60Hz)
Power Consumption 30W MAX/12W
MPEG TS A/V Decoding
Transport Stream MPEG-2, H.264
Input Rate Max.120Mbit/s
Aspect Radio 4:3, 16:9, Letter Box
Video Decoding MPEG-2, MP@ML, MPEG-4 part 10/H264
Video Resolution 720*480P/I, 720*576P/I, 1280*720p,1920*1080i
Audio Decoding MEPG-1 layer I/II, Mpeg2 layerII, Dolby digital plus
Audio Mode Left / Right / Stereo/ Mono
Sampling Rate 32, 44.1 and 48KHz
DDR SDRAM 1024Mbits
Sintonizadores
Horizontal: +18V
Current: Max. 500mA
Overload Protection
Alimentación
