VU+ Duo2 Duo2 dead
pawel115
1 Ene 2017
20
Hi, i have problem
I uploaded soft, the tuner does not turn on only the welcome logo on the panel and restart. I can not upload the software again from USB. I write 2sec programming and 2sec scan and restart. What should I do.
Maybe somebody has files for reanimation flash and tel me what i must do
javilinjavilon
30 Nov 2010
163
70
1. Try with another pendrives
2. The folder directory is ok?
3. Be sure that the "force" archive exist into the main folder ..
pawel115
1 Ene 2017
20
I dont can look in to the tuner because is not runing only welcome logo on front panel and stop.
I try 3 pendrive
15.934
Try other image, I don't understand what is happening. The problem is your box doesn't recognize your pendrive, isn't it?
