- 22 Ene 2010
- 25
- 39
DogSettings ver.1.5.0.0
In this version:
- Added profile for Azbox / Aztrino (NeutrinoHD AzBox)
- Added channel lists for SPARK System (Pingulux - Amiko 8900) in XML format (beta version)
** For the profile Aztrino the program does not automatically reload the settings (problem Aztrino 1.0 & 1.1).
Reload it manually: Main Menu -> Service -> Reload channel list.
** For the system SPARK program only generates XML files.
To upload files to the decoder:
Download them to your receiver via FTP: "root/storage/c" (if pen drive connected)
By the decoder: Menu -> System -> Upgrade -> Transformer Database - select the path "/Storage/C" - then LOAD (green button)
To create the XML file to read in DogSettings:
By the decoder: Menu -> System -> Upgrade -> Transformer Database - select the path "/Storage/C" - then OUTPUT (red button)
Download the file to your PC via FTP "root/storage/c" - then load them into DogSettings
In this version:
