AZBox login: root
Password:
AZBox[~]$ killall -9 sbox.sigma
AZBox[~]$ cd /PLUGINS/OpenXCAS/SboxCAS
AZBox[SboxCAS]$ ./sbox.sigma
16:46:56 sbox: Viewing Pay TV without a valid subscription is illegal
16:46:56
16:46:56 Wellcome to sBox (for Sigma)
16:46:56 Version: 0.0.4-7 (07/03/2010 #2)
16:46:56 WebPage: http://www.sboxobs.tk
16:46:56
16:46:56 sbox: checking for /camd/OpenXCAS/SboxCAS/sbox.conf... OK
AZBox[SboxCAS]$ 16:47:02 io: sci device detected
16:47:02 reset: got atr on slot0
16:47:02 reset: atr xxxxxxxxxx204143532056352E37
16:47:02 reset: hist xxxxxxx4143532056352E37
16:47:02 reset: char I R D E T O A C S V 5 . 7
16:47:02 reset: working at 3.570Mhz (max 6.000Mhz)
16:47:02 sbox: irdeto card init
16:47:02 irdeto: serial 00EAAD4C (15379788)
16:47:02 irdeto: provider 00, id 000000, ppua 00196952, caid 0603
16:47:02 irdeto: provider 01, id 000001, ppua 00005000, caid 0603
16:47:03 irdeto: provider 02, id 000002, ppua 00005000, caid 0603
16:47:03 irdeto: provider 03, id 000003, ppua 00005000, caid 0603
16:47:03 irdeto: card init ok
16:47:03
16:47:03 webif: init
16:47:03 sbox: entering main loop
16:47:03 sbox: mixed mode
[OPENXCAS_API:Tue Oct 18 16:47:03.865] load_xcas_control:68 ## loaded controller ID = 0x19760507
osdep_msq_server_open : key_request 0x35E78453 key_response 0x35E78454
osdep_msq_server_open : request msq is already created
osdep_msq_server_open : response msq is already created
osdep_msq_client_connect : key_request 0x35E78453 key_response 0x35E78454
16:47:03 newcamd: server 29000 init ok
16:47:07 newcamd 29000: accepted dummy from 127.0.0.1
16:47:07 newcamd 29000: sending info dummy
16:58:05 sbox: mixed mode
[OPENXCAS_API:Tue Oct 18 16:58:05.784] load_xcas_control:68 ## loaded controller ID = 0x19760507
16:58:05 newcamd: server 29000 init ok
16:58:33 newcamd 29000: accepted dummy from 127.0.0.1
16:58:33 newcamd 29000: sending info dummy
16:58:34 newcamd 29000: ecm dummy [0603:000000:20F8] [81703143000500010008...] fail (178ms)
16:58:34 newcamd 29000: ecm dummy [0603:000000:20F8] [81703143010500040008...] fail (153ms)
16:58:35 newcamd 29000: ecm dummy [0603:000000:20F8] [81703143020500070008...] fail (170ms)
16:58:35 newcamd 29000: ecm dummy [0603:000000:20F8] [817031430305000A0008...] fail (155ms)
16:58:35 newcamd 29000: ecm dummy [0603:000000:20F8] [817031430405006F0004...] fail (169ms)
16:58:35 newcamd 29000: ecm dummy [0603:000000:20F8] [817031430505014D0004...] fail (169ms)
16:58:36 newcamd 29000: ecm dummy [0603:000000:20F8] [81703143000500010008...] fail (169ms)
SA: { sid }
21:57:50 sbox: Viewing Pay TV without a valid subscription is illegal
21:57:50
21:57:50 Wellcome to sBox (for Sigma)
21:57:50 Version: 0.0.4-7 (07/03/2010 #2)
21:57:50 WebPage: http://www.sboxobs.tk
21:57:50
21:57:50 sbox: checking for /camd/OpenXCAS/SboxCAS/sbox.conf... OK
AZBox[SboxCAS]$ 21:57:54 io: sci device detected
21:57:54 reset: got atr on slot0
21:57:54 reset: atr XXXXX10E49524445544F204143532056352E37
21:57:54 reset: hist XXXX4445544F204143532056352E37
21:57:54 reset: char I R D E T O A C S V 5 . 7
21:57:54 reset: working at 3.570Mhz (max 6.000Mhz)
21:57:55 sbox: irdeto card init
21:57:55 irdeto: serial XXXX690F (16148751)
21:57:55 irdeto: provider 00, id 000000, ppua 0018C27B, caid 0603
21:57:55 irdeto: provider 01, id 000001, ppua 00005A00, caid 0603
21:57:55 irdeto: provider 02, id 000002, ppua 00005A00, caid 0603
21:57:55 irdeto: provider 03, id 000003, ppua 00005A00, caid 0603
21:57:56 irdeto: card init ok
21:57:56
21:57:56 webif: init
21:57:56 sbox: entering main loop
21:57:56 sbox: mode cardserver
21:57:56 newcamd: server 20000 init ok
21:58:21 newcamd 20000: accepted dummy from 127.0.0.1
21:58:21 newcamd 20000: sending info dummy
21:58:21 newcamd 20000: ecm dummy [0603:000000:20FA] [807031430606014D0004...] fail (154ms)
21:58:21 newcamd 20000: ecm dummy [0603:000000:20FA] [80703143000600010008...] fail (152ms)
21:58:22 newcamd 20000: ecm dummy [0603:000000:20FA] [80703143010600040008...] fail (168ms)
21:58:22 newcamd 20000: ecm dummy [0603:000000:20FA] [80703143020600070008...] fail (154ms)
I: { 02 }
X: { 10 }
O: { 3000 2000 }
X+: { 01004106:30;18100000:30 }
H: { 06030000 }
C: { 127.0.0.1 20000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 } { 10 } { 06030000:06030000 }
M: { midline { XXXAAAXXX }}
D: { otradline {XXXXASDA { 21197 24050 { XXDDFAF { 2 2 }}}}
[main]
server_only=1 # 0=camd+newcamd server 1=only newcamd server
log=0 # 1=no log 1=log to /tmp/sbox.log //ALWAYS USE 0//
userspath=/PLUGINS/OpenXCAS/SboxCAS/users.sbox # users list
webinterface=1 # 1=web interface on 0=web interface off
webport=81 # web interface port
[slot0]
active=1 # 0=inactive 1=active
sci=/dev/scard # lower
ncdserver=1 # 0=newcamd server off 1=newcamd server on
deskey=0102030405060708091011121314 # newcamd deskey
port= 20000 # newcamd port
mhz=357 # Mhz for card in this reader, ONLY WORKS ON INTERNAL CARDREADER.
#Irdeto Example
[XXXX690F] # irdeto camid (4 bytes)
camkey=0000000000000000 # CamKEY
camkeydata=000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000
emm=0 # 0=accept all 1=block emms 2=block emmu 4=block emmg
portlist=0 # use portlist or no
portlistpath= # path from port.list
[slot0]
user=dummy #usuario
pass=dummy #contraseña
au=1 #autoroll on/off en este caso on
