- 1 Ene 2010
- 23
hello there
i have azbox for many years
I wanted to go back to the original firmware
with azup 2,2,7 flash the patch.e2 kernel
but I did one mistake,i check only kernel and click on install (install e2 / kernel) and no (install official firmware)
now if i insert USB with patch.bin to flash original firmware the tab with the 5 options appears
i click on USB update and he says that usb is not format fat32
after if insert the USB on pc is 10 partition of ext3
there is a solution or azbox died?
