- 26 Ago 2009
- 8.533
- 2.648
AZBox Me - MICOM FIRMWARE -
v2.0 (13. september 2012.)
Download:
http://www.mediafire.com/?940ptcz11i97d89
Mirrors:
https://hotfile.com/dl/171877721/7ef1b2 ... e.zip.html
https://rapidshare.com/files/1768145114 ... Update.zip
- Fixed Auto Power On (No need anymore to press power button on RCU or Front panel to turn on receiver).
How to update Micom Firmware on AZBox Me?
Unpack archive AZBox-Me-MICOM-Update.zip , and copy file micom.bin together with update.ext file to USB Memory Stick. Plug USB Memory Stick in AZBox Me and Turon on receiver. After You see TV Update GUI select Flash Micom, and wait that receiver reboot and then you can remove USB Memory Stick.
To test if Micom Firmware Upgrade process was finished successfully please remove and reinsert power source of AZBox Me, receiver will boot automatically.
Download:
Mirrors:
