resuelto asi por si a alguien mas le pasa:
Reset of TV Set-up
In case you want to reset the configured TV set-up of your RCU,
Press Sequence: <<1 + 6>>, <9>, <9>, <6>
1. Press 1and 6 for three seconds until LED is on.
2. Press <9>, <9>, <6>.
3. This will reverse the RCU into no configuration state.
ya de paso pondre otras configuraciones para el mando del ultimo por si a alguien le interesa:
2-10. Remote Control Unit (RCU) Set-up
Vu+ RCU is a universal RCU that can be used for TV and STB at the same time.
A. User Guide of Vu+ Universal RCU
Pre-note
<< >> means long press
> means normal press
4 digit code can be found in the TV brand code list of the user manual.
The new RCU of Vu+ is a universal type and you can control your Vu+ STB and TV at the same time. This
universal RCU is a modeless design. While offering the basic control functions of your TV (TV Power,
Volume +/-, Mute, AV), you can control STB without having to select mode between TV and STB every
time. Compared to those universal RCU of mode selection types, the modeless universal RCU of Vu+ is
clearly a smarter choice by eliminating unneeded control functions.
1. TV setting
Set-up Sequence: <<1 + 3>>, <4digit brand-code>, <<Mute or Power>>
1. Press number 1and 3 for three seconds until LED is on.
2. Find your TV brand-code from the TV code list and insert 4 digit code.
- If you press “0000”, Full Automatic Scan will start. This will take a while.
3. Keep Mute button (or Power) pressed until your TV is muted (or turned off).
4. If your TV is muted (or turned off), stop pressing Mute button.
5. Now, your RCU is in test mode and press Volume + /- to check if your TV responds.
6. If the volume buttons are operational, Press <OK + STOP ( )> to escape from the set-up mode.
2. AV setting
AV button is for the selection of TV video source. AV button may be automatically set up depending on TV
models. In case it is not automatically configured, please follow the instructions below.
Set-up Sequence <<1 + 9>>, <<AV>>
1. Press 1 and 9 for three seconds until LED is turned on.
2. Keep AV button pressed until your TV responds and displays the video input source.
3. If AV button is working, check if AV button is properly working several times.
4. Press <OK + STOP ( )> to escape from the set-up mode.
3. RCU Buttons for TV
* Buttons for TV only: TV Power. AV
* Buttons switchable between TV and STB: Volume +/ - and Mute
- These buttons are for STB only before the RCU set-up is done.
- It is switchable only after the configuration is done.
* All the other buttons are for STB only
4. Mode Switch of Volume + / - and Mute
For the sake of easy volume control, please set the STB volume at 50% of the maximum level and set
this level as the default volume level from STB. Then, you just have to control your TV volume only without
having to adjust STB volume at the same time.
Set-up Sequence: <<1 + 6>>, <9>, <9>, <3>, <TV Power or STB Power>
2. Press <9>, <9>, <3>.
3. If you want to control of TV volume, press TV Power button. If you want to control STB volume, press
STB Power button.
5. Reset of TV Set-up
6. System Code Change
You can change the system code of your Vu+ universal RCU according to the Vu+ model that you want to
control. The default system code is Mode 2.
Mode 1 : SOLO / DUO
Mode 2 : UNO / Ultimo (*Note : The keyboard of Ultimo remote cannot be used for SOLO,DUO & UNO.)
Mode 3 & 4 : reserved for future models.
Press <<2 + 7>>, <HELP>, <0001 or 0002 or 0003 or 0004>
1. Press 2 and 7 for three seconds until LED is on.
2. Press HELP
3. Press <0001 or 0002 or 0003 or 0004>
