API Para programar plugins para Spark
Si alguno tiene ganas de trastear, aquí le dejo el API para construir los Plugins que funcionan en Spark
Spark-Plugin_1.0.7
También os dejo la Guía
  • spark_plugin_Guia(1).rar
    92,5 KB · Visitas: 119
  • Spark-Plugin_1.0.7.rar
    544 KB · Visitas: 142
Reactions: HSA2000
Dromo ha realizado un pequeño manual de como el ha compilado el famoso hello world con Spark, os dejo sus comentarios y es un buen comienzo para ir aprendiendo este fantástico Sistema operativo.
How to write "Hello World" with S*park plugin
Based on API plugin tools v1.03 prerelease 4
Prerequisites: Linux and STLinux stm23 cross-compile environment and some good will combined with sound patience (beer does help…)
Installing such a setup is beyond this feeble post, but it is quite well documented elsewhere. Anyway, in a brief attempt to describe the basic options, you could:
  1. Install all the stuff from http://www.stlinux.c...ll/distribution for sh4 on your existing Linux box, real or virtual ( you’ll have least problems with Fedora, but with little effort other distributions are just fine including omnipresent Ubuntu, check info on stlinux web)
  2. Use TDT git for E2 and chose stm23-123 build, although it is very likely that you don’t have to read this if you choose that path:)
  3. Take advantage of ready made virtual boxes, probably the easiest way to happiness…
1) Check http://code.google.c...stall_STLinux23 VMwarePlayer-Fedora 11 40GB STm prepared – download sh4
2) Download 3 biggies – VM with stm23 installed on Fedora 11, generously prepared by maxodil. As an added value, this option enables you to make plugins for Fortis STBs as well.
part1 http://www.megaupload.com/?d=OW4T7Y9B
part2 http://www.megaupload.com/?d=ASYP75N6
part3 http://www.megaupload.com/?d=WQ9VQ4RU
In case that you are unsure about the whole thing, the last option – 3.2 could be the most amicable solution.
Some subjective notes, as always YMMV:
  • If using Linux as a guest on a VM do not be trigger happy with kernel updates, or at least check on web whether VM guest additions, or VM Tools, really work with desired combination. This could save you few hours and some nerves.
  • Choice between Oracle VM VirtualBox, VMware Wrkst, Player or something else is up to you, but free VirtualBox seems to work just fine except ‘slight’ annoyances with shared folders. You may end with running MC or something as root, if editing mount in rc.local with your id and rw rights does not work.
  • Gnome-commander or tuxcmd can come handy when moving files to Alien. Of course, if you write 3D rendering applications in awk, ignore this with deepest contempt.
  • You might encounter problems with stmyum (e.g. running ‘stmyum update’ to get the latest stm23 patches) as it’s written with old Python 2.3. Problem is ‘with’ that became a statement in newer Pythons, and stmyum uses it as variable. If you are skeptical towards cold-blooded animals like me, you’ll have great fun fixing that nuisance. On the other hand, updates (in this case) are not really crucial and can be cause of major screwup. See http://www.stlinux.com/faq?q=node/391
  • See here http://www.stlinux.c...ion/directories for brief orientation.
  • To save your time by changing x rights for your plugin, there is simple script for telnet that sets execute rights on Alien-STB. It can be invoked by ‘./755’, better and faster version with ‘expect’ untried as it needs additional package. Of course you can set mounts, but it could turn out to be slower procedure than plain ftp, again, ymmv.
Unpack HelloWsp.tgz in your favorite directory, newly created directory HelloWorldSP holds sources, includes, and sh4 executable is to be placed in ReadyPlugin (including premade ‘-Helloword’) .
2 Makefiles are provided , one for install from scratch or ready made VM (option 3.2 – octaMakefile and other standard STLinux instalments in /opt..) and the other for E2 TDT build (option 2) - tdtMakefile.
Copy the right xxxMakefile to a Makefile, type ‘make’ and, very probable, things won’t work:) Check Makefile, modify it, check environment, see if attached ‘.bashrc’ makes can help you.
File cMain.cpp is commented with enough descriptions, so even I can understand what is going on and that is definitively something. Plugin actions are from line 71 to 122, consisting of three trivial functions.
First one writes ‘Hello World!’ in a window, second one does pretty much the same but via built in OSDmessage, and third displays mounts via popen() in the main plugin window. Line 136 c_menu->SetItmes( mItem, 3); establishes 3 menu items defined by struct mItem in line 55. RcuCtrl is dispatcher at line 150. File cMenu.cpp is the other where your modifications should come to life, e.g. to improve visuals, add or remove max menuitems, etc.
Beware that remote control codes here become STB dependent, so choose wisely if you plan to cover all the members in Fulan family. Colors and additional OSD functions are in osd.h.
Please do not be destructive:)
  • HelloWsp.rar
    980,8 KB · Visitas: 72
Nuevo api y manual para desarrollar plugins "Plug-In SDK"
D
ejado archivo con manual en su interior, dar las gracias a nuestro compi morscor, que lo publico en el otro foro y lo he añadido ya a su sitio.
Os pongo lo que indican desde Spark.
Spark plugin sdk V1.0 released
Plug-in SDK provides the environment for developing plug-in on SPARK platform, including the GUI system and variety of API functions. By using these, you can develop applications based on Linux DVB API, Streaming Media Player, and Linux standard devices.
DESCARGA Directa, Pincha Aquí
Link de Descarga 1
Spark plugin_sdk 1.02 released
[FONT=arial]in Spark plugin_sdk 1.02, one tuner application is added which shows developer how to [/FONT]      [FONT=arial]control tuner and demodulator device.[/FONT]
      [FONT=arial]This is applicable on Spark I - Uni product which has 3 tuners in maximum.[/FONT]
Plug-in SDK provides the environment for developing plug-in on SPARK platform, including the GUI system and variety of API functions. Using these, you can develop applications based on Linux DVB API, internet TV, and applications based on Linux standard devices.
This file focuses on how to use the plug-in SDK to develop plug-in applications, introduces the description of the SDK tree, the program development and operation, the GUI system, the API functions, the interaction between SPARK STB and plug-in etc.
Descarga el Manual y archivos, pinchando Aquí
Mecha
14 Ene 2010
4.132
819
España
Estos son los nuevos alojamientos
  • Plugin_sdk_release_20120524 11277KB 2012-05-25 Download
  • Spark portal webapps 90KB 2012-04-09 Download
HSA2000
Aprendiendo...
19 Ene 2013
461
184
Hola...
Hay algún tutoríal o guía para empezar a programar plugin en c/c++ y/o python para nuestros decos???, si pudiera ser una guia para empezar desde cero y para novato mejor que mejor, estoy muy interesado en el tema...
Salu2...
