How to upgrade Firmware using a USB stick.
freshmaker
27 Ago 2009
Ensure your USB stick is FAT or FAT32 formatted.
The update files are initially named similar to this - azbox-0.9.4283-patch.bin
Copy the file to your USB stick.
Rename the file to read - patch.bin i.e. by removing the characters - azbox-0.9.4283-
Right click the file, select "Properties" and then select the "General" page the file should read only - patch
On the "Details" page and the "file name" should read - patch.bin
Power UP the Receiver with the updated USB stick Inserted.
Choose 1.USB - The receiver will then search for a valid patch.
When found will give details of Your Version on the Receiver, and the Patch version.
Also asks if you want to update. - Press OK.
The patch file is then extracted, with details of the progress shown on the TV screen.
Also there is also a warning: DO NOT POWER OFF.
After the patch is loaded, the Receiver will reboot itself, returning to the Upgrade menu.
Choose 5. Boot without update.
When the Receiver is rebooted, remove the USB stick.
  • Updating with a USB Stick.pdf
    56,9 KB · Visitas: 15
alcaudo
24 Sep 2009
117
Freshmaker, do you think its necessary to make a factory reset after new firm install?
I think it is recommendable so I always do it but then I have to set all parameters again (video, internet, etc).
I know many people don't do it and seems to be ok.
What do you think?
gaizka71
19 May 2009
105
I understand there is a back up all function available so you can restore from backup after factory reset and fresh install.. am I right? I have never used it... only saw the option somewerhe in the firm...
